4899 connectés
  SQL/NoSQL
  [Mysql] Problème d'import
n°1739239
EVO_Clubic
The Power Of Dreams
Posté le 30-05-2008 à 09:28:19  profilanswer
Lorsque je veux importer ma base de donnée avec phpmyadmin, j'obtiens cette erreur :
Code :
  1. Erreur
  2. requête SQL:
  3. -- phpMyAdmin SQL Dump
  4. -- version 2.6.1
  5. -- http://www.phpmyadmin.net
  6. --
  7. -- Serveur: localhost
  8. -- Généré le : Mardi 27 Mai 2008 à 12:08
  9. -- Version du serveur: 4.1.9
  10. -- Version de PHP: 4.3.10
  11. --
  12. -- Base de données: `arpebn`
  13. --
  14. -- --------------------------------------------------------
  15. --
  16. -- Structure de la table `jos_artforms`
  17. --
  18. CREATE TABLE `jos_artforms` (
  19. `id` int( 11 ) NOT NULL AUTO_INCREMENT ,
  20. `titel` varchar( 255 ) NOT NULL default '',
  21. `text` text NOT NULL ,
  22. `danktext` text NOT NULL ,
  23. `customjscode` text NOT NULL ,
  24. `customcss` text NOT NULL ,
  25. `metakey` mediumtext NOT NULL ,
  26. `metadesc` text NOT NULL ,
  27. `email` varchar( 255 ) NOT NULL default '',
  28. `ccmail` varchar( 255 ) NOT NULL default '',
  29. `bccmail` varchar( 255 ) NOT NULL default '',
  30. `html` char( 2 ) NOT NULL default '0',
  31. `seccode` char( 2 ) NOT NULL default '0',
  32. `emailfield` char( 2 ) NOT NULL default '0',
  33. `allowatt` varchar( 10 ) NOT NULL default '0',
  34. `allowattfiles` mediumtext NOT NULL ,
  35. `allowattfilesize` int( 40 ) NOT NULL default '102400',
  36. `published` tinyint( 1 ) NOT NULL default '0',
  37. `publish_up` datetime NOT NULL default '0000-00-00 00:00:00',
  38. `created` datetime NOT NULL default '0000-00-00 00:00:00',
  39. `created_by` int( 10 ) unsigned NOT NULL default '0',
  40. `checked_out` tinyint( 1 ) unsigned NOT NULL default '0',
  41. `checked_out_time` datetime NOT NULL default '0000-00-00 00:00:00',
  42. `access` int( 10 ) unsigned NOT NULL default '0',
  43. `ordering` int( 10 ) unsigned NOT NULL default '9999',
  44. `publish_down` datetime NOT NULL default '0000-00-00 00:00:00',
  45. `modified` datetime NOT NULL default '0000-00-00 00:00:00',
  46. `modified_by` int( 10 ) unsigned NOT NULL default '0',
  47. `author` varchar( 255 ) NOT NULL default '',
  48. `modifier` varchar( 255 ) NOT NULL default '',
  49. `version` int( 10 ) unsigned NOT NULL default '1',
  50. `hits` int( 10 ) unsigned NOT NULL default '0',
  51. `created_by_alias` varchar( 255 ) NOT NULL default '',
  52. `afeditor` varchar( 255 ) NOT NULL default '',
  53. `attribs` text NOT NULL ,
  54. PRIMARY KEY ( `id` )
  55. ) ENGINE = MYISAM DEFAULT CHARSET = latin1 AUTO_INCREMENT =2;
  56. MySQL a répondu:
  57. #1064 - You have an error in your SQL syntax.  Check the manual that corresponds to your MySQL server version for the right syntax to use near 'DEFAULT CHARSET=latin1 AUTO_INCREMENT=2' at line 38
Auriez vous une idée ?
Merci  ;)
Championnat GT Sport
  SQL/NoSQL
probléme de methode avec les threadsProbleme CSS entre FF et IE
probleme programme passage differentes basesPHP MYSQL PhpMyAdmin
Problème notification OnReceive avec CasyncSocket[PHP/SGBD] Migration de Access à MySQL - Export pictures
Problème d'apostropheProblème d'import mysql ?
[MYSQL/PHP]Probleme lors d'un import CSVprobleme avec un import fichier texte dans mysql
Plus de sujets relatifs à : [Mysql] Problème d'import
