Overclocking, Cooling & Modding
On peut thermoreguler des ventilos avec un soft de monitoring ?| Dernière réponse | |
| Sujet : On peut thermoreguler des ventilos avec un soft de monitoring ? | |
| pom2ping | Liste des carte mere compatible avec speedfan :p :
Manufacturer Model Chipset CPU Notes - ABIT BE6 Intel BX Slot 1 - ABIT BE6-2 Intel BX Slot 1 - ABIT BF6 Intel BX Slot 1 - ABIT BL7 Intel 845 Socket 478 - ABIT BP6 Intel BX Dual PPGA Celeron - ABIT BW7 Intel 845 Socket 423 - ABIT BX133-RAID Intel BX Pentium III, Celeron - ABIT SA6 Intel i815EP Pentium III, Celeron - ABIT SA6R Intel i815EP Pentium III, Celeron - ABIT SH6 Intel i815E Slot 1 - ABIT ST6R Intel i815EP Pentium III, Celeron - ABIT TH7II-RAID Intel 850 Socket 478 - ABIT ZM6 Intel ZX PPGA Celeron - AOPEN AX3S Intel i815E Pentium III, Celeron - AOPEN MX3S Intel i815E Pentium III, Celeron - AOPEN MX3W Intel i810DC-100 PPGA Celeron - ASUS A7A266 ALi M1647 Socket A it has been reported to slow down fans at 15% and to stop them at 10% - ASUS A7S-VM SiS730S Socket A - ASUS A7V266 VIA KT266 Socket A - ASUS A7V266-E VIA KT266A Socket A with bios 1005.15 (beta) it slows fans down at 20% and stops them at 15% - ASUS CUSI-M SiS630E Pentium III, Celeron - ASUS CUV4X VIA694 Pentium III, Celeron - ASUS CUV4X-D VIA694 Dual Pentium III - ASUS MEW-L Intel i810 Socket 370 - ASUS P3B-F Intel BX Slot 1 - ASUS P3C2000 - ASUS P3V4X VIA Apollo Pro 133A Pentium III, Celeron - ASUS P4T Intel 850 Pentium 4 - ASUS P4T-E Intel 850 Socket 478 - ASUS TUV4X ALI M1651T Pentium III, Celeron - ASUS WMT-LX (P4T-M like) Intel 850 Pentium 4 - CHAINTECH CT-60JV2 Intel i815E Pentium III, Celeron - DELL Inspiron 8000 - DELL Latitude C810 Intel Pentium III - DELL Latitude CP Intel BX P233MMX Using BIOS A16 fans can be smoothly controlled - DELTA MP2-BX-X Intel BX Slot 1 - DFI CS60-EC Intel i815EP Pentium III, Celeron - DFI CS62-TC Intel i815EP Pentium III, Celeron - DFI CW-35L Intel i810-L Pentium III, Celeron - FUJITSU/SIEMENS SilverLine - ECS K7VTA3 v1.x KT266 Socket A - ECS P6IPA-T Intel i815EP Pentium III, Celeron - EPOX 8KHA KT266 Socket A - EPOX 8KHA+ KT266A Socket A - FIC FS15 Intel i815EP Pentium III, Celeron - GIGABYTE GA-6OMM7 Intel i815 Pentium III, Celeron - GIGABYTE GA-6OXC Intel i815P Pentium III, Celeron - GIGABYTE GA-6WMMC7C Intel i810 Pentium III, Celeron - GIGABYTE GA-8TX Intel i850 Pentium 4 - INTEL D815EEA Intel i815E Pentium III, Celeron - IWILL DVD266-R VIA Apollo Pro 266 Dual Pentium III - IWILL DVD266u-RN VIA Apollo Pro 266T Dual Pentium III - KOBIAN KOB KT266 FSX VIA KT266 Socket A it has been reported to stop fans at 75% - MSI MS6163 v2.0 (6163 Pro) Intel BX Slot 1 - MSI MS6337 (815E Pro) Intel i815E Pentium III, Celeron - MSI MS6337 v5.x (815 EPT Pro) Intel 815EP B-step Pentium III, Celeron - MSI MS6351 Intel i815E Pentium III, Celeron - MSI MS6380 (K7T266 Pro) VIA VT8633 Socket A - MSI MS6380 v2.0 (K7T266 Pro2) VIA KT266A Socket A - MSI MS6528 (845 Pro2-R) Intel 845 Socket 478 - PROCOMP BIS2M Intel i815E Pentium III, Celeron - QDI KuDoz 7 VIA KT266A Socket A - QDI SynactiX 5ep Intel i815EP Pentium III, Celeron - SOLTEK SL-65H60 Intel i810 PPGA Celeron - SONY VAIO PCV-LX900 Pentium III - SONY VAIO PCV-RX360DS Pentium III - SONY VAIO PCV-RX380DS Intel 850 Pentium 4 - SOYO SY-7IWM-L Intel i810E PPGA Celeron - SOYO SY-6BA+100 Intel BX Slot 1 - SOYO SY-6BA+III Intel BX Slot 1 - SOYO SY-6VBA133 VIA Apollo Pro133 Slot 1 - SOYO SY-TISU Intel i815EP Pentium III, Celeron - Transcend TS/ASL3 Intel i815E Pentium III, Celeron - TYAN Thunder K7 (S2462) AMD-760 MP Dual Socket A by using the /TIGERMP switch, you can access all available features. I will fully fix it in the next release, but fan speeds can already be smoothly changed - TYAN Tiger MP (S2460) AMD-760 MP Dual Socket A currently, it has been reported that the first PWM from the W83782D can change fan speed |
| Vue Rapide de la discussion |
