6464 connectés
Sujet : décidement j ai tjr des probs !!!!!
kevin_the_killer up ! :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:
kevin_the_killer alors j ai o/c mon p4 1.8 a 2.4 il est a 1.7 volts sinon il plante et quand je lance 3 d mark o bout d un moment pafff reboot  :pt1cable:
1ere quest:ca peut venir de l alim??
2eme:est ce que c est l o/c
3: dite vos propositions
