8767 connectés
 Page :   1  2  3  4  5  ..  20  21  22  23  24  25
[ FOR OVERCLOCKERS FOUS ] ?¤¤ salon des habitués ¤¤?
n°550277
MEI
|DarthPingoo(tm)|
Posté le 11-07-2002 à 10:28:40  profilanswer
des infos sur l'EPoX EP-8K5A2+ ... ??? ca a l'air de rocks... ;)
enfins dommage qu'AMD me fasse plus tripper :)
n°550279
cpulloverc​lock
Posté le 11-07-2002 à 10:30:03  profilanswer
tu changeras davis bientot
sinon si ja passais au P4 avec un 2.8GHz ca serait une P4T533-C et de la Pc1066
histoire detre a 175*21
n°550284
MEI
|DarthPingoo(tm)|
Posté le 11-07-2002 à 10:31:42  profilanswer
Hehe... moi je reste en DDR, car le Granite Bay va pulvériser le i850E...
ABIT prevois la DDR333 Dual Channel soit 5400 de bande passante ;)
Donc autant commencer a avoir de la DDR...
n°550285
nikopop
凸(`0´)凸
Posté le 11-07-2002 à 10:33:04  profilanswer
[:yaisse]
granite bay et P4X600
Votre Installation Home-Cinema ici : installations-home-cinema.eu
n°550286
cpulloverc​lock
Posté le 11-07-2002 à 10:33:29  profilanswer
ouaip
mais je vise plus un Barton en f
n°550291
cpulloverc​lock
Posté le 11-07-2002 à 10:36:00  profilanswer
EP-8K5A2+ Press release ....
Jul. 8th, 2002, Taipei, Taiwan (R.O.C.) ? The progress of PC is nonstop. DDR333 became the mainstream, and USB2.0 steps up as a necessity. To meet this trend, VIA introduces its newest super south bridge-VT8235. VT8235 supports USB2.0 and 8X V-link, and Ethernet Mac that enriches the specification of KT333 chipset.
EPoX?s newest EP-8K5A2+ is based on KT333 chipset paired with VT8235 in south bridge. It offers the features that everyone has been long waiting for, the USB 2.0 and built-in LAN connector. This 8K5A2+ has one the highest specifications among all the KT333 mainboards currently available in the market.
The Boldest Specifications:
EP-8K5A2+ is designed support the newest AMD Socket A processor. It features 3 PC 2700 DDR memory slots, up to 3GB of memories, 6 PCI slots, 1 4X AGP, built in 6-channel audio, USB 2.0 on SB, EPoX?s onboard debugger post card, 2 extra IDE ports by High Point 372 and 10/100MB fast Ethernet controller in chipset with external VIA VT6103 physical Layer by RJ-45 connector.
Fastest Overclocking Capabilities:
EPoX is well known for its capabilities to consistently produce overclocking and stable mainboards over the years. EPoX tradition is once again proven with its newest EP-8K5A2+ mainboard. With its target intended for the High End Performance PC market, it also delivers superb over-clocking abilities for the gamers by having both adjustable CPU Vcore and CPU Clock functions. EPoX has also made both the memory and AGP voltage to be adjustable for users? enjoyment. In addition to boost up performance, EPoX also consider the safety for the pricey computer equipment. EPoX?s newest system monitoring function "Magic Health" will show you the vital signs of the system?s main components, which can help you manage the computer system accurately.
Added Value Functions:
The EP 8K5A2+ is built with the High Point 372 chip, which supports IDE RAID 0, 1, 0+1 to enable the hard disks backup and increases performance. To improve the efficiency of installation, EPoX 2 digit debug LED enable users to diagnose and correct any installation error quickly and efficiently
n°550293
MEI
|DarthPingoo(tm)|
Posté le 11-07-2002 à 10:38:00  profilanswer
nikopop a écrit a écrit :
[:yaisse]
Ouai mais du VIA avec un CPU Intel, je n'admet pu se sacrilege...
Je prefere autant avoir un AMD + VIA... c'est plus logique :)
En attendant si ASUS/ABIT fesais des mobos P4X400 on pourrais dominé la RDRAM PC800 et faire peur a la PC1066 avec de la simple DDR333/400 :)
n°550294
Oxygen3
Tears from the moon
Posté le 11-07-2002 à 10:38:43  profilanswer
zelave
Metro-Pole ▬ Réseau A Suivre...: Annuseries|LeVillage|pErDUSA
n°550297
MEI
|DarthPingoo(tm)|
Posté le 11-07-2002 à 10:44:21  profilanswer
http://www.ocworkbench.com/archives/jul2002/8k5a2+.jpg
n°550302
Oxygen3
Tears from the moon
Posté le 11-07-2002 à 10:49:15  profilanswer
:/ fait chier ils ont tjrs pas revu le disign général de la carte :/
n°550332
Magicpanda
Pushing the envelope
Posté le 11-07-2002 à 11:13:31  profilanswer
sortira pas en tbred
c lequel le dernier des dernier tbred?
" Quel est le but du capital ? Le but du capital c'est produire pour le capital. L'objectif, lui, est illimité. L'objectif du capital c'est produire pour produire." - Deleuze || André Gorz - Vers la société libérée
n°550337
Oxygen3
Tears from the moon
Posté le 11-07-2002 à 11:18:02  profilanswer
2400+ en theorie
(1.933Mhz)
n°550343
Magicpanda
Posté le 11-07-2002 à 11:21:49  profilanswer
OxYGeN3 a écrit a écrit :
2400+ en theorie
(1.933Mhz)
bon ba voila mon futur proc si il sort un jour  :D
n°550380
thieuma
Posté le 11-07-2002 à 11:45:40  profilanswer
n°550383
thieuma
Posté le 11-07-2002 à 11:46:23  profilanswer
ouaip ça ça pue par contre, une merdace style kha pour intel....
n°550386
cpulloverc​lock
Posté le 11-07-2002 à 11:49:32  profilanswer
jai monte l'ax7 et le 80mm et ct bien la temp qui me bridait
jai f un 183 a cpumark a 1930MHz et 56s au 1Mo
enfin stable a + de 1900MHz et 2.05v
n°550433
cpulloverc​lock
Posté le 11-07-2002 à 12:27:35  profilanswer
je ferai un screen a 2075MHz dns la journee en air cooling  :sol:
n°550435
Oxygen3
Tears from the moon
Posté le 11-07-2002 à 12:28:14  profilanswer
n°550436
Oxygen3
Tears from the moon
Posté le 11-07-2002 à 12:29:22  profilanswer
les abit sont trop bien pour ca en fait  :love:
tous les connecteurs sont super bien placés, (alim en particulier)
n°550442
cpulloverc​lock
Posté le 11-07-2002 à 12:35:03  profilanswer
sauf la SA7  :kaola:
n°550449
nikopop
凸(`0´)凸
Posté le 11-07-2002 à 12:41:28  profilanswer
sauf la SA7  :kaola:
[:yaisse]
n°550457
Oxygen3
Tears from the moon
Posté le 11-07-2002 à 12:45:01  profilanswer
[:yaisse]
je parle des kt7/kg7/kr7/kx7/kZ7 (? ;))
n°550462
cpulloverc​lock
Posté le 11-07-2002 à 12:46:54  profilanswer
n°550466
Oxygen3
Tears from the moon
Posté le 11-07-2002 à 12:48:20  profilanswer
et ?
n°550468
cpulloverc​lock
Posté le 11-07-2002 à 12:49:12  profilanswer
et ?
ben dns cette phrase tav dit toutes les abit et non pas les kt7/kg7/kr7/kx7/kZ7  :p
n°550470
Oxygen3
Tears from the moon
Posté le 11-07-2002 à 12:50:27  profilanswer
 :non:
j'ai dis 'les' sans préciser toutes  :ange:
n°550473
cpulloverc​lock
Posté le 11-07-2002 à 12:55:33  profilanswer
 :non:
jai pris ca pour une generalite
pour moi meme sans le toutes c une generalite  :benetton:
n°550480
Ben100g
Posté le 11-07-2002 à 12:58:21  profilanswer
:hello:  les furieux
voici un tout petit apperçu de mon mod ( à la webcam ) en attendant un meilleur appareil.....
http://membres.lycos.fr/ben100g/tour1.jpg
http://membres.lycos.fr/ben100g/tour2.jpg
http://membres.lycos.fr/ben100g/tour3.jpg
n°550488
Ben100g
Posté le 11-07-2002 à 13:03:45  profilanswer
allez une autre pour me rattraper...   (elles sont vraiment pas belles les autres..) :D
http://membres.lycos.fr/ben100g/2blocks.JPG
Message édité par Ben100g le 11-07-2002 à 13:04:24
n°550494
Oxygen3
Tears from the moon
Posté le 11-07-2002 à 13:10:28  profilanswer
j'ai le mm a la maison :o
n°550496
cpulloverc​lock
Posté le 11-07-2002 à 13:16:39  profilanswer
pkoi tu te f  pas un vaporphase  :??:
n°550509
Ben100g
Posté le 11-07-2002 à 13:27:26  profilanswer
je commence avec l'eau c'est déja assez compliqué....
1 semaine de modd + 5 heures de montage
je maudissais mon PC à la fin quand j'ai du tout cabler....
un truc de ouf en plus j'ai un fanbus now et ca n'a pas arrangé les choses...  bon bref j'en suis très content même si 2-3 retouches à faire..
A quand qqun au LN2 sur le forum... ???
n°550596
Oxygen3
Tears from the moon
Posté le 11-07-2002 à 15:13:16  profilanswer
oué on veut du ln2 !
n°550632
Magicpanda
Posté le 11-07-2002 à 16:03:01  profilanswer
ki est assez riche pour crammer mobo + cpu a titre experimental + le prix du ln2  :D
n°550710
Le Veilleu​r
Posté le 11-07-2002 à 17:01:10  profilanswer
Mon montage à moi
http://forum.leveilleur.net/montage6.jpg
http://forum.leveilleur.net/montage3.jpg
http://forum.leveilleur.net/montage2.jpg
Mais ils ont pas encore validé mon overclocking ds la bd de hfr  :(
Mon Blog : LeVeilleur.net | Hébergement d'images : Hostipics.net
n°550713
Magicpanda
Posté le 11-07-2002 à 17:02:30  profilanswer
c'est sympa , mais pas  encore extremement extreme  :D
Message édité par Magicpanda le 11-07-2002 à 17:02:55
n°550714
nasdak
Posté le 11-07-2002 à 17:02:41  profilanswer
a koi elle sert la ptite alim ?
n°550716
Le Veilleu​r
Posté le 11-07-2002 à 17:04:20  profilanswer
La petite alim pour les ventilos de 120, C'est réglable de 3V à 12V.
Mais c'est du provisoir, car j'ai mas chieftec a modder. Mais je voudrais tirer plusque 1.5Ghz de mon duron.
n°550717
Oxygen3
Tears from the moon
Posté le 11-07-2002 à 17:04:41  profilanswer
ventilo CG ?
n°550718
nasdak
Posté le 11-07-2002 à 17:05:03  profilanswer
lol tout ca pour un duron
n°550720
Le Veilleu​r
Posté le 11-07-2002 à 17:06:24  profilanswer
ventilo CG ?
Un rad de duron avec un 60mm mais il tourne pas...Vu que c'est une TNT2ultra, pas trop besion de refroidissement. Bientot une Gf4 j'espere.
Duron 1.2Ghz O/C 1.5Ghz (en 10*150).
[ FOR OVERCLOCKERS FOUS ] ?¤¤ salon des habitués ¤¤?Overclock P IV 1.8A @2.2 avis des overclockers fous ?
[ FOR OVERCLOCKERS FOUS ] ?¤¤ salon des habitués ¤¤?[ FOR OVERCLOCKERS FOUS ] /// salon des habitués \\\
Plus de sujets relatifs à : [ FOR OVERCLOCKERS FOUS ] ?¤¤ salon des habitués ¤¤?
