4710 connectés
  VB/VBA/VBS
  Blocage de mon Serveur de tchat (AcceptTcpClient)
n°2202631
naografix
Posté le 11-09-2013 à 18:17:04  profilanswer
Salut !
Je m'inspire d'un serveur de tchat CONSOLE et j'aimerais le refaire en windows form.
Mais j'ai un probleme, arrivé a mon "AcceptTcpClient" (Ligne 33) mon appli ce bloque complétement, je ne peux plus rien faire...
Voici le code au complet :
Code :
  1. Imports System.Net.Sockets
  2. Imports System.IO
  3. Imports System.Net
  4. Public Class Form1
  5.     Dim Etat As Boolean
  6.     Private Serveur As TcpListener
  7.     Private Client As New TcpClient
  8.     Private IPendpoint As IPEndPoint = New IPEndPoint(IPAddress.Any, 10)
  9.     Private ListConnec As New List(Of Connection)
  10.     Private Structure Connection
  11.         Dim Stream As NetworkStream
  12.         Dim Writer As StreamWriter
  13.         Dim Reader As StreamReader
  14.         Dim Pseudo As String
  15.     End Structure
  16.     Private Sub BtnConnect_Click(sender As Object, e As EventArgs) Handles BtnConnect.Click
  17.         TxtEtat.Text = "En ligne"
  18.         Serveur = New TcpListener(IPendpoint)
  19.         Serveur.Start()
  20.         While True
  21.             Client = Serveur.AcceptTcpClient
  22.             Dim c As New Connection
  23.             c.Stream = Client.GetStream
  24.             c.Reader = New StreamReader(c.Stream)
  25.             c.Writer = New StreamWriter(c.Stream)
  26.             c.Pseudo = c.Reader.ReadLine
  27.             ListConnec.Add(c)
  28.             'ListCo.Items.Add(c.Pseudo)
  29.             Dim t As New Threading.Thread(AddressOf ListenToConnection)
  30.             t.Start(c)
  31.         End While
  32.     End Sub
  33.     Private Sub ListenToConnection(ByVal con As Connection)
  34.         Do
  35.             Try
  36.                 Dim tmp As String = con.Reader.ReadLine
  37.                 ListHistorique.Items.Add(con.Pseudo & " : " & tmp)
  38.                 For Each c As Connection In ListConnec
  39.                     Try
  40.                         c.Writer.WriteLine(con.Pseudo & " : " & tmp)
  41.                         c.Writer.Flush()
  42.                     Catch
  43.                     End Try
  44.                 Next
  45.             Catch
  46.                 ListConnec.Remove(con)
  47.                 ListCo.Items.Remove(con.Pseudo)
  48.                 Exit Do
  49.             End Try
  50.         Loop
  51.     End Sub
  52.     Private Sub BtnDeconnect_Click(sender As Object, e As EventArgs) Handles BtnDeconnect.Click
  53.         Etat = False
  54.     End Sub
  55. End Class
Si quelqu'un a une idée :) Je need :P
Message édité par naografix le 11-09-2013 à 18:17:53
n°2202751
naografix
Posté le 12-09-2013 à 18:58:10  profilanswer
up
  VB/VBA/VBS
Connection à un serveurCréer un mini serveur local
Propriété data, envoi du paramètre au serveurLdap et php blocage de session
Mettre classe client et classe serveur dans un seul mainPb blocage php COM
DLNA Client/Serveurgit : cloner un repository vers un autre serveur ?
application client serveurServeur web java multithread
Plus de sujets relatifs à : Blocage de mon Serveur de tchat (AcceptTcpClient)
