4394 connectés
Sujet : Recherche de galvanomètres
limpkin Me revoilou!
Apres 2 semaines et demi, nous avons enfin terminé notre projet!
Remerciements des personnes ayant aidé (majoritairement le constructeur des galvos qui nous a filé toutes nos constantes):
Hello!
Here are attached the powerpoint (hope you'll understand a bit of french) we're gonna show to our teachers and a picture of the whole system working.
Yesterday when we were showing our project we had a response time of 2.6ms because our power supply wasn't powerful enough.
Because of the lack of power we didn't have straight lines, even if our galvo control was fine (we had better curves than the ones showed in the powerpoint).
You will see in the powerpoint that we were projecting moving 3D shapes (picture of a "E" in the powerpoint).
I'll try to have better pictures of our displayed shape because in the ones i gave you the camera obturation time was either too long (blurry shape) or too short (only a few lines).
Thanks a lot for your help, without you it would have been an impossible mission. It was really hard to make the whole system work in only 2 weeks and a half but thanks to your help we managed to make it work!!
Le lien pour l'image: http://limpkin.06.free.fr/PICT0279.JPG
Le lien pour le powerpoint: http://limpkin.06.free.fr/presentationPR302.ppt
Hello!
limpkin Et me revoila pour la suite de mes aventures:
Galvos recus, mirroirs achetés, maquette réalisée :) :
http://img66.imageshack.us/img66/4 [...] rx5.th.jpg
J'attend une evaluation de board d'analog devices pour un DAC, le circuit d'asservissement est à réaliser :)
limpkin Wow!
La coincidence :), je t'explique ma situation actuelle:
Je viens d'acheter des galvos (http://cgi.ebay.com/ws/eBayISAPI.d [...] &rd=1&rd=1) il y a quelques jours, j'attend de les recevoir (tu remarqueras que le prix est... comment dire.... :D :D :D).
J'ai aussi acheté un laser vert 35mw, les lunettes de protections qui vont avec. Je vais réaliser mon projet dans le cadre de mon cursus pendant le mois de juin (carte de developpement arm, ADC, DAC, asservissement etc en numérique). Donc concernant la partie commande, je pense juste faire une etape amplification (l'étape gain, réglage du zero se faisant en numérique via mon programme).
Je pense donc avoir le matos de base, il me manquerait juste un actuator (ou shutter) pour couper le faisceau, et un mirroir de renvoi a 90° pour bien positionner le faisceau sur les galvos. Reste plus qu'a developper :)
Sinon ca doit etre interessant de travailler dans ce genre d'industrie non? :)
fredauto bonjour
je peut t'aider ,je travaille dans les lasers de marquage le systeme est basé sur la deviation du faisceau par deux mirroirs sur deux axes ,posés sur des moteurs galvanometriques , et je bosse au sav electronique ,donc il m'arrive de reparer des cartes de commande a amplificateur hybride de tetes galvas . mais sache qu une tete complete coute tres cher dans les 5000 euros (carte +moteur +mirroirs/ sans la lentille final)
