8756 connectés
Sujet : 2 tours avec un système de ventilation de malade
M@D_OVERCLOCKER That's a case just for fun ;)
« Posted 2001-12-16 17:23:11 ·· Author: MadOverclocker »
This case is just for people who are ready to pay that damn expensive price, that's something like 4 times the price I paid a while back for my AMK OCD-810 24"!!!! And for people who'll like to have an outstanding case. I've modded my OCD-810, first cuz the 810 CFM statement was wrong, it came with 4 120mm ADDA 108.4CFM instead of 120CFM Sunons on the left side of the case, at bottom front a 120mm ADDA instead of a Sunon, on top of the case one 120mm ADDA instead of a Sunon and a 80mm 30CFM Sunon, and finally 2 Sunons 80mm 30CFM on the top rear ; so the airflow was something like 200 CFM less than the total airflow stated by AMK. So I've ordered more powerfull fans to replace some of the fans, more grills, filters, and a lot of other things (I won't detail here all the mods I've done, I'll post a thread about that in the forums). But that's not important, what I wanted to say is that the noise generated by such cases is unstandable, the first days you think you'll get used to that jet engine sound, but finally you won't. And if ypu think it will allow you to overclock your CPU very high, you are wrong, the drop in temps is not that high. That's why I bought a DigitalDoc 3 and DigitalDoc 5 both 8 Channels and turned to WaterCooling, now the fans are just used to maintain the case temp and to help to down the temp a bit. I also want to say that the way AMK organize the airflow is not the best, I'm not going to explain that statement, zedri has already done it, but just say that ideal airflow organization is cold air blowed in on the bottom of the case and hot air blowed out at the top of the case, in pair with an equilibrated amount of air going in and air going out, which is not always easy to do, cuz you have to take in consideration what needs to be cooled and fans localisation. I can give an advice to people who'd like to have a such case : buy the case you'd like to have, buy the fans, grills, filters,....take a hole saw and do it yourself, it isn't too hard, and will save you a LOT of money!!!!;)
G trop la flemme de traduire :D
M@D_OVERCLOCKER
The NBo/c a écrit a écrit :
c vrai que je ne suis que a environ 450CFM honte a moi mais c autrement mieu répartit :p
idem ke ma réponse au post de rafthequaker.
M@D_OVERCLOCKER
RafTheQuaker a écrit a écrit :
:lol:  :lol:  :lol:
ouais c fun mais au bout de 2 jours on doit etre sourd nan ?
pour ce prix la je prefer prendre un kit WC noki.....
d'où mon commentaire sur la page de la review de la 1ère tour :D  ;)
The NBoc c vrai que je ne suis que a environ 450CFM honte a moi mais c autrement mieu répartit :p
The NBoc pitoyable c nul ma ventilation est mieu :na:
[DMA] JF moi je dis vive le vapo ;) vu le prix des ventilos on doit pas en etre loin :lol:
rafthequaker :lol:  :lol:  :lol:
shilinoana lolololololololol :lol:  :lol:  :lol:
Voxel "DO NOT PUT SMALL ANIMALS NEAR THIS CASE!"
http://www.icrontic.com/mm/Reviews [...] t2focz.jpg
"Your pet may end up in another dimension due to the wormhole effect or end up in a few other dimensions due to the fan blade effect. I wouldn't even put a large animal near this case."
:lol:  :lol:  :lol:
Enfin des reviews avec un peu d'humour :).
[edtdd]--Message édité par voxel--[/edtdd]
cpulloverclock
shilinoana a écrit a écrit :
bonne idée je vé appeler ma copine on va se faire une soiree tomb raider5 (pour lui faire plaisir counterstrike c pas sont truc)!!!! :D
[:gregmc] [:markdavis]
shilinoana
cpulloverclock a écrit a écrit :
ya un avantage c que ca te permet de rester seul dns la chambre si tu veux pas quon te fasse chier mais dun autre cote la copine  :eek2:
Magicpanda l'air cooling a encore de beau jours devant lui
ont pas encore tous avec des bassines
je croit que la solution a terme se rapprochera plus du vapochill ( propos ca fait du bruit ca?? desole, jamais vu en fonctionnement de mes yeux, mais deja ca refroidi...)
cpulloverclock ya un avantage c que ca te permet de rester seul dns la chambre si tu veux pas quon te fasse chier mais dun autre cote la copine  :eek2:
Aesthetics oui et 2000 db lol  :D  :lol:
M@D_OVERCLOCKER Personnellement, g une AMK OCD-810 modèle d'il y a à peu près un an et demi, ke g d'ailleurs moddée et à seulement un total de 961,7CFM :D  :pt1cable:  :lol:
Je posterai bientôt les photos. :D
shilinoana tien j ai mon cadeau pour noel PAPA!!!!!!!! :D
cpulloverclock c deja passe dns le forum mais bon yen a qui nont pas du voir
sur le site de noky elle av ete publie aussi cette news  :)
[edtdd]--Message édité par cpulloverclock--[/edtdd]
M@D_OVERCLOCKER Celle-ci avec pas moins de 1708CFM (Record Absolu) :  :pt1cable:
http://www.icrontic.com/mm/Reviews [...] ductws.jpg
La review est ICI
Et celle-là un peu plus soft avec seulement 674CFM :  :lol:
http://www.icrontic.com/mm/Reviews [...] wscase.jpg
La review est ICI
