3543 connectés
  Quel es le stepping de votre P4
n°645858
steve_tho
Posté le 07-11-2002 à 18:32:03  profilanswer
    Package
 Core L2 Cache  Speed and
S-Spec Stepping Size (bytes) CPUID Core/Bus
SL4QD B2 256K OF07h 1.30GHzl400MHz 31.0 mm 001
     rev 1.0
SL4SF B2 256K OF07h 1.30GHzl400MHz 31.0 mm 001 3
     rev 1.0
SL4SG B2 256K OF07h 1.40GHzl400MHz 31.0 mm 001
     rev 1.0
SL4SC B2 256K OF07h 1.40GHzl400MHz 31.0 mm 001
     rev 1.0
SL4SH B2 256K OF07h 1.50GHzl400MHz 31.0 mm 001
     rev 1.0
SL4TY B2 256K OF07h 1.50GHzl400MHz 31.0 mm 001
     rev 1.0
SL5FW C1 256K OFOAh 1.30GHzl400MHz 31.0 mm 001 3
     rev 1.0
SL4WS C1 256K OFOAh 1.40GHzl400MHz 31.0 mm 001 3
     rev 1.0
SL4WT C1 256K OFOAh 1.50GHzl400MHz 31.0 mm 001 3
     rev 1.0
SL4WU C1 256K OFOAh 1.60GHzl400MHz 31.0 mm 001 3
     rev 1.0
SL57W C1 256K OFOAh 1.7GHzl400MHz 31.0 mm 001
     rev 1.0
SL4WV C1 256K OFOAh 1.80GHzl400MHz 31.0 mm 001 3
     rev 1.0
SL5GC C1 256K OFOAh 1.30GHzl400MHz 31.0 mm 001
     rev 1.0
SL4X2 C1 256K OFOAh 1.40GHzl400MHz 31.0 mm 001
     rev 1.0
SL4X3 C1 256K OFOAh 1.50GHzl400MHz 31.0 mm 001
     rev 1.0
SL4X4 C1 256K OFOAh 1.60GHzl400MHz 31.0 mm 001
     rev 1.0
SL57V C1 256K OFOAh 1.70GHzl400MHz 31.0 mm 001
     rev 1.0
SL4X5 C1 256K OFOAh 1.80GHzl400MHz 31.0 mm 001
     rev 1.0
SL5SX DO 256K OF12h 1.50GHzf400MHz 31.0 mm FC 3
     rev 1.0
SL5VL DO 256K OF12h 1.60GHzl400MHz 31.0 mm FC 3
     rev 1.0
SL5SY DO 256K OF12h 1.70GHzl400MHz 31.0 mm FC 3
     rev 1.0
     Package
S-Spec Stepping Size (bytes) CPUID Core/Bus Revision Notes
SL5VM DO 256K OF12h 1.80GHzf400MHz 31.0 mm FC 3
     rev 1.0
SL5VN DO 256K OF12h 1.90GHzf400MHz 31.0 mm FC 3
     rev 1.0
SL5SZ DO 256K OF12h 2GHzf400MHz 31.0 mm FC 3
     rev 1.0
SL5UL DO 256K OF12h 1.60GHzf400MHz 31.0 mm 001
     rev 1.0
SL5VM DO 256K OF12h 1.80GHzf400MHz 31.0 mm 001    rev 1.0
SL5WH DO 256K OF12h 1.90GHzf400MHz 31.0 mm 001
     rev 1.0
SL5TQ DO 256K OF12h 2GHzf400MHz 31.0 mm 001
     rev 1.0
SL59U C1 256K OFOAh 1.40GHzf400Mhz 31.0 mm FC
     rev 1.0
SL59V C1 256K OFOAh 1.50GHzf400Mhz 31.0 mm FC 4
     rev 1.0
SL5US C1 256K OFOAh 1.60GHzf400MHz 31.0 mm FC 4
     rev 1.0
SL59X C1 256K OFOAh 1.70GHzf400Mhz 31.0 mm FC 4
     rev 1.0
SL5UT C1 256K OFOAh 1.80GHzf400MHz 31.0 mm FC 4
     rev 1.0
SL5VK DO 256K OF12h 1.90GHzf400MHz 31.0 mm FC 4
     rev 1.0
SL5TG DO 256K OF12h 1.40GHzf400MHz 31.0 mm FC
     rev 1.0
SL5TJ DO 256K OF12h 1.50GHzf400MHz 31.0 mm FC
     rev 1.0
SL5VH DO 256K OF12h 1.60GHz/400MHz 31.0 mm FC
     rev 1.0
SL5TK DO 256K OF12h 1.70GHzf400MHz 31.0 mm FC
     rev 1.0
SL5VJ DO 256K OF12h 1.80GHzf400MHz 31.0 mm FC
   rev 1.0
     rev 1.0
SL5TL DO 256K OF12h 2GHzf400MHz 31.0 mm FC 4
     rev 1.0
SL5N7 C1 256K 0 FOAh 1.40GHzf400MHz 31.0 mm FC    rev 1.0
     Package
SL5N8 C1 256K OFOAh 1.50GHzl400MHz 31.0 mm FC     rev 1.0
SL5UW C1 256K OFOAh 1.60GHz/400MHz 31.0 mm FC
     rev 1.0
SL5N9 C1 256K OFOAh 1.70GHzl400MHz 31.0 mm FC
     rev 1.0
SL5UV C1 256K OFOAh 1.80GHzl400MHz 31.0 mm FC
     rev 1.0
SL5UE DO 256K OF12h 1.40GHzl400MHz 31.0 mm FC
     rev 1.0
SL5UF DO 256K OF12h 1.50GHzl400MHz 31.0 mm FC
     rev 1.0
SL62Y DO 256K OF12h 1.50GHzl400MHz 31.0 mm FC
     rev 1.0
SL5UJ DO 256K OF12h 1.60GHzl400MHz 31.0 mm FC    rev 1.0
SL5UG DO 256K OF12h 1.70GHzl400MHz 31.0 mm FC
     rev 1.0
SL62Z DO 256K OF12h 1.70GHzl400MHz 31.0 mm FC
     rev 1.0
SL5UK DO 256K OF12h 1.80GHzl400MHz 31.0 mm FC    rev 1.0
SL5WG DO 256K OF12h 1.90GHzl400MHz 31.0 mm FC
     rev 1.0
SL668 BO 512K OF24 1.60GHzl400MHz 31.0 mm FC
     rev 1.0
SL63X BO 512K OF24 1.80GHzl400MHz 31.0 mm FC
     rev 1.0
SL62P BO 512K OF24 1.80GHzl400MHz 31.0 mm FC
     rev 1.0
SL68Q BO 512K OF24 1.80GHzl400MHz 31.0 mm FC
     rev 1.0
SL68R BO 512K OF24 2GHzl400MHz 31.0 mm FC
     rev 1.0
SL5YR BO 512K OF24 2GHzl400MHz 31.0 mm FC     rev 1.0
SL5YS BO 512K OF24 2.20GHzl400MHz 31.0 mm FC
     rev 1.0
SL68S BO 512K OF24 2.20GHzl400MHz 31.0 mm FC
     rev 1.0
SL68T BO 512K OF24 2.40GHz/400MHz 31.0 mm FC
     rev 1.0
        Package
SL5ZU  BO  512K  OF24 2.20GHzl400MHz 31.0 mm FC 1,5
        rev 1.0
SL65R 1 BO 1 512K 1 OF24 12.40GHzl400MHzl 31.0mmFC 1 2,5
        rev 1.0
SL67R 1 BO 1 512K 1 OF24 12.40GHzl400MHzl 31.0 mm FC 1 1,5
        rev 1.0
SL683 1 BO 1 512K 1 OF24 12.26GHzl533MHzl 31.0 mm FC 1 1,5
        rev 1.0
SL67Y 1 BO  512K  OF24 2.26GHzl533MHz 31.0 mm FC 1 2,5
        rev 1.0
SL684 1 BO  512K  OF24 2.40GHzl533MHz 31.0 mm FC 1 1,5
        rev 1.0
SL67Z 1 BO 1 512K 1 OF24 12.40GHzl533MHzl 31.0mmFC 1 2,5
        rev 1.0
SL685 1 BO 1 512K 1 OF24 12.53GHzl533MHzl 31.0 mm FC 1 1,5
        rev 1.0
SL682 1 BO  512K  OF24 2. 53GHzl533MHz 31.0 mm FC 1 2,5
        rev 1.0
SL6HL 1 C1  512K  OF27 2.80GHzl533Mhz 31.0mm FC 1 5
        rev 1.0
SL6K6 1 C1 1 512K 1 OF27 12.80GHzl533Mhz 1 31.0 mm FC 1 1,5
        rev 1.0
n°645862
Hr
ㅤㅤㅤㅤㅤㅤㅤㅤㅤㅤㅤㅤㅤㅤㅤ
Posté le 07-11-2002 à 18:32:55  profilanswer
Topic unique sur les P4, merci.
stepping de 1800+ ca vaut koi celui la ? plutot pas mal nan?est ce que cet athlon tb a un bon stepping??
Overcloking P4 stepping C-1 - Le meilleur choix : FSB 400 ou FSB 533 ?Stepping Athlon XP
Nikopop, ton stepping de Pékat 1.6A C lequel? il monte bien à 2.6 non?stepping dudu
stepping Athlon 1333Mhzsite stepping athlon
A cas quoi correspond le stepping d'un proco ???Ca change koi le stepping d'un proc ?
Plus de sujets relatifs à : Quel es le stepping de votre P4
