3374 connectés
  CPU
  vos O/C sur P5Q Deluxe
n°1818041
scarcore
Posté le 19-11-2008 à 11:31:07  profilanswer
Voilà j'aimerais créer un p'tit topic afin de voir quelle sont vos réglages de votre P5Q Deluxe afin de profitez au mieux de vos O/C.
Voici mon bios pour mon E8500 E0 à 4.531Ghz en mode H24 pour l'instant (36° idle, 62° full).
CPU Ratio Setting: 8.5
FSB Strap to North Bridge: 333
PCI-E Frequency: 101
DRAM Frequency: DD2-1068
DRAM CLK Skew on Channel A1: AUTO
DRAM CLK Skew on Channel A2: AUTO
DRAM CLK Skew on Channel B1: AUTO
DRAM CLK Skew on Channel B2: AUTO
DRAM Timing Control: Manuel
1st Information :
CAS# Latency: AUTO
DRAM RAS# to CAS# Delay: AUTO
DRAM RAS# Precharge: AUTO
DRAM RAS# Activate to Precharge: AUTO
RAS# to RAS# Delay : AUTO
Row Refresh Cycle Time: 55
Write Recovery Time: AUTO
Read to Precharge Time: AUTO
2nd Information :
READ to WRITE Delay (S/D): AUTO
Write to Read Delay (S): AUTO
WRITE to READ Delay (D): AUTO
READ to READ Delay (S): AUTO
READ to READ Delay (D): AUTO
WRITE to WRITE Delay (S): AUTO
WRITE to WRITE Delay (D): AUTO
3rd Information :
WRITE to PRE Delay: AUTO
READ to PRE Delay: AUTO
PRE to PRE Delay: AUTO
ALL PRE to ACT Delay: AUTO
ALL PRE to REF Delay: AUTO
DRAM Static Read Control: Disable
DRAM Read Training: Disable
MEM. OC Charger: Enabled
AI Clock Twister: Lighter
AI Transaction Booster: Manual
Common Performance Level [5] : 10
CPU Voltage: 1.43125 = 1.424
CPU GTL Voltage Reference (0/2): AUTO (si je mets en standard: 0.63 Vista ne se lance pas)
CPU GTL Voltage Reference (1/3): AUTO (pareil)
CPU PLL Voltage: 1,58
FSB Termination Voltage: 1,26
DRAM Voltage: 2.10
NB Voltage: 1,28
NB GTL Reference: AUTO
SBridge Voltage: 1.10
PCIE SATA Voltage: 1.50
Load Line Calibration: Enabled
CPU Spread Spectrum: Disabled
PCIE Spread Spectrum: Disabled
CPU Clock Skew : Normal
NB Clock Skew : Normal
CPU Margin Enhancement: Optimized
Advance CPU Settings: All Disabled
Par contre parfois j'ai des programmes qui se figent quelques secondes (windows mail par ex), est-ce que mes tensions NB/SB seraient-elles trop faibles?
Message édité par scarcore le 19-11-2008 à 13:56:16
n°1818125
scarcore
Posté le 19-11-2008 à 13:56:23  profilanswer
http://images2.hiboox.com/images/4708/41bbd746883922df8fcdbbd2598f5129.jpg
n°1976562
Eclat d'om​bre
Why not?
Posté le 27-01-2010 à 17:43:17  profilanswer
Pardon, mais je déterre [:theorie des lavabos]
Si d'autres personnes pouvaient partager leur O/C sur P5Q Dlx [:tsomi:4]
  CPU
PCIE Frequency sur P5QOC E8500 Rev E0 sur ma P5Q DELUXE help réglages poussés BIOS
Aide pour O/C q6600 , P43 ... svpo/c E8x00 C0 ou E0 sur P5Q tout modèle
Overclocking ASUS P5E3 Deluxe Wifi AP_MyMacCube_ C'est partie pour une grosse modif
O/C affiché à -27% dans OCCT...
Plus de sujets relatifs à : vos O/C sur P5Q Deluxe
