5040 connectés
  Linux et OS Alternatifs
  Installation
  [Problème]RedHat9 & Speedtouch
n°461526
airv3
Des mecs com lui y en a pas 2
Posté le 22-04-2004 à 14:46:34  profilanswer
g suivi tous les tuto dispo pour installer ma raie verte sous ma RH 9.0...
tout ce passe bien je lance la commande pour charger le microcode pas de pb..(enfin apparement) je lance pppd call adsl et qd je ve aller sur le net....impossible voila une partie de mon fichier de log
Code :
  1. Apr 22 14:13:43 Pc-Herve modem_run[3656]: modem_run version 1.1 started by root uid 0
  2. Apr 22 14:13:45 Pc-Herve kernel: usb_control/bulk_msg: timeout
  3. Apr 22 14:13:45 Pc-Herve kernel: usbdevfs: USBDEVFS_BULK failed dev 2 ep 0x85 len 512 ret -110'\n'Apr 22 14:14:00 Pc-Herve modem_run[3656]: ADSL synchronization has been obtained
  4. Apr 22 14:14:00 Pc-Herve modem_run[3656]: ADSL line is up (608 kbit/s down | 160 kbit/s up)
  5. Apr 22 14:14:52 Pc-Herve kernel: CSLIP: code copyright 1989 Regents of the University of California
  6. Apr 22 14:14:52 Pc-Herve kernel: PPP generic driver version 2.4.2
  7. Apr 22 14:14:52 Pc-Herve pppd[3661]: pppd 2.4.1 started by root, uid 0
  8. Apr 22 14:14:52 Pc-Herve pppd[3661]: Couldn't get channel number: Input/output error
  9. Apr 22 14:14:52 Pc-Herve pppd[3661]: Using interface ppp0
  10. Apr 22 14:14:52 Pc-Herve pppd[3661]: Connect: ppp0 <--> /dev/pts/1
  11. Apr 22 14:14:52 Pc-Herve pppd[3661]: Modem hangup
  12. Apr 22 14:14:52 Pc-Herve pppd[3661]: Connection terminated.
  13. Apr 22 14:14:52 Pc-Herve pppd[3661]: Using interface ppp0
  14. Apr 22 14:14:52 Pc-Herve pppd[3661]: Connect: ppp0 <--> /dev/pts/1
  15. Apr 22 14:14:52 Pc-Herve pppd[3661]: Modem hangup
  16. Apr 22 14:14:52 Pc-Herve pppd[3661]: Connection terminated.
  17. Apr 22 14:14:52 Pc-Herve pppd[3661]: Using interface ppp0
  18. Apr 22 14:14:52 Pc-Herve pppd[3661]: Connect: ppp0 <--> /dev/pts/1
  19. Apr 22 14:14:52 Pc-Herve pppd[3661]: Modem hangup
  20. Apr 22 14:14:52 Pc-Herve /etc/hotplug/net.agent: assuming ppp0 is already up
  21. pr 22 14:14:53 Pc-Herve /etc/hotplug/net.agent: NET unregister event not supported
  22. Apr 22 14:14:53 Pc-Herve /etc/hotplug/net.agent: NET unregister event not supported
  23. Apr 22 14:14:53 Pc-Herve /etc/hotplug/net.agent: assuming ppp0 is already up
  24. Apr 22 14:14:53 Pc-Herve /etc/hotplug/net.agent: assuming ppp0 is already up
  25. Apr 22 14:14:53 Pc-Herve /etc/hotplug/net.agent: NET unregister event not supported
  26. Apr 22 14:14:53 Pc-Herve /etc/hotplug/net.agent: assuming ppp0 is already up
  27. Apr 22 14:14:53 Pc-Herve pppd[3661]: Using interface ppp0
  28. Apr 22 14:14:53 Pc-Herve pppd[3661]: Connect: ppp0 <--> /dev/pts/1
  29. Apr 22 14:14:53 Pc-Herve pppd[3661]: Modem hangup
  30. Apr 22 14:14:53 Pc-Herve pppd[3661]: Connection terminated.
  31. Apr 22 14:14:53 Pc-Herve /etc/hotplug/net.agent: NET unregister event not supported
  32. Apr 22 14:14:53 Pc-Herve pppd[3661]: Exit.
  33. Apr 22 14:14:53 Pc-Herve /etc/hotplug/net.agent: assuming ppp0 is already up
  34. Apr 22 14:14:53 Pc-Herve /etc/hotplug/net.agent: assuming ppp0 is already up
  35. Apr 22 14:14:53 Pc-Herve /etc/hotplug/net.agent: NET unregister event not supported
si qq'un a une idée avt ke je refoute la mdk :'( (que j'ai pas envie de remettre mais g besoin du net et de java vite... merci de votre aide
Message édité par airv3 le 22-04-2004 à 14:52:46
n°461543
airv3
Posté le 22-04-2004 à 15:02:31  profilanswer
j'ajoute qu'après tout çà je fais un ifconfig.... et pas d'interface ppp0
  Installation
[Zapping] Problème TV, j'ai le son mais pas l'image .... [Resolu][bash] probleme traitement fichier texte
Probleme avec heartbeat - Bide story[kopete] Probleme de connexion à msn
[Mandrake 9.2] Problème open office 1.1.1[noyau 2.6] problème mtrr
problème d'accès pop suite à l'installation mailscanner sur mdk9.2[Gentoo] problème pour démarrer interface réseau
Aide probleme avec les sources main_ftp,vlcmain etc...probleme dans horde
Plus de sujets relatifs à : [Problème]RedHat9 & Speedtouch
