2865 connectés
  CPU
  aider moi a overclocker mon pentium!!! 1,6...
n°1470638
alexandra3​7
Posté le 08-09-2006 à 02:40:24  profilanswer
salut, je suis novice dans le domaine informatique,je voudrai savoir comment overclocker mon ordi-portable "pentuim !!! 1,6ghz" ,avec quel logiciel sur windows,(car a partir de bios c impossible).ma configuration est la suivante: et je remerci tt aide ...
  CPU-Z version 1.36
Processors Map
Number of processors 1
Number of threads 1
Processor 0
    -- Core 0
        -- Thread 0
Processors Information
Processor 1 (ID = 0)
Number of cores  1
Number of threads 1 (max 1)
Name   Intel Pentium III-M
Codename  Tualatin
Specification  Intel(R) Pentium(R) III Mobile CPU      1066MHz
Package   Socket BGA2 (platform ID = 5h)
CPUID   6.B.1
Extended CPUID  6.B
Brand ID  6
Core Stepping  tA1
Technology  0.13 um
Core Speed  730.4 MHz (5.5 x 132.8 MHz)
Stock frequency  1066 MHz
Instructions sets MMX, SSE
L1 Data cache  16 KBytes, 4-way set associative, 32-byte line size
L1 Instruction cache 16 KBytes, 4-way set associative, 32-byte line size
L2 cache  512 KBytes, 8-way set associative, 32-byte line size
FID/VID Control  no
Thread dumps
CPU Thread 0
APIC ID   0
Topology  Processor ID 0, Core ID 0, Thread ID 0
Type   01000807h
Max CPUID level  00000002h
Max CPUID ext. level 80000004h
Function  eax  ebx  ecx  edx
0x00000000 0x00000002 0x756E6547 0x6C65746E 0x49656E69
0x00000001 0x000006B1 0x00000006 0x00000000 0x0383F9FF
0x00000002 0x03020101 0x00000000 0x00000000 0x0C040883
0x80000000 0x80000004 0x00000000 0x00000000 0x00000000
0x80000001 0x00000000 0x00000000 0x00000000 0x00000000
0x80000002 0x65746E49 0x2952286C 0x6E655020 0x6D756974
0x80000003 0x20295228 0x20494949 0x69626F4D 0x4320656C
0x80000004 0x20205550 0x20202020 0x36363031 0x007A484D
MSR 0x00000017  edx = 0x97D60000 eax = 0x00000000
MSR 0x0000002A  edx = 0x00000000 eax = 0xC5040020
Chipset
Northbridge  Intel i830MP rev. A4
Southbridge  Intel 82801CAM (ICH3-M) rev. 01
Graphic Interface AGP
AGP Revision  2.0
AGP Transfer Rate 4x
AGP SBA   supported, enabled
Memory Type  SDRAM
Memory Size  1024 MBytes
Memory SPD
DIMM #1
General
Memory type  SDRAM
Manufacturer (ID) Micron Technology (2CFFFFFFFFFFFFFF)
Size   512 MBytes
Max bandwidth  PC133 (133 MHz)
Attributes
Number of banks  2
Data width  64 bits
Correction  None
Registered  no
Buffered  no
EPP   no
Timings table
Frequency (MHz)  100 133
CAS#   2.0 3.0
RAS# to CAS# delay 2 3
RAS# Precharge  2 3
TRAS   5 6
Dump Module #1
      0  1  2  3  4  5  6  7  8  9  A  B  C  D  E  F
00   80 08 04 0D 0A 02 40 00 01 75 54 00 82 08 00 01
10   8F 04 06 01 01 00 0E A0 60 00 00 14 0F 14 2C 40
20   15 08 15 08 00 00 00 00 00 00 00 00 00 00 00 00
30   00 00 00 00 00 00 00 00 00 00 00 00 00 00 12 D2
40   2C FF FF FF FF FF FF FF 01 31 36 4C 53 44 46 36
50   34 36 34 48 47 2D 31 33 33 42 32 02 00 01 2F 1A
60   10 45 61 00 00 00 00 00 00 00 00 00 00 00 00 00
70   00 00 00 00 00 00 00 00 00 00 00 00 00 00 64 CF
Monitoring
Sensor Chip  SMSC E01
PCI Device List
Host Bridge
bus 0 (0x00), device 0 (0x00), function 0 (0x00)
Common header
 Vendor ID  0x8086
 Model ID  0x3575
 Revision ID  0x02
 PI   0x00
 SubClass  0x00
 BaseClass  0x06
 Cache Line  0x00
 Latency   0x00
 Header   0x00
PCI header
 Address 0 (memory) 0x60000000
 Subvendor ID  0x0E11
 Subsystem ID  0x0030
 Int. Line  0x00
 Int. Pin  0x00
Capabilities
 Vendor Dependant Capability
  Dump
  00 01 02 03 04
  09 A0 05 01 01
 AGP Capability
  Version  2.0
  Status  enabled
  Transfer rate 4x (max 4x)
  Queue lenght 1 (max 32)
  Dump
  00 01 02 03 04 05 06 07 08 09 0A 0B
  02 00 20 00 17 02 00 1F 04 03 00 00
Dump
 00   86 80 75 35 06 00 10 20 02 00 00 06 00 00 00 00
 10   08 00 00 60 00 00 00 00 00 00 00 00 00 00 00 00
 20   00 00 00 00 00 00 00 00 00 00 00 00 11 0E 30 00
 30   00 00 00 00 40 00 00 00 00 00 00 00 00 00 00 00
 40   09 A0 05 01 01 00 00 00 00 00 00 00 02 28 00 0E
 50   72 A2 0A 00 00 00 00 00 00 10 11 11 00 00 11 11
 60   08 10 18 20 20 20 00 00 00 00 00 00 00 00 00 00
 70   22 22 FF FF 00 00 00 00 10 00 04 00 70 42 00 30
 80   00 00 00 00 00 00 00 00 00 30 C2 22 00 00 00 00
 90   0A 38 00 00 00 00 00 00 00 00 00 00 00 00 00 00
 A0   02 00 20 00 17 02 00 1F 04 03 00 00 00 00 00 00
 B0   80 00 F0 00 00 00 00 00 00 40 12 00 20 00 00 00
 C0   00 56 0E 41 A2 81 01 00 C0 00 00 00 00 00 00 00
 D0   00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
 E0   00 00 00 00 00 00 00 00 00 00 00 00 25 49 32 FC
 F0   14 44 04 70 22 33 0D 06 37 D4 30 CE 1E CF 23 CE
PCI to PCI Bridge
bus 0 (0x00), device 1 (0x01), function 0 (0x00)
Common header
 Vendor ID  0x8086
 Model ID  0x3576
 Revision ID  0x02
 PI   0x00
 SubClass  0x04
 BaseClass  0x06
 Cache Line  0x00
 Latency   0x40
 Header   0x01
PCI header
 Primary bus  0x00
 Secondary bus  0x01
 Int. Line  0x00
 Int. Pin  0x00
Dump
 00   86 80 76 35 07 00 20 00 02 00 04 06 00 40 01 00
 10   00 00 00 00 00 00 00 00 00 01 01 00 30 30 A0 22
 20   20 40 20 40 00 48 F0 4F 00 00 00 00 00 00 00 00
 30   00 00 00 00 00 00 00 00 00 00 00 00 00 00 0C 00
 40   00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
 50   00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
 60   00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
 70   00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
 80   00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
 90   00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
 A0   00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
 B0   00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
 C0   00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
 E0   00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
 F0   00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
USB Controller (UHCI)
bus 0 (0x00), device 29 (0x1D), function 0 (0x00)
Common header
 Vendor ID  0x8086
 Model ID  0x2482
 Revision ID  0x01
 PI   0x00
 SubClass  0x03
 BaseClass  0x0C
 Cache Line  0x00
 Latency   0x00
 Header   0x80
PCI header
 Address 4 (port) 0x00004000
 Subvendor ID  0x0E11
 Subsystem ID  0x0030
 Int. Line  0x0B
 Int. Pin  0x01
Dump
 00   86 80 82 24 05 00 80 02 01 00 03 0C 00 00 80 00
 10   00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
 20   01 40 00 00 00 00 00 00 00 00 00 00 11 0E 30 00
 30   00 00 00 00 00 00 00 00 00 00 00 00 0B 01 00 00
 60   10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
 C0   00 2F 00 00 00 00 00 00 00 00 00 00 00 00 00 00
 F0   00 00 00 00 00 00 00 00 47 0F 00 00 00 00 00 00
bus 0 (0x00), device 29 (0x1D), function 1 (0x01)
Common header
 Vendor ID  0x8086
 Model ID  0x2484
 Revision ID  0x01
 PI   0x00
 SubClass  0x03
 BaseClass  0x0C
 Cache Line  0x00
 Latency   0x00
 Header   0x00
PCI header
 Address 4 (port) 0x00004020
 Subvendor ID  0x0E11
 Subsystem ID  0x0030
 Int. Line  0x0B
 Int. Pin  0x02
Dump
 00   86 80 84 24 05 00 80 02 01 00 03 0C 00 00 00 00
 20   21 40 00 00 00 00 00 00 00 00 00 00 11 0E 30 00
 30   00 00 00 00 00 00 00 00 00 00 00 00 0B 02 00 00
bus 0 (0x00), device 29 (0x1D), function 2 (0x02)
Common header
 Vendor ID  0x8086
 Model ID  0x2487
 Revision ID  0x01
 PI   0x00
 SubClass  0x03
 BaseClass  0x0C
 Cache Line  0x00
 Latency   0x00
 Header   0x00
PCI header
 Address 4 (port) 0x00004040
 Subvendor ID  0x0E11
 Subsystem ID  0x0030
 Int. Line  0x0B
 Int. Pin  0x03
Dump
 00   86 80 87 24 05 00 80 02 01 00 03 0C 00 00 00 00
 20   41 40 00 00 00 00 00 00 00 00 00 00 11 0E 30 00
 30   00 00 00 00 00 00 00 00 00 00 00 00 0B 03 00 00
PCI to PCI Bridge
bus 0 (0x00), device 30 (0x1E), function 0 (0x00)
Common header
 Vendor ID  0x8086
 Model ID  0x2448
 Revision ID  0x41
 PI   0x00
 SubClass  0x04
 BaseClass  0x06
 Cache Line  0x00
 Latency   0x00
 Header   0x01
PCI header
 Primary bus  0x00
 Secondary bus  0x02
 Int. Line  0x00
 Int. Pin  0x00
Dump
 00   86 80 48 24 07 00 80 00 41 00 04 06 00 00 01 00
 10   00 00 00 00 00 00 00 00 00 02 04 20 20 20 80 22
 20   00 40 10 40 F0 FF 00 00 00 00 00 00 00 00 00 00
 30   00 00 00 00 00 00 00 00 00 00 00 00 00 00 06 00
 40   02 28 20 20 00 00 00 00 00 00 00 00 00 00 00 00
 50   02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
 70   20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
 80   00 00 C4 00 00 00 00 00 00 00 00 00 00 00 00 00
 A0   10 00 08 00 00 00 00 00 00 00 00 00 00 00 00 00
 B0   01 00 02 00 00 00 C0 00 00 00 00 00 00 00 00 00
 F0   00 00 00 00 00 00 00 00 47 0F 00 00 00 00 5C 42
PCI to ISA Bridge
bus 0 (0x00), device 31 (0x1F), function 0 (0x00)
Common header
 Vendor ID  0x8086
 Model ID  0x248C
 Revision ID  0x01
 PI   0x00
 SubClass  0x01
 BaseClass  0x06
 Cache Line  0x00
 Latency   0x00
 Header   0x80
PCI header
 Subvendor ID  0x0000
 Subsystem ID  0x0000
 Int. Line  0x00
 Int. Pin  0x00
Dump
 00   86 80 8C 24 0F 01 80 02 01 00 01 06 00 00 80 00
 20   00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
 30   00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
 40   01 10 00 00 10 00 00 00 00 00 00 00 00 00 00 00
 50   00 00 00 00 00 00 00 00 01 11 00 00 10 00 00 00
 60   0B 0B 0B 0B 92 00 00 00 0B 0B 0B 80 00 00 00 00
 90   7D 54 00 00 00 00 00 00 00 00 00 00 00 00 00 00
 A0   0C 03 00 00 02 00 00 00 0D 00 00 00 00 00 00 00
 B0   00 00 00 00 00 00 00 00 0A 40 82 05 00 00 00 00
 C0   70 00 00 00 40 01 00 01 80 10 00 00 7F 07 00 00
 D0   07 20 00 02 02 07 00 00 04 00 00 00 00 00 00 00
 E0   70 00 00 C0 00 00 0E 3C 33 22 11 00 00 00 67 45
 F0   00 00 61 80 00 00 00 00 47 0F 0F 00 00 00 81 00
IDE Controller
bus 0 (0x00), device 31 (0x1F), function 1 (0x01)
Common header
 Vendor ID  0x8086
 Model ID  0x248A
 Revision ID  0x01
 PI   0x8A
 SubClass  0x01
 BaseClass  0x01
 Cache Line  0x00
 Latency   0x00
 Header   0x00
PCI header
 Address 4 (port) 0x00004060
 Address 5 (memory) 0xFFEFFC00
 Subvendor ID  0x0E11
 Subsystem ID  0x0030
 Int. Line  0x0B
 Int. Pin  0x01
Dump
 00   86 80 8A 24 07 00 80 02 01 8A 01 01 00 00 00 00
 10   01 00 00 00 01 00 00 00 01 00 00 00 01 00 00 00
 20   61 40 00 00 00 FC EF FF 00 00 00 00 11 0E 30 00
 40   07 A3 07 A3 00 00 00 00 05 00 01 02 00 00 00 00
 50   00 00 00 00 11 10 00 00 00 00 00 00 00 00 00 00
 60   08 00 00 00 00 00 00 00 08 00 00 00 00 00 00 00
SMBus Controller
bus 0 (0x00), device 31 (0x1F), function 3 (0x03)
Common header
 Vendor ID  0x8086
 Model ID  0x2483
 Revision ID  0x01
 PI   0x00
 SubClass  0x05
 BaseClass  0x0C
 Cache Line  0x00
 Latency   0x00
 Header   0x00
PCI header
 Address 4 (port) 0x00001200
 Subvendor ID  0x0E11
 Subsystem ID  0x0030
 Int. Line  0x00
 Int. Pin  0x02
Dump
 00   86 80 83 24 01 00 80 02 01 00 05 0C 00 00 00 00
 20   01 12 00 00 00 00 00 00 00 00 00 00 11 0E 30 00
 30   00 00 00 00 00 00 00 00 00 00 00 00 00 02 00 00
 40   05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
VGA Controller
bus 1 (0x01), device 0 (0x00), function 0 (0x00)
Common header
 Vendor ID  0x1002
 Model ID  0x4C59
 Revision ID  0x00
 PI   0x00
 SubClass  0x00
 BaseClass  0x03
 Cache Line  0x08
 Latency   0xFF
 Header   0x00
PCI header
 Address 0 (memory) 0x48000000
 Address 1 (port) 0x00003000
 Address 2 (memory) 0x40200000
 Subvendor ID  0x0E11
 Subsystem ID  0xB111
 Int. Line  0x0B
 Int. Pin  0x01
Capabilities
 AGP Capability
  Version  2.0
  Status  enabled
  Queue lenght 1 (max 48)
  Dump
  02 50 20 00 07 02 00 2F 04 03 00 1F
 Power Management Capability
  Version  1.1
  Dump
  01 00 02 06 00 00 00 00
Dump
 00   02 10 59 4C 87 00 B0 02 00 00 00 03 08 FF 00 00
 10   08 00 00 48 01 30 00 00 00 00 20 40 00 00 00 00
 20   00 00 00 00 00 00 00 00 00 00 00 00 11 0E 11 B1
 30   00 00 00 00 58 00 00 00 00 00 00 00 0B 01 08 00
 40   00 00 00 00 00 00 00 00 00 00 00 00 11 0E 11 B1
 50   01 00 02 06 00 00 00 00 02 50 20 00 07 02 00 2F
 60   04 03 00 1F 00 00 00 00 00 00 00 00 00 00 00 00
PCI to CardBus Bridge
bus 2 (0x02), device 3 (0x03), function 0 (0x00)
Common header
 Vendor ID  0x104C
 Model ID  0xAC51
 Revision ID  0x00
 PI   0x00
 SubClass  0x07
 BaseClass  0x06
 Cache Line  0x08
 Latency   0x42
 Header   0x82
PCI header
Capabilities
  Version  1.0
  Dump
  01 00 11 FE 00 00 C0 00
Dump
 00   4C 10 51 AC 07 00 10 02 00 00 07 06 08 42 82 00
 10   00 00 00 40 A0 00 00 02 02 03 03 00 00 E0 EF FF
 20   00 E0 EF FF 00 00 B0 FB 00 F0 AF FF 00 FE 00 00
 30   FC FE 00 00 00 FD 00 00 FC FD 00 00 0B 01 C0 00
 40   11 0E 4E 00 01 00 00 00 00 00 00 00 00 00 00 00
 80   60 90 44 28 00 00 00 00 00 00 00 00 02 10 00 01
 90   C0 22 64 60 00 00 00 00 00 00 00 00 00 00 00 00
 A0   01 00 11 FE 00 00 C0 00 00 00 00 00 1F 00 00 00
bus 2 (0x02), device 3 (0x03), function 1 (0x01)
Common header
 Vendor ID  0x104C
 Model ID  0xAC51
 Revision ID  0x00
 PI   0x00
 SubClass  0x07
 BaseClass  0x06
 Cache Line  0x08
 Latency   0x42
 Header   0x82
PCI header
Capabilities
  Version  1.0
  Dump
Dump
 10   00 00 08 40 A0 00 00 02 02 04 04 00 00 D0 EF FF
 20   00 D0 EF FF 00 00 B0 F7 00 F0 AF FB 00 FC 00 00
 30   FC FC 00 00 00 FA 00 00 FC FA 00 00 0B 01 C0 00
Communication Device
bus 2 (0x02), device 4 (0x04), function 0 (0x00)
Common header
 Vendor ID  0x11C1
 Model ID  0x0450
 Revision ID  0x02
 PI   0x00
 SubClass  0x80
 BaseClass  0x07
 Cache Line  0x00
 Latency   0x42
 Header   0x00
PCI header
 Address 0 (memory) 0x40180000
 Address 1 (port) 0x00002840
 Address 2 (port) 0x00002000
 Subvendor ID  0x1468
 Subsystem ID  0x0450
 Int. Line  0x0B
 Int. Pin  0x01
Capabilities
  Version  1.1
  Dump
  01 00 E2 E4 00 00 00 00
Dump
 00   C1 11 50 04 07 00 90 02 02 00 80 07 00 42 00 00
 10   00 00 18 40 41 28 00 00 01 20 00 00 00 00 00 00
 20   00 00 00 00 00 00 00 00 40 00 00 00 68 14 50 04
 30   00 00 00 00 F8 00 00 00 00 00 00 00 0B 01 FC 0E
 40   FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 50   FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 60   FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 70   FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 80   FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 90   FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 A0   FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 B0   FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 C0   FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 D0   FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 E0   FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 F0   FF FF FF FF 00 00 00 00 01 00 E2 E4 00 00 00 00
Ethernet Controller
bus 2 (0x02), device 8 (0x08), function 0 (0x00)
Common header
 Vendor ID  0x8086
 Model ID  0x1038
 Revision ID  0x41
 PI   0x00
 SubClass  0x00
 BaseClass  0x02
 Cache Line  0x08
 Latency   0x42
 Header   0x00
PCI header
 Address 0 (memory) 0x40100000
 Address 1 (port) 0x00002800
 Subvendor ID  0x0E11
 Subsystem ID  0x0098
 Int. Line  0x0B
 Int. Pin  0x01
Capabilities
  Version  1.1
  Dump
  01 00 22 FE 02 40 00 3A
Dump
 00   86 80 38 10 07 00 90 02 41 00 00 02 08 42 00 00
 10   00 00 10 40 01 28 00 00 00 00 00 00 00 00 00 00
 20   00 00 00 00 00 00 00 00 00 00 00 00 11 0E 98 00
 30   00 00 00 00 DC 00 00 00 00 00 00 00 0B 01 08 38
 D0   00 00 00 00 00 00 00 00 00 00 00 00 01 00 22 FE
 E0   02 40 00 3A 00 00 00 00 00 00 00 00 00 00 00 00
Audio device
bus 2 (0x02), device 9 (0x09), function 0 (0x00)
Common header
 Vendor ID  0x125D
 Model ID  0x1988
 Revision ID  0x12
 PI   0x00
 SubClass  0x01
 BaseClass  0x04
 Cache Line  0x00
 Latency   0x40
 Header   0x00
PCI header
 Address 0 (port) 0x00002400
 Subvendor ID  0x0E11
 Subsystem ID  0x0094
 Int. Line  0x0B
 Int. Pin  0x01
Capabilities
  Version  1.1
  Dump
  01 00 22 76 00 00 00 00
Dump
 00   5D 12 88 19 05 00 90 02 12 00 01 04 00 40 00 00
 10   01 24 00 00 00 00 00 00 00 00 00 00 00 00 00 00
 20   00 00 00 00 00 00 00 00 00 00 00 00 11 0E 94 00
 30   00 00 00 00 C0 00 00 00 00 00 00 00 0B 01 02 18
 40   60 90 00 00 00 00 00 00 00 00 00 00 00 00 00 00
 50   40 00 E0 0A 00 00 00 00 00 01 01 00 00 00 00 00
 60   00 00 00 00 00 00 00 00 00 00 00 00 11 0E 94 00
 C0   01 00 22 76 00 00 00 00 00 00 00 00 00 00 00 00
DMI
DMI BIOS
 vendor  Compaq
 version  686DF v2.49
 date  12/31/2003
DMI System Information
 manufacturer Compaq
 product  Evo N600c
 version  unknown
 dMI Baseboard
 vendor  Compaq
 model  0744
 revision unknown
 serial  unknown
DMI System Enclosure
 manufacturer Compaq
 chassis type Notebook
DMI Processor
 manufacturer Intel
 model  unknown
 clock speed 1066.0MHz
 FSB speed 133.0MHz
 multiplier 8.0x
DMI Extension Slot
 designation PC CARD-Slot 0
 type  PCMCIA
 width  32 bits
 populated no
DMI Extension Slot
 designation PC CARD-Slot 1
 type  PCMCIA
 width  32 bits
 populated no
DMI Physical Memory Array
 location Motherboard
 usage  System Memory
 correction None
 max capacity 310MBytes
 max# of devices 2
 usage  Flash Memory
 correction None
 max capacity 0MBytes
 max# of devices 1
DMI Memory Device
 designation DIMM #1
 format  unknown
 type  DRAM
 total width 64bits
 data width 64bits
 size  512MBytes
DMI Memory Device
 designation DIMM #2
 format  unknown
 type  DRAM
 total width 64bits
 data width 64bits
 size  512MBytes
DMI Memory Device
 designation 82802
 format  Chip
 type  FLASH
 total width 8bits
 data width 8bits
 size  0MBytes
Software
Windows Version  Microsoft Windows XP Professional  Service Pack 2 (Build 2600)
DirectX Version  9.0c
n°1470647
blackhawke​r
IWH and almost anywhere
Posté le 08-09-2006 à 07:35:32  profilanswer
overclocker un portable, c'est déjà pas une bonne idée alors un portable avec un p3 dedans...
ya 90% de truc inutile dans le rapport que t'as copié
si tu veux quand même o/c, il y a clockgen
n°1470986
Voyezzz
Posté le 08-09-2006 à 20:10:48  profilanswer
Je sais pas si c'est OC-able, mème si tu peu tu ne gagnera sans doute pas grand chose.
Le meilleur OC pour ton portable serai sans doute de remplacer le disque dur (qui est sans doute un 4200tpm) par un 5400 tpm ...
Tu vera bien plus la difference, qu'en gagnant 100Mhz sur ton P3...
Salut
n°1471118
alexandra3​7
Posté le 09-09-2006 à 01:10:42  profilanswer
slt...
pour repondre a blackhawker...j'ai deja essayer clockgen mais mon ecran reste figer,et j'ete obliger de redemarer a chaque foi,donc oubli clckgn...merci kn mm.
n°1471119
alexandra3​7
Posté le 09-09-2006 à 01:13:25  profilanswer
slt voyezzz..
merci pour ta reponse claire,ta raison pour le disque dur,efectivmen c 4200tpm...donc j sai pas si je laisse tomber...
n°1471122
Gigathlon
Quad-neurones natif
Posté le 09-09-2006 à 01:59:56  profilanswer
Avec un Tualatin tu pourra au mieux atteindre les 1.3-1.4, et ça dépend encore du refroidissement du portable...
Dans tous les cas si tu pouvais réduire un poil le descriptif hautement inutile des process/threads...
Message édité par Gigathlon le 09-09-2006 à 02:00:45
n°1471248
paulo-53
Posté le 09-09-2006 à 14:29:48  profilanswer
Si c'est bloqué par le BIOS, y'a peut etre une raison... :whistle:
Feed-back : http://tinyurl.com/kmwycda
n°1473610
Duncan le ​fremen
Quand on change le code...
Posté le 15-09-2006 à 12:00:04  profilanswer
Arf Voyezzz a raison, tu pourra rien en tiré de cette machine a part en la mettant dans un bain d'azote liquide...
Investi plutot dans du materiel AMD en socket 939; oui je sais y a mieu mais ça reste de l'excellent matos tres o/c-able et surtout vraiment pas chere depuis la sortie des AM2...
Donc amd 3000 ou 3200+, une A8N-E (y a DFI, mais si tu connais rien en o/c c'est plus simple mais aussi plus limité chez asus...), 1Go de ram genre kingston value (évite la corsair value c'est de la m****), une petite carte graphique style 6600GT... ça te fait un beau pc tout neuf qui déchire pour environ 400€ max...
et, en plus, là on pourra faire quelque chose pour toi! ;)
  CPU
comment overclocker une 7900 gtBesoin d'aid epour overclocker un Core 2 Duo ...
overclock du pentium d 805safe mode: le cauchemar, aider moi
overclocker un peut plus ma mdtOverclocker en étant pauvre
overclocker athlon 64 3000+ sur epoxOverclock limité sur Pentium D 805...
Temperature pentium D et changement de ventilateur
Plus de sujets relatifs à : aider moi a overclocker mon pentium!!! 1,6...
