4193 connectés
mon o/c
n°209905
geoboss
Posté le 03-06-2001 à 23:10:30  profilanswer
[ WCPUID Version 3.0a  (c) 1996-2001  By H.Oda! ]
  Processor #1 : AMD Athlon (Model 4) / 65210EDA
      Platform : Socket A (PGA462 Socket)
 Vendor String : AuthenticAMD
      CPU Type : Original OEM Processor (0)
        Family : 6  (7)
         Model : 4  (4)
   Stepping ID : 2  (2)
         Brand : ----
          APIC : ----
   Name String : AMD Athlon(tm) Processor
Internal Clock : 1333.38 MHz
    System Bus :  266.68 MHz DDR
  System Clock :  133.34 MHz
    Multiplier :   10.0
    L1 I-Cache :   64K Byte
    L1 D-Cache :   64K Byte
    L1 T-Cache :  ----
    L1  Cache  :  ----
    L2  Cache  :  256K Byte
    L2  Speed  : 1333.38 MHz (Full)
    MMX   Unit : Supported
    SSE   Unit : Not Supported
   SSE2   Unit : Not Supported
   MMX2   Unit : Supported
  3DNow!  Unit : Supported
  3DNow!+ Unit : Supported
   Host Bridge : 1106:0305.03 [VIA Apollo KT133x]
  South Bridge : 1106:0686.40 [VIA VT82C686B]
    VGA Device : 102B:0525.04 [Matrox Millennium G400 DualHead]
  Memory  Size : 256M Byte
  Memory Clock :  133.34 MHz
               : 68,2,M:4001,D:0C45,R:0001
    OS Version : Windows Me  Version 4.90.3000
    StdFunc 0  : 00000001 68747541 444D4163 69746E65
    StdFunc 1  : 00000642 00000000 00000000 0183FBFF
    ExtFunc 0  : 80000006 68747541 444D4163 69746E65
    ExtFunc 1  : 00000742 00000000 00000000 C1C7FBFF
    ExtFunc 2  : 20444D41 6C687441 74286E6F 5020296D
    ExtFunc 3  : 65636F72 726F7373 00000000 00000000
    ExtFunc 4  : 00000000 00000000 00000000 00000000
    ExtFunc 5  : 0408FF08 FF18FF10 40020140 40020140
    ExtFunc 6  : 00000000 41004100 01008140 00000000
    C0010010h  : 00000000 00160604 D6589F70 DBA62E64
    C0010011h  : 00000000 08126320 D6589F70 DBA62E64
    C0010012h  : 00000000 00000000 D6589F70 DBA62E64
    C0010013h  : 00000000 00032147 D6589F70 DBA62E64
    C0010014h  : 00000000 0003104F D6589F70 DBA62E64
    C0010015h  : 00000000 0E001008 D6589F70 DBA62E64
    C0010016h  : 00000000 00000000 D6589F70 DBA62E64
    C0010017h  : 00000000 00000000 D6589F70 DBA62E64
    C0010018h  : 00000000 D0000018 D6589F70 DBA62E64
    C0010019h  : 0000000F FC000800 D6589F70 DBA62E64
    C001001Ah  : 00000000 10000000 D6589F70 DBA62E64
    C001001Bh  : 00000000 3FF21223 D6589F70 DBA62E64
    C0010111h  : 00000000 000B0000 D6589F70 DBA62E64
    C0010112h  : 00000000 00000000 D6589F70 DBA62E64
    C0010113h  : 00000000 00000001 D6589F70 DBA62E64
##--- Date 06/03/2001, Time 23:03:58
les chiffres parlent d'eux même!!  :lol:
Mais bon , c vrai j'ai déjà 1 atlon 1.2 où les ponts sont reliés d'origine.
Si quelqu'un peut m'expliquer, dès que je change la ram à autre chose que 8/10 ns ça plante, même à fréquence normale de plus, dés que je passe le cpu fast commande decode à fast je plante aussi.
Enfin et c mon grand drame, j'ai 1 dd 40 go 7200 t udma100 de chez wd et il obtient une note merdique au test lab 2000. :gun:
n°209911
rix
Robotic Intelligent Xenomorph
Posté le 03-06-2001 à 23:12:55  profilanswer
Oué peux mieux faire :p
n°209947
geoboss
Posté le 03-06-2001 à 23:29:46  profilanswer
J'aimrerais bien mais comment ?
je suis en kt7a version du bios wz, via 4.31, 133 x10 et dès que je change le coeff ne serait-ce qu'à 10.5 ça plante soit au boot soit à la moindre manip sous windaube.
Faut essayer fsb plus ? :ouch:
Au fait vous avez pas un truc pour améliorer les perfs de mes dd ?
n°209961
geoboss
Posté le 03-06-2001 à 23:36:55  profilanswer
n°210007
Copermine
Posté le 04-06-2001 à 00:24:13  profilanswer
1000@1450 (10*145)
MSI K7T Turbo
http://www.ifrance.com/blaast/MBM_02-06.JPG
Plus de sujets relatifs à : mon o/c
