3264 connectés
 Page :   1  2  3  4  5  6
Fabriquant de ventilo !!
n°245040
eManu
Posté le 16-07-2001 à 16:14:21  profilanswer
AAAAAAAAAAAhhhhhhh !  :bounce:  :bounce:  :bounce:
Au boulot, tu as de la lecture !  :D
vectorw16 a écrit a écrit :
Après une semaine d'absence je suis de retour ...
n°245068
eManu
Posté le 16-07-2001 à 16:53:50  profilanswer
Sinon, j'ai une réponse de Verax à mes demandes de précisions :
"Here are some detail informations about our products:
Fan (80x80x25):
Min 1200 U/min at 20°C with 12,5 m³/h (40%)
Max 3100 U/min at 50°C with 32 m³/h
CPU-cooling system (fan 65x65x20):
Min 2250 U/min at 20°C with 9,5 m³/h (40%)
Max 3700 U/min at 50°C with 16 m³/h
This are free-blowing determined characteristic values.
A comparison with free-blowing characteristic values of conventional axial fans with regard to volume current and sound development is not meaningful, because in the inserted condition they react more sensitively to sheetings than Verax-fans.
Axial fans are pursued in the PC in an area of their throttle
curve very unfavorable for.
They reach in the inserted condition sometimes only up to 25% of their free-blowing volume current.
Besides, by whirls they become at the same time very loud. Therefore, free-blowing characteristic values are to be enjoyed with caution.
Therefore, we always consider the whole PC-system with regard to sound developments.
I hope I could answer your(their) questions satisfyingly.
Faithfully Yours
Christof Huonker
-Verax ventilators GmbH"
Et concernant le bruit, si je comprends bien, ...ce n'est PAS COMPARABLE !  :hap:
On est bien avancés, là !  :lol:
n°245255
vectorw16
Posté le 16-07-2001 à 21:41:26  profilanswer
C'est quoi cette explication bidon  :hap:  :??:
En passant pour mettre les chiffres en valeur !
1m 3/min = 35.31 ft3/min cfm alors des m3/h il faut diviser le tout par 60 et multiplier par 35.31 donc :
Min 1200 U/min at 20°C with 12,5 m³/h (40%)  = 7,35 cfm
Max 3100 U/min at 50°C with 32 m³/h          = 18,83 cfm
Min 2250 U/min at 20°C with 9,5 m³/h (40%)   = 5,59 cfm
Max 3700 U/min at 50°C with 16 m³/h          = 9,41 cfm
TOUT CA POUR UNE 80x80x25 .... j'ai tu maqué qqch ou ca vaux pas de la MARDEEEEEEEE  :lol: désoler
n°245773
vectorw16
Posté le 17-07-2001 à 18:10:17  profilanswer
Ou du moins à 5 ou 6 dba ca serais intéressant ....
n°246258
eManu
Posté le 18-07-2001 à 11:39:29  profilanswer
Humm, chez Blacknoise ils parlaient plutôt de 12 dBA (je ne sais pas d'où ils les "sortent" ). :(
Mais ATTENTION, il ne s'agit pas des mêmes dBA ! :lol:  :lol:  :lol:
Si on tient compte de l'avantage qu'ils revendiquent sur les ventilos axiaux "normaux", une fois installés, nous leur accorderons un 11 dBA. :sol:
Ils vont avoir du mal à convaincre de la supériorité de leur profil de pales révolutionnaire ! :D
n°246372
vectorw16
Posté le 18-07-2001 à 14:37:38  profilanswer
En fait Sanyo m'on dit quelque chose de similaire ! Ca sonnais qqch du genre  : leur fan étaient mieux balancé alors elle risquais moins de faire de vibration sur le métal du casing !
C'est vrai qu'il y a une différence entre la mesure du bruit d'une fan suspendu dans les air et une visser sur le casing...
Vas falloir les essayer ....
n°246376
eManu
Posté le 18-07-2001 à 14:44:36  profilanswer
...Je t'en prie  :D
(on attend ton verdict :p )
Note: ils sont répertoriés comme ventilos d'alim.
n°246431
vectorw16
Posté le 18-07-2001 à 16:20:42  profilanswer
...Je t'en prie  :D
Fais moi en parvenir une et je vais regrouper tous mes amis pour qu'on fasse une session d'écoute attentive  :lol: !
n°249562
vectorw16
Posté le 23-07-2001 à 22:30:37  profilanswer
UP Mon topic n'est pas pour les oubliettes ... On a toujours pas trouvé l'utime fan puissante et silentieuse !!
n°249673
eManu
Posté le 24-07-2001 à 02:08:38  profilanswer
Il est temps de faire 1 p'tit récapitulatif :D
Peux-tu m'envoyer le fichier (80x80), stp ?
Merci. :hello:
n°251603
eManu
Posté le 26-07-2001 à 18:13:22  profilanswer
Euh, t'es faché, vectorw16 ?  :(
n°254771
vectorw16
Posté le 31-07-2001 à 01:32:34  profilanswer
Quoi que mon classement ne change pas voici un update des constructeurs :
Remarquez que le site de Panaflo à changer
ADDA   : http://www.adda.com.tw/
Antec    : http://www.antec-inc.com/
Cofan  : http://www.cofan-usa.com/
ComairRotron    : http://www.comairrotron.com/
CoolerMaster : http://www.coolermaster.com/home.html
Delta    : http://www.deltaww.com/products/pr [...] key=3308dc
Ebm     : http://www.ebm.com/home.html#
Elina  : http://www.russellind.com/Conco/indek/indek.htm
Etri     : http://www.etrinet.com/
Globalwin : http://www.globalwin.com.tw/cd_html.html
GlobeFan : http://www.globefan.com/
GlobeMotors : http://www.globemotors.com/
Jamicon  : http://www.jamicon.com/FANS.HTM
JMC  : http://www.jmcproducts.com/
Mechatronics    : http://www.mechatronics.com
Nidec  : http://www.nidec.com/fans.html
NMB  : http://nmbtechn.iserver.net/cgi-bi [...] start.html
ORIX  : http://www.omusa.com/automated/product/orix.htm
Panasonic  : http://www.panasonic.com/industria [...] _axial.htm
Papst    : http://www.papst.de/english/produc [...] start.html
Sanyo Denki   : http://www.sanyo-denki.com/
Sunon    : http://www.sunon.com.tw/index_en.htm
Titan    : http://www.titan-cd.com/titan.htm
Thermaltake  : http://www.thermaltake.com/
Top Motor  : http://www.dynaeon.com.tw/
Toyo  : http://www.ustoyofan.com/
YateLoon        : http://www.yateloon.com/
Y.S tech        : http://www.ystech.com.tw
Zalman  : http://www.zalman.co.kr/english/product/cnpsfan.htm
n°254775
vectorw16
Posté le 31-07-2001 à 01:34:28  profilanswer
Mais non pourquoi le serais-je ?? :D
n°254805
eManu
Posté le 31-07-2001 à 02:23:07  profilanswer
Tu ne m'as pas envoyé le fichier (excel) que je te demandais gentiment :D
 :cry:  :cry:  :cry:
PS: dans ta liste, tu as considéré que Noiseblocker n'était pas un "constructeur" ?
[edtdd]--Message édité par Emanu--[/edtdd]
n°254912
cidou
Euh...
Posté le 31-07-2001 à 11:34:36  profilanswer
kelk1 va les tester ?
avec un tableau comparatif : CFM, bruit, prix...
paske les répertorier c bien mais faut aussi savoir ki les vend !
n°255524
vectorw16
Posté le 31-07-2001 à 17:31:14  profilanswer
Si ca te tente demande aux gars de Hardware.fr moi j'ai abandonné ...  :na:
Si ca te tente part toi un topic vendeur de ventilo car comme j'ai déja dit j'habite pas la france alors c'est bien difficile pour moi de savoir ou ils en vendent !
[edtdd]--Message édité par vectorw16--[/edtdd]
n°257513
vectorw16
Posté le 02-08-2001 à 16:25:06  profilanswer
Pour faciliter la vie a tous le monde qui cherche des spects de fan ...
UUUUUUPPPPPPPPPPPP!!!
n°258458
vectorw16
Posté le 03-08-2001 à 22:14:41  profilanswer
On a du nouveau  :D
http://www.rexnordindia.com/
Dans le DC y en a avec des très bonne spects
J'ai trouver ca a cause de mon nouveau topic "vos ordi de marque on quel ventilo"
n°260417
vectorw16
Posté le 06-08-2001 à 16:29:19  profilanswer
J'ai aussi trouver un magasin qui vend plein de ventilo au USA
http://www.jameco.com
Ils ont l'air d'avoir des prix pas trop pire ! :D
n°260424
nicotwingo
Posté le 06-08-2001 à 16:46:59  profilanswer
http://www.nidec.co.jp/english/index.html
Et les NIDEC alors on en parle pas ?
n°260495
vectorw16
Posté le 06-08-2001 à 17:45:53  profilanswer
Je crois que tu as mal regarder ... regarde un peu plus haut dans la liste NIDEC est bien présent ...
n°260578
colin
Posté le 06-08-2001 à 19:00:03  profilanswer
vectorw16 , ton fichier excel m'intéresse tu pourai me l'envoyer please;):
tomtom141@caramail.com
n°267689
vectorw16
Posté le 16-08-2001 à 20:24:07  profilanswer
Tin un beau petit UP pour remettre ce beau topic a la vue   :D
Si vous avez des commentaires ou des nouveauté ne vous gênez pas ...
n°267887
trentmil
Posté le 17-08-2001 à 00:17:39  profilanswer
Sur mon alim no name j'ai un ventilo que je ne connais pas. J'en cherche les specs qq1 peu m'aider. Voilà ce que je peux lire :
     colorful
     DC   brushless
     CF-128025  MS
     12 V   0.14 A
n°268461
vectorw16
Posté le 17-08-2001 à 19:55:37  profilanswer
     colorful
     DC   brushless
     CF-128025  MS
     12 V   0.14 A
A prime abort je ne trouve rien sur colorful ... t'es sur qu'il est pas marqué autre chose ?
C'est quoi la marque de ton alim ?
n°268628
trentmil
Posté le 18-08-2001 à 01:49:32  profilanswer
     J'ai déjà entendu un gars parler de ventilo colorful sur le forum. Sinon mon alim est sous du gédicoustic donc je ne vois pas la marque. Je l'ai acheté avec ma tour no-name. Je pense que c'est la même chose que les alims qu'on voit à 170 F.
     J'ai cherché aussi colorful, sans rien trouver, je me demande si ce ne serait pas un sous traitant. Sur le ventilo il y a écrit que c'est fait en chine, mais bon ca aide pas beaucoup.
n°269225
vectorw16
Posté le 19-08-2001 à 01:04:33  profilanswer
 :lol:  :lol:  Non en effet ca aide pas vraiment  :lol:
Mais pour quel raison tu veux avoir ces spects au juste ?
n°276665
vectorw16
Posté le 30-08-2001 à 21:09:23  profilanswer
J'ai négliger un peu mon topic ces derniers temps alors !
UPPPPPPPPP!!!
n°276681
crocow
Posté le 30-08-2001 à 21:53:25  profilanswer
salut vectorw16,
as tu vu les ventilos sanyo denki?
cf news de ppc...
Frappés par la maladie du retard depuis tout début août, ils sont enfin disponibles : ce sont les ventilateurs pour tour de Sanyo Denki.
Pour le moment, seules deux références des modèles standards 80x80x25 sont disponibles, qui semblent très intéressantes :
109R0812H402 : 1.56W, 2900trs/min, 29 dBA pour 36.4 CFM
109R0812M402 : 0.72W, 2350trs/min, 23 dBA pour 29.3 CFM
CFM : flux d'air délivré. Plus c'est élevé, mieux c'est.
Pour rappel la plupart des "bons noname" (80 à 100 F) trouvables sur le marché font environ 30 / 31 dBA pour environ 30 à 35 CFM. Le moins bruyant qu'il m'ait été donné de trouver en France jusqu'ici était le modèle proposé par LDLC : 29 dBA pour 33 CFM (80 F).
L'offre de Sanyo dépasse ici clairement les "noname" : moins bruyant pour plus d'efficacité, et une durée de vie probablement meilleure. Bien sûr, cela à un prix : vous devriez pouvoir les trouver autour des 140/150 F, contre 80 à 100 F pour des "bons no name".
Si le silence vous importe plus que tout, le modèle à 23 dBA fera merveilleusement l'affaire, tandis que le modèle à 29 dBA ravira tout le monde, offrant un excellent rapport qualité / performances / bruit.
A noter que pour les fanas de l'overclocking, deux modèles 119x119 sont disponibles :
109P1212M402 : 1850 trs/min, 29 dBA pour 58.6 CFM
109P1212H402 : 2800 trs/min, 40 dBA pour 88.3 CFM
Le magasin Docmicro-fr, qui vient de nous prévenir de cette toute fraiche disponibilité, vous propose d'acheter les 80x80 à 120 F pièce en venant de la part de Présence PC.
voila
a+
n°276698
vectorw16
Posté le 30-08-2001 à 22:08:53  profilanswer
crocow a écrit a écrit :
salut vectorw16,
cf news de ppc...
Bein je connais la marque c'est des très bon ventilo mais au niveau des spects ils n'ont rien d'extraordinaire ...
C'est certain qu'on regrette rarement l'achat d'une sanyo denki!
C'est bien qu'elles soit pas trop cher en france car ici au Québec elle sont cher ca pas de bon sang une 60x60 coute 15$ US j'ai jamais osé demander plus gros ... :sweat:
n°277560
crocow
Posté le 01-09-2001 à 13:19:56  profilanswer
et les autres marques, c'est moins cher au quebec?(papst sunon)
n°279609
vectorw16
Posté le 04-09-2001 à 21:09:54  profilanswer
Oui Papst je peux en avoir pour pas trop cher sunon aussi !
Il vas bein faloir que je me décide un jour ! Ce topic à été créer pour me permettre de changer les fans de mon PC!
Mais vu qu'on a jamais choisi la meilleur bein je marche encore avec mes Antec bruyante !  :gun:
n°279646
Titprem
Posté le 04-09-2001 à 21:43:06  profilanswer
Juste en passant :
http://www.vibobel.be/francais/mar [...] ntent.html
voire :
http://www.vibobel.be/francais/produit/produit.html
[edtdd]--Message édité par Titprem--[/edtdd]
n°279651
crocow
Posté le 04-09-2001 à 21:49:29  profilanswer
ba si tu peux prend des papst j'en ai 2 et je suis pas decu
surtout si tu lesa pa cher....
n°298000
vectorw16
Posté le 01-10-2001 à 20:16:16  profilanswer
Tien je vais ressortir mon vieux topic !
En sous peux on n'en aura pus besoin car D-Fens est en train de développer un site-web avec une base de donnée ventillo !
Mais remarque que le meilleur ventilo n'est toujours pas choisi ...   :)
Still open
n°298112
crocow
Posté le 01-10-2001 à 22:11:06  profilanswer
lol ton proc a du cramer depuis le temps.....
c'est quoi l'adresse du site?
a+
n°298156
vectorw16
Posté le 01-10-2001 à 22:58:25  profilanswer
Non l'hiver s'en vien et il aime plutôt ca mon Proc !
L'adresse est la suivante :
http://tweakfr.multimania.com/ventilo/
Mais dison que j'ai pas mal de chose à m'occuper en plus de mon water cooling qui est toujours pas terminer !
Alors le site est construit par D-fens et les ventilo viennent de mes fichier excel !
Ca donne un bon résultat !  :sol:
n°300493
D-Fens
Posté le 04-10-2001 à 16:57:37  profilanswer
Un ti up
Juste pour dire ke le site est bien ouvert mainteant avant c'etait des tests.
L'url precedente ne marche + là nouvelle est www.tweak.fr.st
Sur cette nouvelle version on peut entre autre voir des dizaines de references supplementaire
n°384583
vectorw16
Posté le 22-01-2002 à 15:23:14  profilanswer
ET Up ca fais longtemps !! Mais reste que si qq'un cherche un ventilo c'est une bonne référence !
n°384624
Kahyman
Posté le 22-01-2002 à 16:39:51  profilanswer
n°384631
vectorw16
Posté le 22-01-2002 à 16:42:30  profilanswer
Kahyman a écrit a écrit :
Dynaeon : http://www.dynaeon.com.tw/products.htm
Compagnie de leur ventilateur Top Motors !
Déja dans le classement !
Merci quand même ! :sol:
 Page :   1  2  3  4  5  6
plaque cuivre entre Athlon et ventiloou acheter juste un ventilo ?
Il y a un gros risque de peter un duron en bougeant le ventilo de 2mmBesoin de conseils pour un ventilo et autres
Ventilo pour Leadtek Geforce II GTS 64 Mo ?Ou je trouve un ventilo de 120 style papst, panaflo... ?
raaaaaaaaaaaah saloperie de ventilo abit !- Le Ventilo de ma KT7-133 se prends pour un Bi reacteur -
FOP 38 + ventilo 92mm??Quel ventilo pour un P3 slot 1
Plus de sujets relatifs à : Fabriquant de ventilo !!
