7440 connectés
  Linux et OS Alternatifs
  Installation
  je trouve pas xfontsel
n°534890
EpoK
Let's burn
Posté le 06-08-2004 à 13:39:58  profilanswer
voila je suis sous mandrake 10 et je cherche xfontsel, il semble ne pas connaitre et urpmi xfontsel ne donne rien :/
n°534943
mikala
Souviens toi du 5 Novembre...
Posté le 06-08-2004 à 14:26:35  profilanswer
c'est un binaire ?
si oui il est dans X11R6-contrib
14:25 john@andrea ~% urpmf xfontsel
X11R6-contrib:/usr/X11R6/bin/xfontsel
X11R6-contrib:/usr/X11R6/man/man1/xfontsel.1x.bz2
Message édité par mikala le 06-08-2004 à 14:26:45
n°534959
EpoK
Let's burn
Posté le 06-08-2004 à 14:50:29  profilanswer
et c'est quoi X11R6-contrib  ?
n°534963
mikala
Posté le 06-08-2004 à 14:54:58  profilanswer
14:53 root@andrea ~# urpmq -i X11R6-contrib
extracting X11R6-contrib-6.7.0-0.0.10mdk.i586
Version     : 6.7.0
Release     : 0.0.10mdk
Group       : System/X11
Size        : 1097841                      Architecture: i586
Source RPM  : Xorg-x11-6.7.0-0.0.10mdk.src.rpm   Build Host: svetljo.lh.kicks-as
s.org
Packager    : Frederic Lepied <flepied@mandrakesoft.com>
URL         : http://www.x.org/
Summary     : A collection of user-contributed X Window System programs
Description :
If you want to install the X Window System (TM) on
your machine, you'll need to install XFree86.
The X Window System provides the base technology
for developing graphical user interfaces. Simply stated,
X draws the elements of the GUI on the user's screen and
builds methods for sending user interactions back to the
application. X also supports remote application deployment--running an
application on another computer while viewing the input/output
on your machine.  X is a powerful environment which supports
many different applications, such as games, programming tools,
graphics programs, text editors, etc.  XFree86 is the version of
X which runs on Linux, as well as other platforms.
This package contains the basic fonts, programs and documentation
for an X workstation.  You will also need the XFree86-server
package, which contains the program which drives your video
hardware.
In addition to installing this package, you will need to install the
drakxtools package to configure your card using XFdrake. You may also
need to install one of the XFree86 fonts packages.
And finally, if you are going to develop applications that run as
X clients, you will also need to install libxfree86-devel.
n°535091
Dark_Schne​ider
Close the World, Open the Net
Posté le 06-08-2004 à 19:57:49  profilanswer
http://linux-wizard.net/howto.php? [...] e=42#urpmi
apprends à utiliser urpmi & cie
Mandriva : parce que nous le valons bien ! http://linux-wizard.net/index.php
n°535384
EpoK
Let's burn
Posté le 07-08-2004 à 16:05:11  profilanswer
le probleme c'est que si je veux installer X11R6-contrib on me demande 70mo de dépendances alors que je voudrai juste le petit executable ...
n°536338
Dark_Schne​ider
Posté le 09-08-2004 à 15:13:32  profilanswer
EpoK> et oui que veux tu.
  Installation
Make ne trouve pas rhconfig.h[deb]Dans quel package se trouve dig ?
Hôte non trouvé[OoO] Ou se trouve le balai pour copier les styles comme sous Word
pb de son, pas trouvé de solutions sur le forumg++ ! pourquoi je l'ai pas ? et où je le trouve ?
[MDK9.2]Où se trouve le dossier du kernel ?Probleme d'installtion de kdevelop 3,lib berkeley non trouvé :/
mozilla 1.5 et onglets [Trouvé][MDK 9.2] PhpMyAdmin : où se trouve le fichier de configuration ?
Plus de sujets relatifs à : je trouve pas xfontsel
