8335 connectés
Sujet : [SOS] abit KT7a FLASHé (3C) est MORT ...
biour 1000L(ires) :D
efimo 401 Frs :hap:
topaz =
Comment on peut faire pour augmenter
le Voltage COre sur la KT7A, c'est quoi la modif
nicko500 400 [:olimou]
thieuma
KillerMan a écrit a écrit :
Je monte jusqu'à 300 francs pour son rachat !
350F :na:
topaz Ou on peut trouver le BIOS 3C pour la crate kt7a .???
PS : j'ai fait une belle FAQ sur le rodage
Killerman Je monte jusqu'à 300 francs pour son rachat !
Héhé
Lelio
thieuma a écrit a écrit :
 :lol: c clair....
c le lutin de la KT7A ki revient te flasher le bios
ABIT KT7A = lutin inside :D
:D :D :D Mouaaaaaaaaahhhhhhhh !!:D :D :D
TheNicow Nous sommes donc bien d'accord.
Bonne chance pour ton flashage...
chewie j'ai trouvé ça (c'est en anglais) :
I flashed my BIOS and now the machine is dead. What can I do?
If your BIOS appeared to flash properly, then you had one good reboot, but all subsequent reboots have left you with a blank screen, you most likely failed to use your one chance to reset the CPU speed from the default 500 MHz back to the proper clock setting.  This results in a machine that won't go.  You need to clear the CMOS and then immediately enter SoftMenuIII in the BIOS and set the correct CPU speed.
Otherwise, you have probably somehow corrupted your BIOS whilst flashing to the later version. If you are lucky, the boot-block BIOS will remain, which means you may be able to reflash your BIOS using a bootable floppy. Your screen may remain dead during this activity, and so you might have to guess when the process is finished (wait 5-10 minutes). You must do the following:
Create a bootable DOS floppy using Windows 95 or 98
Remove all memory management files from the floppy disk and AUTOEXEC.BAT
Download a new version of the BIOS file and copy to the floppy disk (don't use the version which killed your BIOS - it's probably corrupted!)
Download a new version of the AWDFLASH.EXE file and copy to the floppy disk
Add the line "AWDFLASH newbios.bin /py /cc /sn /cd" to the end of the AUTOEXEC.BAT file (where newbios.bin is the name of new BIOS file)
Power off your machine, insert the floppy, power up
After five-ten minutes, remove floppy and reboot!
Pims Si cette procedure marche alors c'est ce qu'il faut faire à CHAQUE FOIS !! c'est beaucoup plus securisé :eek:
Le vais tenter direct chez moi (meme si j'ai pas de pb)
chewie ok, thanx, je vais essayer tout ca ce soir ...
TheNicow Tout a fait, il va lire la diskette avant meme d'initialiser qoui que ce soit sur le PC, donc tu ne vas rien voir.
Tu laisse la touche Insert enfoncée, jusqu'à ce que tu vois le témoin de ton lecteur de diskette s'allumer (1 ou 2s au plus), la tu te rend compte que ca lie la diskette, et des que tu entends les bips, tu peux retirer la diskette et rebooter.
La tu peux faire direct un appuie sur DEL pour remettre le bios comme tu veux.
chewie mais t'es sur qu'il va lire la disquette au boot ?
J'ai l'écran qui reste en veille dès le boot ...
J'avais lu cette histoire des 4 blocs.
TheNicow Si tu as un autre PC sous la main, tu te crée une diskette de boot :
format a: /s
Tu mets sur la diskette le fichier du bios et un fichier autoexec.bat qui contient juste la ligne de commande du prog de flashage dans le genre :
awd???   monbios.bin
Tu redémarre le PC avec la diskette dedans en tenant enfoncé la touche Insert.
Normalement, tu dois voir qu'il lit sur la diskette. Des que tu entend 3 bips, le bios a été réecrit.
Et pour ceux qui pensent que ca ne peut pas marcher, et bien désolé, ca marche tres bien.
En fait, il existe dans le bios quelques secteurs qui ne sont pas modifiés par les mises à jour de bios et qui permettent justement cette petite restauration.
J'ai déjà eu à le faire, ca marche très bien.
La procédure est d'ailleurs décrite sur le site de MSI, et sur le site http://www.viahardware.com  dans la FAQ sur la KT7A
Bonne chance
chewie c vrai l'histoire de sortir la pile pendant +sieurs heures pour pouvoir rebooter en boot d'origine ?
The Manant Moi j'ai exactement ce pb qd j'essaye de changer le coef du TB alors que les pont l1 ne sont pas relié, ou que j'ai traffiqué ds la tour...
Mais chez moi il fait des bips et il suffit que je débranche le PC quelque minutes/démonte et remonte le CPU pour que ca marche
efimo bon si tu n'arrive à rien et que le SAV ne marche pas ben moi je te la rachete 200Frs  :D
chewie
faut juste verifier que le bios n'est pas soudé, c'est très fréquement le cas desormais sur les cartes récentes.
j'en sais rien, il doit être soudé ...
chewie
T as même pas un écran qui te demande un disquette de boot
Moi j avais fait la même connerie avec la Kt7A et j ai pu la reflasher en faisant un disquettte de boot !
non, rien. L'écran reste désespéremment éteint ...
thieuma
Nicko500 a écrit a écrit :
:lol: ouais g fé un copier collé a thieuma on s est bien marré :)  :pt1cable:
:lol: c clair....
Slyde faut juste verifier que le bios n'est pas soudé, c'est très fréquement le cas desormais sur les cartes récentes.
Chewie en ligne de commande uniquement y a encore des saloperies style emm386 qui peuvent être chargé en mêmoire.
De memoire le flashage à été presque immediat même a la fin. Donc que tu ai reseté ou pas n'aurait rien changé.
efimo Si tu connais kelk1 qui à la meme carte mere que toi, alors tu va chez lui avec ton eeprom mal flashé, lui va booté en mode dos seul, ensuite il retire son bios avec précaution et insert le tien et reflash le tout autant de fois qu'il le faudra à ton bon vouloir mais une fois suffit, puis reboot et si tout a été fait correctement no prob tout remarche, moi j'ai dejà fais cette manip trois fois et sa a toujours marché.
A toi de joué maintenant :sol:
pc2000 T as même pas un écran qui te demande un disquette de boot
Pims [:oo_oo]
nicko500 :lol: ouais g fé un copier collé a thieuma on s est bien marré :)  :pt1cable:
*kin*
Rincevent1 a écrit a écrit :
debranches ton alime, enleves la pile de ta carte mere, mets ton jumper sur clear cmos, attends 4 a 5 heures ton bios sera remplacés par un bios basique.
abit rulez
chewie T sur que ca marche le fait d'enlever la pile pendant 4 à 5 heures ??????
Rincevent1 debranches ton alime, enleves la pile de ta carte mere, mets ton jumper sur clear cmos, attends 4 a 5 heures ton bios sera remplacés par un bios basique.
abit rulez
chewie oui, moi aussi, j'ai utilisé le runme. Il a bloqué à 4 blocs avant la fin, j'ai attendu 5 mn, et j'ai reseté.
J'aurais peut-etre pas du ...
J'étais en mode DOS pur (ligne de commande avant le boot de windows 98)
Maintenant ca démarre plus
[edit]--Message édité par chewie--[/edit]
Slyde moi j'ai flashé le bios 3C sur la carte d'un pote, ca s'est très bien passé, j'ai juste fait gaffe a ce que rien ne soit chargé en mémoire et je suis revenu à la fréquence d'origine du proco. J'ai utilisé le runme ou un truc comme ca.
chewie
tu envoie tout ça à Morx France
c'est ou ? Adresse please ?
Comment on fait pour enlever son bios de la CM ? Ca se fait ?
chewie mais ca prend pas 15 mn à flasher un bios quand meme, si ?
Y avait ecrit au milieu de l'écran : 3C00000 OK, je me suis dit que la version 3C était installé ...
Green_Giant il est clair que si tu as fait un reset avant que le prog t'ai dit qu'il avait terminé, ton bios ne peut pas marcher!
dans ton malheur, t'as de la chance: si ton revendeur info vaut pas faire passer ta carte en SAV, tu prend ton bios, tu le met dans une jolie enveloppe protégée, et tu envoie tout ça à Morx France (revendeur officiel de ABIT en France), et il te répare ton joli petit bios!
@plus
Ps: c quand même pas malin d'arrêter un prog de flashage en cours de route!
chewie le truc bizarre, c'est que j'ai tous les périphériques qui marchent. Y a juste l'écran qui reste en veille.
Ca peut venir du proc ? Pourtant, tout marchait avant le flashage.
Qui à flashé sa CM avec la 3C ? Vous avez du faire un reset à la fin du flashage ?
chewie heureusement, je l'ai acheté mardi dernier, donc je vais pouvoir me le faire échanger (enfin, j'espère !).
Personne d'autre n'a eu ce genre de problèmes avec leur CM abit KT7a ?
ni_co la dernière fois que j'ai flashé j'ai du changer de carte mere... Enfin j'ai fait passer ca sur la garantie. A mon avis t'as eu un bug, et si tu redémarres pas tu risques pas de pouvoir reflasher...
chewie Salut à tous :
Hier soir, j'ai téléchargé le VIA 4in1 et je l'ai installé, ainsi que la version 3C du bios pour ma CM abit KT7a.
Je redémarre, et plus rien ... L'écran ne s'allume pas. Pourtant, tout marchait avant de flasher le bios.
D'ailleurs, quand je l'ai flashé, il me marquait 3C0000 OK (mais il n'était pas arrivé au bout des blocs blancs). J'ai fait un reset, et BLAM, ca marche plus.
J'aurais du attendre encore plus avant le reset ? J'ai vu dans le manuel que les 4 derniers blocs permettaient de faire une sorte de sauvegarde du dernier bios, et ils disent qu'il faut redémarrer avec une disquette systeme. Mais si déjà l'écran il s'allume pas ...
J'ai essayé le "Inser" au démarrage pour revenir à la config d'origine, j'ai vidé le CMOS, et j'ai enlevé la pile pour voir ...
HELPPPPPPPPPPPPPPPPPPPPPPPPPPP !
