4078 connectés
Sujet : qq est monté au dessus de 119Mhz de FSB pour une KT7 ???
booba oui moi 120 sur ma KT7 personalisé (g viré le ventirad d'origine pour un mieux)
8.5*120 c le pied pour mon duron
risboc j arrive a 118 mais ct mon pross ki bridait  :)
Rayaki up !
Rayaki oups désolé j'ai laissé les benchs de ma config d'avant....
HWinfo32:
  AMD Duron - 954
  CPU Benchmark = 10188
  FPU Benchmark = 14460
  MMX Benchmark = 8638
  Memory Benchmark = 286 MBytes/s
Sandra 2001:
                AMD Duron Processor 950Mhz (estimated PR1264)
  CPU Benchmark (CPU Dhrystone) = 2668 MIPS
                (FPU Whestone) = 1285 MFLOPS
  CPU Multi-Media Benchmark (Integer MMX) = 5319 it/s
                            (floating-Point 3DNow! enh) = 6460 it/s
  Drives Benchmark (IBM UDMA100 14.3G - Drive index) = 22828
  Memory Benchmark (CPU/Memory Bandwidth) = 541MB/s
                   (FPU/Memory Bandwidth) = 613MB/s
CPUmark
  Score = 82.4
FPUmark
  Orbital = 11241.064
  Polygon = 4636.455
  3D Geometry = 4163.500
  Fourier = 5847.163
  Linear Equation = 9041.880
  AVERAGE = 5178.186
HDTach  Ramdom access time = 10.8 ms
  Read Burst Speed = 59.8 mbps
  Average = 32881.7 kps
  CPU utilization = 6.1%
Rayaki au fait, qq a une abit kt7A avec un Duron à 950Mhz, histoire que l'on puisse comparer les benchs pour voir ce qu'apporte le 133Mhz de FSB (cpumark-fpumark-HDtach-hwinfo32-sandra2001) ????
HWinfo32:
  AMD Duron - 929/954
  CPU Benchmark = 9899/10188
  FPU Benchmark = 14057/14460
  MMX Benchmark = 8383/8638
  Memory Benchmark = 254/286 MBytes/s
Sandra 2001:
                AMD Duron Processor 924/950Mhz (estimated PR1229/1264)
  CPU Benchmark (CPU Dhrystone) = 2587/2668 MIPS
                              (FPU Whestone) = 1249/1285 MFLOPS
  CPU Multi-Media Benchmark (Integer MMX) = 5168/5319 it/s
                                          (floating-Point 3DNow! enh) = 6274/6460 it/s
  Memory Benchmark (CPU/Memory Bandwidth) = 444/541MB/s
                                 (FPU/Memory Bandwidth) = 470/613MB/s
CPUmark
  Score = 77.9/82.4
FPUmark
  Orbital = 10914.582/11241.064
  Polygon = 4504.505/4636.455
  3D Geometry = 4044.118/4163.500
  Fourier = 5684.558/5847.163
  Linear Equation = 8783.887/9041.880
  AVERAGE = 5030.222/5178.186
HDTach  Ramdom access time = 10.7/10.8 ms
  Read Burst Speed = 59.7/59.8 mbps
  Average = 32840.4/32881.7 kps
  CPU utilization = 5.4/6.1%
Rayaki j'ai testé:
133Mhz: là c'est juste pour rire...la mobo a pas aimé et n'a pas voulu rebooter par la suite... hihihihihi
124Mhz: pas stable du tout
122Mhz: stable le temps de mes tests, j'ai lancé wintune, hdtach et cpumark pour voir... ben par rapport à 119Mhz, pas un iota d'amélioration (en fait, j'ai meme du descendre le coef d'un cran sinon mon 650 demarrait à plus de 1ghz, et là il aime pas du tout !)
donc je reste à 119Mhz de FSB !
là j'ai cpu/chipset: 34°c/19°c ça me va !
moyen_moins perso max a 119 et pas tres stable
118 stable
[edit]--Message édité par moyen_moins--[/edit]
Rayaki j'essai ça et je donne la reponse dans qq minutes (ou heures)
moyen_moins popgael à 120MHz stable sur sa kt7 il me semble
a verifier
keyzer93 euh moi 115 pour l'instant ca me convient avec les param bios de la ram optimisés a donf
j'ai po essayé + haut
kelkun est passé a 122/123 stable parait il
Rayaki tout est dans le titre !
pour le moment, je tourne à 119mhz de FSB stable !
peut ton monter au dessus en restant stable ??
