3850 connectés
  CPU
  Q9650 : En route vers les 4.4 Ghz !
 Page :   1  2  3
Page Précédente
n°2104407
Logicsyste​m360
Posté le 25-03-2011 à 12:43:55  profilanswer
Ce post reunit les screens :jap:
  • Le BIOS :
Profil 4 Ghz :
Validation CPU-Z
http://valid.canardpc.com/show_oc.php?id=1785790
█► > ASUS Maximus II Formula Rev. 1.02g (BIOS 2302)
      > Q9650 E0 (Batch : L009B452 et VID 1.2125V)
      > Dominator PC8500 2*2 Go
      > Windows 7 64 bits
█► Protocole = > OCCT (2h Méduim Data Set)
               > Prime 95 (2h)
               > LinX (50 Minutes)
               > Furmark (1h)
               > Memtest (All Memory)
               > HyperPI et SuperPI (32M : Score = ... sec )
               > 3Dmark Vantage (Score = ... points)
█        Extreme Tweaker          █
█► Ratio CMOS Setting ..........> 9
█► FSB Frequency ...............> 445
█► CPU Clock Skew ..............> Delay 100ps
█► NB Clock Skew ...............> Delay 100ps
█► FSB Strap to North Bridge ...> 333
█► DRAM Frequency ..............> 1069
█► DRAM Clock Skew CH1 A1 ......> Normal
█► DRAM Clock Skew CH1 A2 ......> Normal
█► DRAM Clock Skew CH1 B1 ......> Normal
█► DRAM Clock Skew CH1 B2 ......> Normal
█► DRAM Timing Control .........> Manual
█► CAS# Latency ................> 5
█► RAS# to CAS# Delay ..........> 5
█► RAS# Precharge ..............> 5
█► RAS# Activate Time ..........> 16
█► RAS# to RAS# Delay ..........> 3
█► Row Refresh Cycle Time ......> 55
█► Write Recovery Time .........> 6
█► Read to Precharge Time ......> 3
█► Read to Write Delay (S/D) ...> 8
█► Write to Read Delay (S) .....> 3
█► Write to Read Delay (D) .....> 5
█► Read to Read Delay (S) ......> 4
█► Read to Read Delay (D) ......> 6
█► Write to Write Delay (S) ....> 4
█► Write to Write Delay (D) ....> 7
█► Write to PRE Delay ..........> 14
█► Read to PRE Delay ...........> 5
█► PRE to PRE Delay ............> 1
█► ALL PRE to ACT Delay ........> 6
█► ALL PRE to REF Delay ........> 6
█► DRAM Static Read Control ....> Disabled
█► Dram Read Training ..........> Disabled
█► MEM OC Charger ..............> Enabled
█► Ai Clock Twister ............> Moderate
█► AI Transaction Booster ......> Manual
█► Common Performance Level ....> 09
█► Pull-In of CHA PH1 ..........> Disabled
█► Pull-In of CHA PH2 ..........> Disabled
█► Pull-In of CHA PH3 ..........> Disabled
█► Pull-In of CHA PH4 ..........> Disabled
█► Pull-In of CHA PH5 ..........> Disabled
█► Pull-In of CHB PH1 ..........> Disabled
█► Pull-In of CHB PH2 ..........> Disabled
█► Pull-In of CHB PH3 ..........> Disabled
█► Pull-In of CHB PH4 ..........> Disabled
█► Pull-In of CHB PH5 ..........> Disabled
█► PCIE Frequency ..............> 100
█► CPU Voltage .................> 1.2125
█► CPU PLL Voltage .............> 1.53
█► FSB Termination Voltage .....> 1.29
█► DRAM Voltage ................> 1.99
█► North Bridge Voltage ........> 1.35
█► South Bridge Voltage 1.5 ....> 1.51
█► South Bridge Voltage 1.1 ....> 1.12
█► CPU GTL Reference 0 .........> Auto
█► CPU GTL Reference 1 .........> -10 mV
█► CPU GTL Reference 2 .........> Auto
█► CPU GTL Reference 3 .........> -10 mV
█► NB GTL Reference ............> +70 mV
█► DDR2 Channel A REF Voltage ..> Auto
█► DDR2 Channel B REF Voltage ..> Auto
█► NB DDR Reference ............> Auto
  • Les screens
OCCT (2h Médium data Set)
http://img26.imageshack.us/img26/8341/occt4ghz.png
http://img709.imageshack.us/img709/6467/2011042509h41cpuusage.pnghttp://img822.imageshack.us/img822/6010/2011042509h41memoryused.png
http://img251.imageshack.us/img251/1158/2011042509h41tcc11.pnghttp://img251.imageshack.us/img251/2144/2011042509h41tcc12.png
http://img163.imageshack.us/img163/1832/2011042509h41tcc13.pnghttp://img132.imageshack.us/img132/2328/2011042509h41tcc14.png
http://img717.imageshack.us/img717/1279/2011042509h41tmobo.pnghttp://img543.imageshack.us/img543/5687/2011042509h41tnb.png
http://img576.imageshack.us/img576/4396/2011042509h41topt2.pnghttp://img862.imageshack.us/img862/2117/2011042509h41tsb.png
http://img193.imageshack.us/img193/8070/2011042509h41v33v.pnghttp://img18.imageshack.us/img18/1716/2011042509h41vcpu.png
http://img15.imageshack.us/img15/8503/2011042509h41vcpupll.pnghttp://img20.imageshack.us/img20/3521/2011042509h41vcpuvtt.png
http://img847.imageshack.us/img847/820/2011042509h41vdimm.pnghttp://img197.imageshack.us/img197/2079/2011042509h41vnb11v.png
http://img828.imageshack.us/img828/5597/2011042509h41vp5v.pnghttp://img38.imageshack.us/img38/231/2011042509h41vp12v.png
http://img824.imageshack.us/img824/2843/2011042509h41vsb11v.pnghttp://img821.imageshack.us/img821/5898/2011042509h41vsb15v.png
Prime 95 (2h)
http://img52.imageshack.us/img52/82/prime954ghz.png
LinX (50 Minutes)
http://img852.imageshack.us/img852/4474/linx4ghz.png
Message édité par Logicsystem360 le 25-04-2011 à 11:15:44
n°2104429
Posté le 25-03-2011 à 14:38:04  answer
Baisse ton VNB
Avec 2 barrettes synchros + timings relâchés, ce n'est en aucun cas utile
Ton VTT est largement trop haut
Limite dangereux pour ton CPU sur le long terme
Je rappelle qu'il est déconseillé de dépasser 1.36V & 1.4V uniquement pour screen...
n°2104460
Logicsyste​m360
Posté le 25-03-2011 à 15:21:27  profilanswer
J'ai mis actuellement 1.40, ça me parait bien (et suivant le test de jmax hardware c'est une bonne tension qui devrait pas limiter)
par contre pour le VTT tu parle du CPU ? j'ai pas trouvé ou le regler ...
n°2104461
Posté le 25-03-2011 à 15:22:08  answer
n°2104462
Logicsyste​m360
Posté le 25-03-2011 à 15:22:46  profilanswer
Donc VTT CPU = vFSB ? :o
n°2104463
Posté le 25-03-2011 à 15:23:14  answer
Un peu vi [:zaib3k]
n°2104466
Logicsyste​m360
Posté le 25-03-2011 à 15:24:58  profilanswer
Rien de grave alors :D
J'ai plus qu'a régler mes GTL pour le 500 mhz au FSB et c'est bon ! (à priori :whistle: )
n°2104467
Posté le 25-03-2011 à 15:29:16  answer
Si tu veux screener, place qu'une seule barrette
Ça marchera mieux :o
n°2104474
Posté le 25-03-2011 à 15:35:42  answer
Euh, sinon pour la stabilité (!= screen), c'est le NB GTL :jap:
Lui c'est par tatonnement qu'on le détermine...
Perso, il m'a fallu bien 1 semaine (tests compris) pour stabiliser ;)
Message édité par Profil supprimé le 25-03-2011 à 15:38:54
n°2104475
Posté le 25-03-2011 à 15:37:51  answer
Posté le 25-03-2011 à 15:37:51  profilanswer
n°2104478
Logicsyste​m360
Posté le 25-03-2011 à 15:41:08  profilanswer
Selon toi, à 500 Mhz de FSB il me faut combien de vFSB ?
n°2104482
Posté le 25-03-2011 à 15:46:44  answer
J'en sais rien, ça dépend de la tension nécessaire au chipset pour y monter...
A régler avant, avec son GTL associé :jap:
EDIT: nettement moins qu'1.51V en tous cas :o!
Le VTT lui sera en dessous d'1.38V, quasi surement ;)
A condition de bien régler ses GTL associés :jap:
Message édité par Profil supprimé le 25-03-2011 à 15:48:06
n°2107588
Sweeper
Chi va piano, va sano...
Posté le 03-04-2011 à 14:05:46  profilanswer
@ Logicsystem360
Un autre lien utile, cet autre et cet autre pour une meilleure compréhension.
Bon O/C!
Coucou Maître BIERMAN  :)
E va lontano... Enfin on verra ^^
n°2107590
Posté le 03-04-2011 à 14:11:09  answer
Salut Sweeper
On attend encore mais le 500 ne vient pas
Viendra-t'il un jour, ça...
Moi j'ai tranché, même si possible d'y aller, c'est useless :jap:
n°2107594
Sweeper
Posté le 03-04-2011 à 14:17:47  profilanswer
CQFD  :hello:
n°2107746
Logicsyste​m360
Posté le 03-04-2011 à 22:18:25  profilanswer
Merci mais je cherche à stabiliser mon NB, qui reste très problématique.
Je mets 1.5 ou 1.6 ça change rien, tout les autres voltages idem.
J'ai beau à toucher à tout ça plante l'oCCT
Message édité par Logicsystem360 le 03-04-2011 à 22:19:18
n°2107748
Posté le 03-04-2011 à 22:26:04  answer
Limite-toi à quelque chose de raisonnable
Tu en sortiras grandi ;)
n°2108023
pvhk
lord Vader
Posté le 04-04-2011 à 19:54:14  profilanswer
taper 500 de fsb avec la MIIF, va falloir s'accrocher!!!
mon q9650 est @4.41ghz rock stable en fsb@490 sur cette mobo en air! :)
Message édité par pvhk le 04-04-2011 à 19:54:37
Topic unique-monter un PC matx à base de C2D: petit mais costaud
n°2108029
Logicsyste​m360
Posté le 04-04-2011 à 19:58:04  profilanswer
Ca va pour le moment.
Il demande combien de Vcore à 4.4 Ghz ton CPU ?
Et la question qui tue la mort : ton VID ?  :pt1cable:
n°2108038
pvhk
lord Vader
Posté le 04-04-2011 à 20:04:17  profilanswer
vid 1.1875
1.368v réel pour 4.41ghz!
Message édité par pvhk le 04-04-2011 à 20:04:51
n°2108040
Logicsyste​m360
Posté le 04-04-2011 à 20:07:38  profilanswer
pvhk a écrit :
vid 1.1875
1.376v réel pour 4.41ghz!
Spa vrai [:fegafobobos:4]
Un meilleur VID que moi [:korner:1]  [:gabuzaumeu]  [:deouss]  [:gillesimonenrage]  [:novaklerageux:2]  [:velasquez:3]  [:fegafobobos:2]
Tu le vends pas par hasard ?  :whistle: ²
Ca me parait un peu haut ce Vcore, moi j'ai l'impression que mon 4.5 Ghz va passer nikel à 1.4
n°2108045
pvhk
lord Vader
Posté le 04-04-2011 à 20:12:10  profilanswer
si tu passes 500 de fsb sur M2F:  :jap:
c 'est plutôt l'apanage des bonnes gigabyte p45
n°2108085
syu63
Posté le 04-04-2011 à 21:09:36  profilanswer
Logicsystem360 a écrit :
Ca me parait un peu haut ce Vcore, moi j'ai l'impression que mon 4.5 Ghz va passer nikel à 1.4 (et 3v au NB)
 :lol:  :lol:  :lol:
n°2108193
Posté le 05-04-2011 à 00:40:27  answer
Je t'avais dit que ça existait :ange:
Son Q9650 je sais pas mais, la "bonne GIGABYTE P45", ça j'ai
Qui a peu servi et n'a pas été brusquée
Juste qu'elle a un peu plus de mal que la Miif avec 8 gigos
Sinon elle n'a pas connu ce Q9550 qui est le mien, dommage ;)...
true :whistle:
n°2108485
Logicsyste​m360
Posté le 05-04-2011 à 20:06:15  profilanswer
Je vais avoir du mal, j'ai l'impression.
Je vois pas d’où l'instabilité pourrait venir, je teste & toujours
n°2108937
Logicsyste​m360
Posté le 06-04-2011 à 19:36:02  profilanswer
Si vous avez des liens amenant vers des OC à 500 Mhz FSB sur MIIF et autre Asus en P45, je suis preneur :jap:
n°2108946
Posté le 06-04-2011 à 20:09:37  answer
On en parle beaucoup, sur cette page => http://www.xtremesystems.org/forum [...] 2&page=172
& globalement sur l'ensemble de ce sujet
Des settings, captures etc. sont présents en quantité
Il faut les chercher :jap:...
Message édité par Profil supprimé le 06-04-2011 à 20:09:58
n°2108962
Logicsyste​m360
Posté le 06-04-2011 à 20:47:55  profilanswer
Je suis sur la voie des paramètres stables :love: :jap:
n°2108977
Logicsyste​m360
Posté le 06-04-2011 à 21:13:40  profilanswer
Et puis j'ai décidé de revoir à la baisse hausse l'OC :whistle:
http://img5.imageshack.us/img5/7604/4641.png
:whistle:
Message édité par Logicsystem360 le 25-04-2011 à 11:06:37
n°2108981
Posté le 06-04-2011 à 21:22:35  answer
Fais gaffe, c'était pas sympa pour les voisins http://www.dhnet.be/pictures_news/art_103631.gif
n°2109023
Logicsyste​m360
Posté le 06-04-2011 à 22:28:27  profilanswer
Han je viens de m'apercevoir que mon instabilité venait de mon SB qui avait pas assez de voltages  [:prozac]
n°2109024
Posté le 06-04-2011 à 22:29:13  answer
Oui oui [:tachyon]
n°2109041
syu63
Posté le 06-04-2011 à 22:59:38  profilanswer
Tu sais que tu vas avoir la mort dans un mois quand ton CPU aura grillé ? Ou ta CM ? Ou les 2 ? :D
n°2109063
Logicsyste​m360
Posté le 07-04-2011 à 02:00:32  profilanswer
Nan vous avez pas cru quand même :o
C'est un bug d'oCCT
Sinon pour les amateurs :
Vola le BIOS tel qu'il est en ce moment pour atteindre le 10 minutes sous OCCT
Message édité par Logicsystem360 le 25-04-2011 à 11:06:25
n°2109163
Posté le 07-04-2011 à 13:35:11  answer
Chipset en karton [:fredmoul:1]
Elle est sympa la présentation hein
http://forum.hardware.fr/hfr/Hardw [...] m#t7542277 :o
Message édité par Profil supprimé le 07-04-2011 à 13:36:54
n°2109179
Logicsyste​m360
Posté le 07-04-2011 à 15:09:20  profilanswer
Selon notre BIERMAN, le strap 400 consomme plus de tension au vNB je tends à penser le contraire :o
n°2109182
Posté le 07-04-2011 à 15:15:40  answer
:non:
J'ai dit:
qu'en baissant le strap (333->400), le PL (8->15) le ratio (5:6->1:1) et la quantité de mémoire (8->4), on pouvait baisser énormément la tension du P45
J'ai également fait part des Step/VID uniques de chaque puce P45
Que compte-tenu de tout ça, mon système a besoin de moins de tension que le sien :jap:
n°2109183
Logicsyste​m360
Posté le 07-04-2011 à 15:17:10  profilanswer
Donc je dois mettre quel strap ?
n°2109184
Posté le 07-04-2011 à 15:19:26  answer
333 bien sûr
Le PL de 15 @500 MHz est totalement surévalué
Je dirais 10 maxi. (je n'ai plus la formule de calcul :o)
Mais ce n'est pas ça qui fera baisser la tension nécessaire...
Message édité par Profil supprimé le 07-04-2011 à 15:20:09
n°2109186
Logicsyste​m360
Posté le 07-04-2011 à 15:22:53  profilanswer
Mais la ratio c'est mort la RAM monte pas sinon même en OC  [:cosmoschtroumpf]
 Page :   1  2  3
Page Précédente
  CPU
O/C Q9650 sur P5WDG2 WS PROProbleme oc E6750 3.8 Ghz sur une..... P5N-D (VDM??^^)
OC Q9650 Stable ?[Résolu] i7 950 @3.8 GHz - obligé de faire un reset à chaque démarrage
overclock i5 760 3,6 GhzVers un PC plus calme
Besoin d'aide Overclocking Q9650 Rev.E0Oc d'un Intel Core 2 Quad Q9650 déjà à 3.8GHz
[Aide] i7 860 @ 3.5 GhzQue pensez-vous de cet OC? i5 750 @4 GHz
Plus de sujets relatifs à : Q9650 : En route vers les 4.4 Ghz !
