4565 connectés
Sujet : CHERCHE PERSONNE POUR M AIDER CA SERAI COOL MERCI
flojess QUI VEUT DIRE
Baruckello JE CROIS QUE T AS PAS ASSEZ POSTE ET QU IL FAUDRAIT ENCORE dEUX OU TROIS POSTS
flojess :eek2: BORDELE JE NARRIVE PAS A ALLER PLUS LOIN QUE 115 FSB AVEC MA CARTE MERE GIGA BYTE 7ZX SERIES ET JE NE PEUX CHANGER DE COEF.
MEME AVEC SOFTFSB UNE/MA CARTE EST PAS DANS LA LISTE
                  DEUX/MON PLL N EST PAS DANS LA LISTE AUSSI
J AI RELIELES POINT L1 DU CPU AVEC DU REPARATEUR DE PISTE A L ARGENT
SOLUTION SOLUTION SOLUTION SOLUTION SOLUTION SOLUTION SOLUTION
