6198 connectés
Sujet : mon system report sisoft sandra 2001
JOEBAR_91 *****  Start of Report  *****
<<< General >>>
    Program Name:                         SiSoftware Sandra Standard [Web]
    Program Version:                      2002.1.8.59
    Registered User:                      JOEBAR_69
    Registered Company:                   FIGHT CLUB
    Licence Status:                       Unregistered Shareware Evaluation Copy. FREE for
                                          personal use.
    Licence Extra:                        See Ordering Document for information on the
                                          Professional version.
    Report Done By:                       JOEBAR_69
    Host Name:                            JOEBAR
    System ID:                            4E492441-3184-42a5-9518-E41C366D6CDB
    Run ID:                               38AE3BCB-4537-42d5-AFEC-B7C2FECFA37A
    Report Done On:                       mardi 28 mai 2002
    Report Done At:                       19:21:51
<<< Comments >>>
    Comments:                             1000 mhz 1.85v 10X100mhz
<<< CPU Arithmetic Benchmark >>>
  < Benchmark Results >
    Dhrystone ALU:                        2754MIPS
    Whetstone FPU:                        1372MFLOPS
  < Test Status >
    SMP Test:                             No
    Total Test Threads:                   1
    SMT Test:                             No
    Dynamic MP/MT Load Balance:           No
    Processor Affinity:                   No
  < Processor(s) >
    Model:                                AMD Duron(tm) Processor
    Speed:                                1.01GHz
    Model Number:                         1006 (estimated)
    Performance Rating:                   PR1338 (estimated)
    L2 On-board Cache:                    64kB ECC synchronous write-back
    Front Side Bus Speed:                 2x 101MHz (202MHz data rate)
  < Technology Support >
    SSE2 Technology:                      No
    Hyper-Threading Technology:           No
  < Performance Tips >
    Notice N5008:                         To change benchmarks, click Options.
    Notice N5004:                         Synthetic benchmark. May not tally with 'real-life'
                                          performance.
    Notice N5006:                         Only compare the results with ones obtained using the
                                          same version!
    Tip T2:                               For more information about tips, press F1 and scroll
                                          to the Tips section.
<<< CPU Multi-Media Benchmark >>>
    Integer aEMMX/aSSE:                   5482it/s
    Floating-Point aE3DNow!:              6074it/s
  < Test Status >
    SMP Test:                             No
    SMT Test:                             No
  < Processor(s) >
    Speed:                                1.01GHz
    Model Number:                         1007 (estimated)
    Performance Rating:                   PR1339 (estimated)
    MMX Technology:                       Yes
    SSE Technology:                       No
    SSE2 Technology:                      No
    Extended AMD MMX Technology:          Yes
    3DNow! Technology:                    Yes
    Extended 3DNow! Technology:           Yes
                                          performance.
                                          same version!
<<< Memory Bandwidth Benchmark >>>
    RAM Bandwidth Int Buffered aEMMX/aSSE:765MB/s
    RAM Bandwidth Float Buffered aEMMX/aS:763MB/s
  < Int Buffered aEMMX/aSSE (Integer STREAM) Results Breakdown >
    Assignment:                           769MB/s
    Scaling:                              768MB/s
    Addition:                             762MB/s
    Triad:                                763MB/s
    Data Item Size:                       4-bytes / 32-bits
    Buffering Used:                       Yes
    Bandwidth Efficiency:                 95% (estimated)
  < Float Buffered aEMMX/aSSE (Float STREAM) Results Breakdown >
    Assignment:                           768MB/s
    Scaling:                              768MB/s
    Addition:                             757MB/s
    Triad:                                760MB/s
    Data Item Size:                       8-bytes / 64-bits
    Buffering Used:                       Yes
    Bandwidth Efficiency:                 94% (estimated)
  < Test Statistics >
    Array Memory Used:                    64MB
    SMP Test:                             No
    SMT Test:                             No
  < System Chipset >
    Model:                                VIA Technologies Inc VT8363/5 KT133/KM133 System
                                          Controller
    Max. Bus Bandwidth:                   1616MB/s (estimated)
  < Logical/Chipset Memory Banks >
    Bank 0 Setting:                       64MB SDRAM 2-2-2CL
    Bank 4 Setting:                       64MB SDRAM 2-2-2CL
    Bank Interleave:                      4-way
    Memory Bus Speed:                     1x 101MHz (101MHz data rate)
    Max. Memory Bandwidth:                808MB/s (estimated)
  < Instruction Set Support >
    MMX Technology:                       Yes
    SSE Technology:                       No
    SSE2 Technology:                      No
                                          performance.
                                          same version!
    Warning W5403:                        Tests using (E)MMX/SSE(2) are not standard STREAM.
*****  End of Report  *****
<<< General >>>
                                          personal use.
    Host Name:                            JOEBAR
<<< Comments >>>
  < Test Status >
    SMP Test:                             No
    SMT Test:                             No
  < Processor(s) >
    Speed:                                1.01GHz
    SSE2 Technology:                      No
                                          performance.
                                          same version!
  < Test Status >
    SMP Test:                             No
    SMT Test:                             No
  < Processor(s) >
    Speed:                                1.01GHz
    MMX Technology:                       Yes
    SSE Technology:                       No
    SSE2 Technology:                      No
                                          performance.
                                          same version!
    Assignment:                           769MB/s
    Scaling:                              768MB/s
    Addition:                             762MB/s
    Triad:                                763MB/s
    Buffering Used:                       Yes
    Assignment:                           768MB/s
    Scaling:                              768MB/s
    Addition:                             757MB/s
    Triad:                                760MB/s
    Buffering Used:                       Yes
  < Test Statistics >
    SMP Test:                             No
    SMT Test:                             No
  < System Chipset >
                                          Controller
    MMX Technology:                       Yes
    SSE Technology:                       No
    SSE2 Technology:                      No
                                          performance.
                                          same version!
