10263 connectés
 Page :   1  2
Page Suivante
AUSECOURS impossible de booter apres flash !!! AHHHHHH !!!!
n°228969
COULIX
un pc pour les attirer ...
Posté le 22-06-2001 à 21:33:31  profilanswer
avec la disquett win 2000 ca marche pas le sys s arreta a la premiere disquett apres detection de matos   et  la plis rien......
la disquette s etteint et je l ai dans le cul
sa veut dir que meme avec ubne disquette win 98 je ne booterai pas osus dos
y aplus que le flash comme vous avez dit
y apas d equivalnt sous win 2000 pour creer une disquette system bootable?????
(fais chiez j aurai j amais dut metre le serveur sous win 2000)
couolix
.... et dans les tenebres les lier
n°228990
COULIX
Posté le 22-06-2001 à 21:49:30  profilanswer
de tout facon c en ntfs...
n°229028
COULIX
Posté le 22-06-2001 à 22:28:04  profilanswer
ca fait chiez...
un beau 1466
coulix
au pire je rachete une carte mere
n°229187
COULIX
Posté le 23-06-2001 à 01:04:27  profilanswer
voila mon problem
c exactement ca
When I boot the BIOS all it says is "AWARD boot block BIOS". What should I do?
This can occur if you have been overclocking your processor and failed to boot at a certain speed.  In this case it can be solved by clearing the CMOS using the jumper on the motherboard.
It can also occur if your CPU is damaged or malfunctioning in some way - particularly after damaging the core when installing a heatsink.
In other cases, however, this means you have a corrupted BIOS, but the "fail safe" boot block BIOS is still working. You should be able to insert a bootable floppy and flash the BIOS to the latest version. Make sure the bootable floppy contains no memory management utilities, such as HIMEM.SYS. Follow the BIOS flash instructions above. If this fails, you will need to contact the suppliers of your motherboard. Your BIOS chip is dead... :-(
Note that companies such as BadFlash exist, who will reprogram your BIOS chip for a modest fee. Alternatively contact Abit directly who again will sell you a new BIOS chip for a similar cost - see question "How do I get a replacement BIOS chip?" below.
To prevent these problems in the future you may wish to consider using a BIOS Saviour.
j opterai pour e bios defectueu d epreferences :)
coulix
n°229206
corpo
Wat
Posté le 23-06-2001 à 02:36:45  profilanswer
Les choses sont simples:
Tu as foiré ton flash, donc le bios est corrompu. Heureusement, le boot block n'a pas été touché et tu peux donc booter en mode restauration. Tu as le service minimum, le boot sur une disquette. Il te faut une disquette de boot Win 95 ou 98 sinon ça marchera pas. Sur cette disquette, il te faut en plus des fichiers systemes les fichiers suivants:
  • AWDFLASH.EXE
  • AUTOEXEC.BAT qui contient une ligne -> AWDFLASH BIOS.BIN /PY /SN /R
  • BIOS.BIN Un bios qui fonctionne pour ta carte mère
Si tu n'as pas accès a un win 9x mais seulement à un Win 2000 tu es un peu emmerdé pour créér une disquette de boot Win 9x, car même en copiant les fichiers ça ne marchera pas il manque le boot de la disquette.
Solution: Télécharge ça http://service.boulder.ibm.com/sto [...] t-v210.exe , ce prog te créée une disquette de boot avec plein de trucs dessus. Une fois la disquette créée tu effaces tous les fichiers SAUF:
  • COMMAND.COM
  • IBMBIO.COM
  • IBMDOS.COM
là tu mets tes fichiers préparés avant
Et tu as ta disquette magique!
[edit]--Message édité par Corpo--[/edit]
Mon topic vente
n°229208
COULIX
Posté le 23-06-2001 à 02:47:11  profilanswer
j attend un pote qui vas arriver avec sa becanne sous win98 on vas faire ac a deux
si sca marche je brulerain un cierge dans l honneur de hardware
.fr
donc il n y a qu une seule ligne dans l autoexe...
et si c une disquette de win 98 pazs besoin de  garder                  commande.com
                        IBMBIO.com
                        IBMDOS.com  c ca??
coulix
n°229209
corpo
Wat
Posté le 23-06-2001 à 02:50:33  profilanswer
.fr
                        IBMBIO.com
                        IBMDOS.com  c ca??
coulix
Si c'est une disquette win 98 formatée système (au choix dans le poste de travail ou par format a: /s) tu n'effaces rien (il devrait y avoir command.com et io.sys au minimum)
Le plus simple c'est que tu mettes tous les fichiers du bios abit sur la disquette et que tu changes le nom de ABITFAE.BAT en AUTOEXEC.BAT, c'est le plus simple
Mon topic vente
n°229213
COULIX
Posté le 23-06-2001 à 02:59:40  profilanswer
ok  je vous tient au courant
http://www.smilies.org/basesmilies/camper.gif
n°229214
COULIX
Posté le 23-06-2001 à 03:04:43  profilanswer
au fait cela t deja arriver??
comment ca se fait que un flashage puisse deconer sur        mon ancienne cartemerePA61 ct nickel
coulix
n°229215
corpo
Wat
Posté le 23-06-2001 à 03:07:29  profilanswer
coulix
J'ai jamais foiré un seul flash, mais j'ai déjà dépanné plein de carte mère avec des bios foirés. Le plus marrant c'est quand le bios est complètement foiré: tu boote sur une carte mère identique (pas forcement, mais vaut mieux), tu changes la puce du bios a chaud (faut etre rapide et précis, sinon bonjour les faux contacts) et tu flashes. Et hop! Retour a la vie de la carte mère!
Mon topic vente
n°229217
COULIX
Posté le 23-06-2001 à 03:17:23  profilanswer
tu as dons deja vus des cas comme le mien??
la           KT7A l eprom estsoudée??
coulix
n°229220
bobo
Posté le 23-06-2001 à 04:23:31  profilanswer
coulix
tu te fais un disk boot win98se
tu vires tout sauf autoexec.bat et config.sys
tu vides le contenu de config.sys
tu vides le contenu de autoexec.bat
tu mets "abitfae.bat kt7_3c.bin" dans autoexec.bat
tu mets tous les fichiers decompressé de ton bios
L'abitfae.bat je te conseille :
au lieu de "AWDFLASH.EXE %1 /py /sn /cd /cp /cc" de mettre "AWDFLASH.EXE %1 /py /sn /cd /cp /cc /r /ld" après le flash il va rebooter tout seul.
et meme tout court au lieu de "abitfae.bat kt7_3c.bin" dans autoexec.bat, de mettre dans l'autoexec.bat "AWDFLASH.EXE  kt7_3c.bin /py /sn /cd /cp /cc /r /ld"
ps: si les potes lisent ce post : "j'en ai marre !!! quand vous plantez vos bios venez avec vos disquettes, sur mes 20 disk j'en ai plus qu'une seule et jamais personne pense à me les ramener, aussi vous pointez plus chez moi le dimanche." v'là c tout.
[edit]--Message édité par bobo--[/edit]
1+1=10
n°229231
COULIX
Posté le 23-06-2001 à 06:13:35  profilanswer
CA Y EST CA MARCHE !!!!!!!  :crazy:  :hap:  :love:
c cooolllll
MERCI A TOUS C SUPER SYMPA !!!!!
est ce que un changement de bios peut influencer l overclocking
par ce que la, il plante au bout de 5 seconde sous windows  a 1466 mhz :ouch:
je vais tester les differents parametres..
coulix
n°229234
COULIX
Posté le 23-06-2001 à 07:12:40  profilanswer
une chose bizarre..
il plante au bout de 10 seconde avec une frequence >1333
c bizarre avant il tenait les 1466
d eplus il tient a 1466 seulement en mode sans echec
il faut reinstaler un truc apres le flashage genre via 4.3 ??
sinon je rechope le bios d origine !!
coulix
snif avant j était a 4082 mips et maintenant 3680
 :cry:  :cry:  :cry:  :cry:  :cry:  :cry:  :cry:  :cry:  :cry:  :cry:
 Page :   1  2
Page Suivante
message d'erreur flash biosflash bios
BH6 Rev 1.1 : impossible d'avoir 8,5X105 avec un CII 566OC Impossible ?? -- Voltage ???
Overcloaking Dell Pentium 4 (possible ou impossible?)Flash bios KT7A -> Icone noir et brouillé ?
Impossible de mettre son o/c dans le classement !Putain de Tbird qui veux pas booter au dessus de 1.4 Ghz !!!
est ce que quand on flash la garantie marche encore???Problème de flash sur A7V133, rassurez-moi
Plus de sujets relatifs à : AUSECOURS impossible de booter apres flash !!! AHHHHHH !!!!
