8093 connectés
Sujet : Prob Oc Geforce2 Ti [Grosses plaques triangulaire]
apolon34 ouais de toute facon les deux sont au taquet
sinon je sais qu'il faut privilegier la ram mais vu qu'elle monte pas plus haut....
reivax59 le gpu @280??? travailez votre bande passante mémoire les enfants, c'est là que se situe le vrai goulot d'étranglement de la carte.
extrait d'un article d'Anandtech sur l'oc des gf2ti: (ANGLOPHOBES BE CAREFUL :D )
Looking at the performance increase that resulted from the core speed overclock, we can deduce that there is a memory bandwidth bottleneck in the GeForce2 Ti 200's 400MHz DDR memory bus. Increasing the core clock speed from the stock 250MHz to 300MHz resulted in a performance gain of only 1.6%, representing a 2.1 FPS speed boost. If the GeForce2 Ti 200 had the same memory management technologies incorporated in the GeForce3 series cards and featured a higher memory clock speed, we could have expected a much larger performance boost associated with the 50MHz overclock.
The small performance gain that occurred when overclocking the GeForce2 Ti 200 core alone is modeled by the regression line f(x)=0.042x+131.014. As you can see, the extremely small slope suggests that performance increases only very marginally each time the core clock speed is boosted up 1MHz.
Knowing that the card appears to be quite memory bandwidth limited at the stock clock setup, we suspected that a memory overclock would dramatically increase the card's performance. Let's see what it did to the performance of the card.
The line increases at a much greater rate when the memory clock is upped while maintaining the stock core speed. No longer are we looking at marginal gains from overclocking like we saw when we overclocked the core. Instead, the performance of our GeForce2 Ti 200 increased 24.8% when overclocked; a very noticeable speed boost that provided for an additional 32.4FPS in Quake III Arena at 1024x768x32.
The data in this case increases in an almost perfect linear fashion, suggesting that the memory bus is the bottleneck in the GeForce2 Ti 200. The regression line, f(x)=0.271x+131.279, shows that it took approximately 3MHz of overclocking to increase gameplay performance by 1FPS in our test.
Once again, we were able to realize rather large speed increases when overclocking both the memory and the core of the GeForce2 Ti 200. Overclocking the card to the max speed we could reach while pushing both the memory and core was 290MHz/480MHz. Note that this is a lower speed than we were able to get when overclocking just the memory or just the core, as card speeds were 300MHz/400MHz when overclocking just the core and 250MHz/520MHz when overclocking just the memory. At 290MHz/480MHz the GeForce2 Ti 200 performed 18.6% better than the stock clocked card, increasing gameplay by 24.3FPS.
The regression line for this data fits a linear model represented by f(x)=0.611x+131.02. As you can see, the slope of this line is the largest yet, meaning that for each 1MHz that the core clock was increased and 2MHz that the memory clock was increased, game performance increased the most. It took only 2 steps (2MHz on the core and 4MHz on the memory) to get to a 1FPS speed increase.
It is important to note that just because the slope of the line produced when overclocking the core and the memory was the largest, overclocking the core and the memory in this case did not necessarily produce the most performance. This is because when we overclocked the core and the memory together we could not get the same high clock speeds that we got when overclocking just the core or just the memory (as noted above).
Because of this, we were actually able to get the most performance out of our GeForce2 Ti 200 card by overclocking the memory alone. Pushing the memory clock to 520MHz resulted in better performance than pushing the core to 290MHz and the memory clock to 480MHz. This is because, as we noted before, the GeForce2 Ti 200's memory bus is the bottleneck in the system
As the data shows, the best way to overclock your GeForce2 Ti 200 is to push the memory as high as possible and then slowly bring up the clock speed.
Comme le dit la conclusion de l'article, :sarcastic: travaillez vos fréquences mémoires avant vos fréquences gpu!!
[jfdsdjhfuetppo]--Message édité par reivax59--[/jfdsdjhfuetppo]
onizuka c pas le chip qui gene, il a un dissipateur du tonnerre, g jamais vu ça lol, mais y a rien sur la ram, je vais mettre des rad, je vais a casse pc en hercher un pour le modifier legerement :) apres ça tiendra nikel
apolon34 >onizuka faut la refroidir un peu pour virer les pbs de freeze
ma msi tient 280/460 depuis que j'ai change le refroidissement et ajoute des rads sur la memoire
wolverineos ta quel drivers ?
j'avais "des flous" par ex visages perso de DEUS EX et sur les icones de 3d mark pdt le bench en bas à droite avec les 27.51 j'ai remis les 21.83 :o et c beaucoup mieux, quelques pertes en perfs mais c nickel
rodage=demo de 3d mark en looping ;) resolution au max
[jfdsdjhfuetppo]--Message édité par trickle2--[/jfdsdjhfuetppo]
onizuka 275/450 ( je peux foutre 280/460 mais bon, ça freeze un peu) y a t il un roddage necessaire? ma carte est neuve, et je l'ai a peinee reçus que je l'ai poussé a fond
wolverineos 280/450 sur une GF2 Ti pixelview, avec rad sur la mem c pareil donc à mon avis c la ram qui tiens pas plus ou le voltage
razorbak83 ben nan pour l'instant, j'ai tout laissé d'origine, donc pas de rad sur la memoire ... voili voilou, mais je pense bientot la watercooler cette petite GF2 TI ..... parce que le ventilo d'origine, fait trop de bruit à mon gout ;... lol
 :love:
reivax59 y'a des rads sur la mem sur ta ti razorkak?
sinon bravo... t'as tiré le gros lot :sol:
razorbak83 ben voui moi j'ai une GF2 TI 64VX de chez leadtek
j'ai pas changé le ventirad d'origine, mais je trouve bruyant ...
mais bon, je l'ai poussé à 270/531 ... et ça crache pas mal lol
voili voilou
rizzla_tsa et a ceux qui ont une geforce 2 Ti de chez leadtek !
AVEZ VOUS RAJOUTER DES VENTILOS DESSUS ?
SI OUI :
voyez vous un net changement ???
thx
popoles
Popol96 a écrit a écrit :
Bien je v essayer avec le l'artic collante , la j'en ai pas , faut la commander  :(
mais , mettre des rad sans monter la tension c pas stupide ?
Quand vous dite quel suis pas , si je met c con de rad ça vas vraiment l'aidez  ? car g mis un doigt sur une ram et franchement , c pas chaud  ! , je dirait temp coporel +-
Alors faut vraiement que j'achete de l'artic ou je l'aise tomber ça servira a rien sans mod voltage mem au miveau de la carte ?
pas forcément idiot les rads.
avec une radeon R8500 built by ati, j'étais bloqué à 290 pour la mem. avec des rads "bricolés", je suis passé à 310 avec fsb à 157 sur une kt7a, sinon en fsb 133 ca peut monter à 330.
(fréquences maxi indiquées pour une image nickel)
et c'est vrai que pour un gros overclock fo passer par le voltage, mais pour mon cas perso c'était uniquement pour le sport, car c'est surtout mon proc qui limite (tbird 1,57), et pas trop la cg
popol96 Bien je v essayer avec le l'artic collante , la j'en ai pas , faut la commander  :(
@poppof
popoles a écrit a écrit :
et après voir si il y a une solution hard pour augmenter le voltage mem
ca m'interresse aussi de trouver la modif!!
-unsin- les plaques noires ou blanches que tu vois c les poly qui sont pas affichés assez vite ( clipping )parce que la carte arrive plus à suivre, elle a un chtit coup de chaud !  :sweat:
popoles et après voir si il y a une solution hard pour augmenter le voltage mem
popoles
Bien oui c ce que je me dit aussi , c le Gpu ki deconne mais si je met le Gpu a 200 et la ram a 450 g toujours les plaque noir qui se ballade  :heink:
je comprend pas trop  :(
le prob de plaque , viendrai t'il quand meme de la mem  ? :heink:
vi c'est la mem
seul moyen :les rads
popol96 Bien oui c ce que je me dit aussi , c le Gpu ki deconne mais si je met le Gpu a 200 et la ram a 450 g toujours les plaque noir qui se ballade  :heink:
frandon il me semble que lorsque les textures se plaquent mal, c'est le gpu qui est en cause
à confirmer quand meme par un mec plus calé  :D
popol96 C clair que le Gpu la frequence rien a foutre 250 c bon deja  :crazy:
mais la ram arf fait chier , donc je peut coller des pti rad sur les ram et je v monter un peut plus alors  !
moi je penssait a un prob de voltage pour les prob de Plaque noir qui se ballade ......
et meme a 450 g pas de point blanc  ! donc la ram a l'air de tenir
les plaque vienne de koi de la ram trop haute  ?
reivax59 leadtek gf2ti power...
280/480 ss pbs... avant qu'on me la pique pdt un cambriolage
frandon j'ai une pixelwiev
250/444 par defaut
le core monte à 290 stable
la ram à 460 stables mais points blancs
à 465, les defauts de textures apparaissent
ne t'inquiete pas, cette ram est pas top
ne te fie pas aux nazes qui disent que le core c'est le + important : c'est pas vrai  :o
fait des benches avec core aà fond et mem d'ori et l'inverse, tu comprendra  ;)
sinon, il faudarit faire comme les leadtec : un rad qui englobe GPU et ram --> la ram est ventilée  :)
VinchHum
Voila , g actuellement une GeforceTi , qui est d'origine en 250/401 , pas de rad sur les memoires, et un ventirad sur le Gpu.
le ram et de la 4Ns je pensse de marque Samsung je pensse.
le prob c que quand je passe la ram a 450 Par exemple , il me fait de grosse plaque noire qui ce ballade sur l'image  :( mais surtout dans les bench , dans les jeux il y a moin mais alors nettement moi de plaque .
c koi que je peut faire pour ameliorer la chose c possible ? il y a peutetre un Mod , non ?
de plus la sortie Tv de donne vraiment une image de merde 'pire que ma Gf2Mx) je me demande si c (normal)
La carte et une Club3d Ti , copie exacte de la Pixelview ...
des conseils seraient les bien venu  :sweat:
250 sur le core par défaut c'est déjà pas mal la mienne ne va pas si haut et elle est en 175 par défaut !
Le plus important étant le core et non la mémoire ...
Tu peux : ajouter un ventillo qui souffle en direction de la carte ... ou alors rajouter des radiateurs sur tes memoires en les collant avec de l'artic silver glue ... tu va gagner 20/30 en mémoires
popol96 Voila , g actuellement une GeforceTi , qui est d'origine en 250/401 , pas de rad sur les memoires, et un ventirad sur le Gpu.
[jfdsdjhfuetppo]--Message édité par Popol96--[/jfdsdjhfuetppo]
