Tue Nov 3 22:32:22 UTC 2020 Welcome to vtown, volkerdi's friendly takeover of alienBOB's ktown Plasma 5 packages! Enormous thanks are due to alienBOB for maintaining and leading testing of Plasma 5 on the side, even as I wore out his patience (and likely others as well). But now this has made it into /testing and it won't be all that long before it'll hit the main tree, so test it out and let me know if anything broke. Several packages have been given back their upstream names since there's no real reason to do otherwise unless we were going to support installing KDE4 at the same time, and we aren't. Qt4 won't even be sticking around, but probably slackbuilds.org will take it up. I dropped kaudiocreator (won't build), ktuberling and klettres (rather bloated for the probably limited appeal), user-manager (seems to have been dropped by upstream), kdelibs (KDE4 library, not going to support that), kwebkitpart, and kpat (not adding three new dependencies only used for a solitaire game). In addition, it's probable that digikam and its dependencies will be dropped. It's a great program, but in my opinion it's just a little too big (especially the source) to ship by default. To install the vtown packages, first you'll want to remove any KDE4 packages (the KDE and KDEI series in the main tree), any previous ktown packages from alienBOB, and then install all of the packages in vtown/deps and vtown/kde using upgradepkg --install-new. The previous advice on ConsoleKit2 was to remove it since we've switched to elogind, but if you've got the latest rc.M it shouldn't matter since ConsoleKit2 will not be started if elogind is installed. Speaking of elogind, you'll probably notice that once elogind is installed X or Wayland sessions will launch in the current console rather than on console 7. Regarding the build numbers, the one before _vtown_ is the build number that will be used when the merge to the main tree happens, and the one after _vtown_ is used in case any rebuilds need to happen while vtown is in /testing. That's about it for the notes on this one. Thanks again to alienBOB, and to my friends in the US - don't forget to vote. :-) l/poppler-20.11.0-x86_64-1.txz: Upgraded. Shared library .so-version bump. x/libinput-1.16.3-x86_64-1.txz: Upgraded. testing/packages/vtown/deps/QtAV-20200910_2a470d2a-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/deps/accountsservice-0.6.55-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/deps/cfitsio-3.49-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/deps/cryfs-0.10.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/deps/cryptopp-8.2.0-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/deps/dbus-1.12.20-x86_64-2_vtown_1.txz: Rebuilt. testing/packages/vtown/deps/dotconf-1.3-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/deps/dvdauthor-0.7.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/deps/eigen3-3.3.7-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/deps/elogind-243.7-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/deps/frei0r-plugins-1.7.0-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/deps/grantlee-5.2.0-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/deps/kdsoap-1.9.1-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/deps/lensfun-0.3.95-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/deps/libappindicator-12.10.0-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/deps/libburn-1.5.2.pl01-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/deps/libdbusmenu-16.04.0-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/deps/libdbusmenu-qt-0.9.3+16.04.20160218-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/deps/libdmtx-0.7.5-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/deps/libindicator-12.10.1-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/deps/libqalculate-3.14.0-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/deps/libsass-3.6.4-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/deps/mlt-6.22.1-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/deps/opencv-4.5.0-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/deps/phonon-4.11.1-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/deps/phonon-backend-gstreamer-4.10.0-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/deps/pipewire-0.3.13-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/deps/polkit-0.118-x86_64-2_vtown_1.txz: Rebuilt. testing/packages/vtown/deps/polkit-qt-1-0.113.0-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/deps/qrencode-4.1.1-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/deps/qtkeychain-0.11.1-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/deps/quazip-1.1-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/deps/rttr-0.9.6-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/deps/sassc-3.6.1-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/deps/speech-dispatcher-0.8.8-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/deps/vid.stab-20200916_e851e7b-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/akonadi-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/akonadi-calendar-20.08.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/akonadi-calendar-tools-20.08.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/akonadi-contacts-20.08.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/akonadi-import-wizard-20.08.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/akonadi-mime-20.08.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/akonadi-notes-20.08.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/akonadi-search-20.08.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/akonadiconsole-20.08.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/akregator-20.08.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/alkimia-8.0.4-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/analitza-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/ark-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/artikulate-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/attica-5.75.0-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/audiocd-kio-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/baloo-5.75.0-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/baloo-widgets-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/blinken-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/bluedevil-5.20.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/bluez-qt-5.75.0-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/bomber-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/bovo-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/breeze-5.20.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/breeze-grub-5.20.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/breeze-gtk-5.20.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/breeze-icons-5.75.0-noarch-1_vtown_1.txz: Added. testing/packages/vtown/kde/calendarsupport-20.08.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/calligra-3.2.1-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/calligraplan-3.2.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/cantor-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/cervisia-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/digikam-7.1.0-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/dolphin-20.08.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/dolphin-plugins-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/dragon-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/drkonqi-5.20.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/elisa-20.08.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/eventviews-20.08.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/extra-cmake-modules-5.75.0-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/falkon-3.1.0-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/ffmpegthumbs-20.08.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/filelight-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/frameworkintegration-5.75.0-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/granatier-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/grantlee-editor-20.08.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/grantleetheme-20.08.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/gwenview-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/incidenceeditor-20.08.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/juk-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/k3b-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/kactivities-5.75.0-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/kactivities-stats-5.75.0-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kactivitymanagerd-5.20.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kaddressbook-20.08.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kalarm-20.08.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kalarmcal-20.08.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kalgebra-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/kalzium-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/kamera-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/kamoso-20.08.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kanagram-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/kapidox-5.75.0-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kapman-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/kapptemplate-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/karchive-5.75.0-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kate-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/katomic-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/kauth-5.75.0-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kbackup-20.08.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kblackbox-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/kblocks-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/kbookmarks-5.75.0-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kbounce-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/kbreakout-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/kbruch-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/kcachegrind-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/kcalc-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/kcalendarcore-5.75.0-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kcalutils-20.08.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kcharselect-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/kcmutils-5.75.0-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kcodecs-5.75.0-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kcolorchooser-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/kcompletion-5.75.0-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kconfig-5.75.0-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kconfigwidgets-5.75.0-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kcontacts-5.75.0-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kcoreaddons-5.75.0-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kcrash-5.75.0-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kcron-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/kdav-5.75.0-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kdbusaddons-5.75.0-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kde-cli-tools-5.20.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kde-dev-scripts-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/kde-dev-utils-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/kde-gtk-config-5.20.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kdebugsettings-20.08.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kdeclarative-5.75.0-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kdeconnect-kde-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/kdecoration-5.20.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kded-5.75.0-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kdeedu-data-20.08.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kdegraphics-mobipocket-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/kdegraphics-thumbnailers-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/kdelibs4support-5.75.0-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kdenetwork-filesharing-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/kdenlive-20.08.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kdepim-addons-20.08.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kdepim-apps-libs-20.08.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kdepim-runtime-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/kdeplasma-addons-5.20.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/kdesdk-kioslaves-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/kdesdk-thumbnailers-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/kdesignerplugin-5.75.0-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kdesu-5.75.0-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kdev-php-5.6.0-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kdev-python-5.6.0-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/kdevelop-5.6.0-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/kdevelop-pg-qt-2.2.1-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/kdewebkit-5.75.0-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kdf-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/kdiagram-2.7.0-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kdialog-20.08.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kdiamond-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/kdnssd-5.75.0-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kdoctools-5.75.0-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/keditbookmarks-20.08.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kemoticons-5.75.0-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kfilemetadata-5.75.0-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/kfind-20.08.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kfloppy-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/kfourinline-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/kgamma5-5.20.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kgeography-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/kget-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/kglobalaccel-5.75.0-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kgoldrunner-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/kgpg-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/kguiaddons-5.75.0-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/khangman-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/khelpcenter-20.08.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kholidays-5.75.0-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/khotkeys-5.20.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/khtml-5.75.0-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/ki18n-5.75.0-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kiconthemes-5.75.0-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kid3-3.8.4-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kidentitymanagement-20.08.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kidletime-5.75.0-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kig-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/kigo-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/kile-2.9.93-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/killbots-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/kimageformats-5.75.0-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kimagemapeditor-20.08.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kimap-20.08.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kinfocenter-5.20.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kinit-5.75.0-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kio-5.75.0-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kio-extras-20.08.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kio-gdrive-20.08.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kipi-plugins-20.08.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kirigami-gallery-20.08.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kirigami2-5.75.0-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kiriki-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/kitemmodels-5.75.0-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kitemviews-5.75.0-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kiten-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/kitinerary-20.08.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kjobwidgets-5.75.0-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kjots-20200924_355b642-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kjs-5.75.0-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kjsembed-5.75.0-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kjumpingcube-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/kldap-20.08.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kleopatra-20.08.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/klickety-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/klines-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/kmag-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/kmahjongg-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/kmail-20.08.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kmail-account-wizard-20.08.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kmailtransport-20.08.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kmbox-20.08.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kmediaplayer-5.75.0-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kmenuedit-5.20.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kmime-20.08.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kmines-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/kmix-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/kmousetool-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/kmouth-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/kmplot-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/kmymoney-5.1.0-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/knavalbattle-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/knetwalk-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/knewstuff-5.75.0-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/knights-20.08.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/knotes-20.08.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/knotifications-5.75.0-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/knotifyconfig-5.75.0-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kolf-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/kollision-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/kolourpaint-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/kompare-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/konqueror-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/konquest-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/konsole-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/kontact-20.08.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kontactinterface-20.08.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kopete-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/korganizer-20.08.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kpackage-5.75.0-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kparts-5.75.0-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kpeople-5.75.0-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kpeoplevcard-0.1-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kpimtextedit-20.08.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kpkpass-20.08.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kplotting-5.75.0-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kpmcore-4.2.0-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kpty-5.75.0-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kqtquickcharts-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/kquickcharts-5.75.0-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/krdc-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/krename-5.0.1-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kreversi-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/krfb-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/krita-4.4.1-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kross-5.75.0-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kross-interpreters-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/kruler-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/krunner-5.75.0-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/krusader-2.7.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kscreen-5.20.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/kscreenlocker-5.20.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kservice-5.75.0-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kshisen-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/ksirk-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/ksmtp-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/ksnakeduel-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/kspaceduel-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/ksquares-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/ksshaskpass-5.20.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kstars-3.4.3-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/ksudoku-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/ksysguard-5.20.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/ksystemlog-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/kteatime-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/ktexteditor-5.75.0-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/ktextwidgets-5.75.0-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/ktimer-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/ktimetracker-5.0.1-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/ktnef-20.08.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/ktorrent-5.2.0-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/ktouch-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/kturtle-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/kubrick-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/kunitconversion-5.75.0-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kwallet-5.75.0-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kwallet-pam-5.20.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kwalletmanager-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/kwave-20.08.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kwayland-5.75.0-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kwayland-integration-5.20.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kwayland-server-5.20.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kwidgetsaddons-5.75.0-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kwin-5.20.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kwindowsystem-5.75.0-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kwordquiz-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/kwrited-5.20.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kxmlgui-5.75.0-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/kxmlrpcclient-5.75.0-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/latte-dock-0.9.11-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/libgravatar-20.08.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/libkcddb-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/libkcompactdisc-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/libkdcraw-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/libkdegames-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/libkdepim-20.08.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/libkeduvocdocument-20.08.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/libkexiv2-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/libkgapi-20.08.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/libkgeomap-20.08.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/libkipi-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/libkleo-20.08.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/libkmahjongg-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/libkomparediff2-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/libksane-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/libkscreen-5.20.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/libksieve-20.08.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/libksysguard-5.20.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/libktorrent-2.2.0-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/lokalize-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/lskat-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/mailcommon-20.08.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/mailimporter-20.08.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/marble-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/mbox-importer-20.08.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/messagelib-20.08.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/milou-5.20.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/minuet-20.08.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/modemmanager-qt-5.75.0-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/networkmanager-qt-5.75.0-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/okteta-0.26.4-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/okular-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/oxygen-5.20.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/oxygen-fonts-5.4.3-noarch-1_vtown_1.txz: Added. testing/packages/vtown/kde/oxygen-gtk2-1.4.6-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/oxygen-icons5-5.75.0-noarch-1_vtown_1.txz: Added. testing/packages/vtown/kde/palapeli-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/parley-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/partitionmanager-4.2.0-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/picmi-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/pim-data-exporter-20.08.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/pim-sieve-editor-20.08.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/pimcommon-20.08.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/plasma-browser-integration-5.20.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/plasma-desktop-5.20.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/plasma-disks-5.20.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/plasma-framework-5.75.0-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/plasma-integration-5.20.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/plasma-nm-5.20.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/plasma-pa-5.20.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/plasma-sdk-5.20.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/plasma-vault-5.20.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/plasma-wayland-protocols-1.1.1-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/plasma-workspace-5.20.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/plasma-workspace-wallpapers-5.20.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/polkit-kde-agent-1-5.20.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/powerdevil-5.20.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/poxml-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/print-manager-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/prison-5.75.0-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/pulseaudio-qt-1.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/purpose-5.75.0-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/qqc2-desktop-style-5.75.0-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/rocs-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/sddm-0.18.1-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/sddm-kcm-5.20.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/skanlite-2.2.0-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/solid-5.75.0-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/sonnet-5.75.0-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/spectacle-20.08.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/step-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/svgpart-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/sweeper-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/syndication-5.75.0-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/syntax-highlighting-5.75.0-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/systemsettings-5.20.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/threadweaver-5.75.0-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/umbrello-20.08.2-x86_64-1_vtown_1.txz: Upgraded. testing/packages/vtown/kde/wacomtablet-20201030_417d9d9-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/xdg-desktop-portal-kde-5.20.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/yakuake-20.08.2-x86_64-1_vtown_1.txz: Added. testing/packages/vtown/kde/zeroconf-ioslave-20.08.2-x86_64-1_vtown_1.txz: Upgraded. +--------------------------+ |
