7600 connectés
Sujet : Trous sur la ASUS 9800XT (big pictures)
rorofox Oui, oui, après plus d'un an en Irlande chez Billou, je me débrouille. :D
"If you're going to water cool that card you have to take off the complete cooling system that's on it now and then replace the ram cooling with some other type of ram sink. All 9800XTs have that huge sink on them, they might look a bit different but they all mount with the same pin mount holes. I just looked at your card on line and it looks as if yours also has the same mount holes as the rest of the XTs. It also looks to be the same red PCB as the other XTs so I don't think you'll have any problems[/g]. You'll just have to get different ram sinks if that cooler is one piece.
Here's a little out take from a recent review of the card about the board design:
"It's no surprise that Asus follows the reference designed ATi Radeon 9800XT with the exception of the additional ATi Rage Theatre chip on the back.""
Merci de ton aide Zebra3-...  :hello:
Zebra3- Si tu lis l'anglais : http://www.houseofhelp.com/forums/ [...] hp?t=24337
rorofox Je viens d'acheter une ASUS 9800XT et je voudrais savoir si les trous sur le PCB sont les mêmes que sur les autres 9800XT vu que ASUS a un PCB particulier et un système de refroidissement propriétaire.
http://www.ati-news.de/Bilder/News/Asus/r9800xt.jpg
http://itc.ua/img/testlab/2003/asusradeon9800xt3.jpg
Photos haute-définition:
http://images.google.fr/imgres?img [...] oe%3DUTF-8
Ce serait pour la watercooler... :love:
Merci de votre aide. :hello:
