4283 connectés
Sujet : L'ultime accessoire pour overclocker AMD ?
Lex mais pas très rassurant ... déjà que les Athlons sont pas ce qui se fait de plus solide !
As opposed to the ZIF (Zero Insertion Force) sockets that are common today, Upgradeware's adapter is a module that offers no ease-of-use, because the processor has to be inserted into the adapter along with all of its 462 pins. Do this carefully, because if you don't apply even pressure to all sides when inserting the CPU into the socket, then it might bend - this can result in breaking the circuitry and causing the CPU to die a premature death.
nikopop dommage,sorti trop tard  :sarcastic:
Lex :ouch:
C4_EXODUSSS une CG s impose  :D  [:thesphax]
niiizzzz ben sinon je voi pas ou le mettre  :whistle:
lagaffe ca se met entre le proco et le socket? (si j'ai bien compris)
niiizzzz http://www.tomshardware.com/cpu/20030703/index.html
Il semblerai qu'il libere les coef sur TOUS les athlons....
