4750 connectés
Sujet : WIN XP m empeche t il d overclocké ???? voltage core ki fé des truc
JOEBAR_91 ca c mon system report montrant kilé stable
*****  Start of Report  *****
<<< General >>>
    Program Name:                         SiSoftware Sandra Standard [Web]
    Program Version:                      2002.1.8.59
    Registered User:                      JOEBAR_69
    Registered Company:                   FIGHT CLUB
    Licence Status:                       Unregistered Shareware Evaluation Copy. FREE for
                                          personal use.
    Licence Extra:                        See Ordering Document for information on the
                                          Professional version.
    Report Done By:                       JOEBAR_69
    Host Name:                            JOEBAR
    System ID:                            4E492441-3184-42a5-9518-E41C366D6CDB
    Run ID:                               38AE3BCB-4537-42d5-AFEC-B7C2FECFA37A
    Report Done On:                       mardi 28 mai 2002
    Report Done At:                       19:21:51
<<< Comments >>>
    Comments:                             1000 mhz 1.85v 10X100mhz
<<< CPU Arithmetic Benchmark >>>
  < Benchmark Results >
    Dhrystone ALU:                        2754MIPS
    Whetstone FPU:                        1372MFLOPS
  < Test Status >
    SMP Test:                             No
    Total Test Threads:                   1
    SMT Test:                             No
    Dynamic MP/MT Load Balance:           No
    Processor Affinity:                   No
  < Processor(s) >
    Model:                                AMD Duron(tm) Processor
    Speed:                                1.01GHz
    Model Number:                         1006 (estimated)
    Performance Rating:                   PR1338 (estimated)
    L2 On-board Cache:                    64kB ECC synchronous write-back
    Front Side Bus Speed:                 2x 101MHz (202MHz data rate)
  < Technology Support >
    SSE2 Technology:                      No
    Hyper-Threading Technology:           No
  < Performance Tips >
    Notice N5008:                         To change benchmarks, click Options.
    Notice N5004:                         Synthetic benchmark. May not tally with 'real-life'
                                          performance.
    Notice N5006:                         Only compare the results with ones obtained using the
                                          same version!
    Tip T2:                               For more information about tips, press F1 and scroll
                                          to the Tips section.
<<< CPU Multi-Media Benchmark >>>
    Integer aEMMX/aSSE:                   5482it/s
    Floating-Point aE3DNow!:              6074it/s
  < Test Status >
    SMP Test:                             No
    SMT Test:                             No
  < Processor(s) >
    Speed:                                1.01GHz
    Model Number:                         1007 (estimated)
    Performance Rating:                   PR1339 (estimated)
    MMX Technology:                       Yes
    SSE Technology:                       No
    SSE2 Technology:                      No
    Extended AMD MMX Technology:          Yes
    3DNow! Technology:                    Yes
    Extended 3DNow! Technology:           Yes
                                          performance.
                                          same version!
<<< Memory Bandwidth Benchmark >>>
    RAM Bandwidth Int Buffered aEMMX/aSSE:765MB/s
    RAM Bandwidth Float Buffered aEMMX/aS:763MB/s
  < Int Buffered aEMMX/aSSE (Integer STREAM) Results Breakdown >
    Assignment:                           769MB/s
    Scaling:                              768MB/s
    Addition:                             762MB/s
    Triad:                                763MB/s
    Data Item Size:                       4-bytes / 32-bits
    Buffering Used:                       Yes
    Bandwidth Efficiency:                 95% (estimated)
  < Float Buffered aEMMX/aSSE (Float STREAM) Results Breakdown >
    Assignment:                           768MB/s
    Scaling:                              768MB/s
    Addition:                             757MB/s
    Triad:                                760MB/s
    Data Item Size:                       8-bytes / 64-bits
    Buffering Used:                       Yes
    Bandwidth Efficiency:                 94% (estimated)
  < Test Statistics >
    Array Memory Used:                    64MB
    SMP Test:                             No
    SMT Test:                             No
  < System Chipset >
    Model:                                VIA Technologies Inc VT8363/5 KT133/KM133 System
                                          Controller
    Max. Bus Bandwidth:                   1616MB/s (estimated)
  < Logical/Chipset Memory Banks >
    Bank 0 Setting:                       64MB SDRAM 2-2-2CL
    Bank 4 Setting:                       64MB SDRAM 2-2-2CL
    Bank Interleave:                      4-way
    Memory Bus Speed:                     1x 101MHz (101MHz data rate)
    Max. Memory Bandwidth:                808MB/s (estimated)
  < Instruction Set Support >
    MMX Technology:                       Yes
    SSE Technology:                       No
    SSE2 Technology:                      No
                                          performance.
                                          same version!
    Warning W5403:                        Tests using (E)MMX/SSE(2) are not standard STREAM.
*****  End of Report  *****
<<< General >>>
                                          personal use.
    Host Name:                            JOEBAR
<<< Comments >>>
  < Test Status >
    SMP Test:                             No
    SMT Test:                             No
  < Processor(s) >
    Speed:                                1.01GHz
    SSE2 Technology:                      No
                                          performance.
                                          same version!
  < Test Status >
    SMP Test:                             No
    SMT Test:                             No
  < Processor(s) >
    Speed:                                1.01GHz
    MMX Technology:                       Yes
    SSE Technology:                       No
    SSE2 Technology:                      No
                                          performance.
                                          same version!
    Assignment:                           769MB/s
    Scaling:                              768MB/s
    Addition:                             762MB/s
    Triad:                                763MB/s
    Buffering Used:                       Yes
    Assignment:                           768MB/s
    Scaling:                              768MB/s
    Addition:                             757MB/s
    Triad:                                760MB/s
    Buffering Used:                       Yes
  < Test Statistics >
    SMP Test:                             No
    SMT Test:                             No
  < System Chipset >
                                          Controller
    MMX Technology:                       Yes
    SSE Technology:                       No
    SSE2 Technology:                      No
                                          performance.
                                          same version!
JOEBAR_91 harfffffffffffffff
mé ca tourne bien pourtant jé pas envie de repasser a 98 SE
c koa ki fou la merde ?
il a un log des voltages core ?
JOEBAR_91 jvien de lancer 3DMark 2001 SE
ca tourne impec a 1000 mhz 10X100mhz 1.85 V de core ca chauffe pas trop genre 45 ° radiateur je peut laisser ma main sur la radiateur (ca chauffe un peu kan meme mais c pas intenable du tout )
bouss01 eh bien oui!!!
xp n'est pas terrible pour @
dommage
JOEBAR_91 je vous explique mon probleme
je souhaite repasser mon duron 800 a 1000mhz ( stable sous win 98 se ) c un duron debrider sur soltek SL75KAV
donc voila mon blem
je vais dans le bios je met 10x100mhz a 1.825 v pour etre sur , je boot j arrive dans win ca tourne 10 min a 45 ° environ
je remarque une couille dans sisoft sandra au nivo de la motherboard ki marque plus rien en info
je lance MBM5 pour verifier la temp et boum ca plante
je relance je met 1.85 v , ca plante de meme
je met 1.60 , ca plante de meme
alors je comprend plus rien la le processeur surchauffe pas
il tient impec sauf kan je lance des application ki font appelle au sonde (MBM5 a installé un fichier bizarre en dll en disnat kilyruai ptete des blem )
ca vient de WIN XP , de MBM5 ou de ma CM kiné pas stable ?
avant ca marchait impec a 1000mhz sous win 98 se
