3046 connectés
  Linux et OS Alternatifs
  Installation
  Les modules de Mandrake ...
n°292911
Moriaben
Posté le 16-07-2003 à 22:12:58  profilanswer
y'a un truc que je capte pas sous Mandrake 9.1
si je fais un lsmod j'obtiens ceci:
Code :
  1. [root@localhost benjamin]# lsmod
  2. Module                  Size  Used by    Not tainted
  3. sd_mod                 13100   0  (autoclean) (unused)
  4. sg                     34636   0  (autoclean)
  5. ide-floppy             15580   0  (autoclean)
  6. ide-tape               48304   0  (autoclean)
  7. parport_pc             25096   1  (autoclean)
  8. lp                      8096   0  (autoclean)
  9. parport                34176   1  (autoclean) [parport_pc lp]
  10. es1371                 29000   0
  11. ac97_codec             12488   0  [es1371]
  12. gameport                3316   0  [es1371]
  13. af_packet              14952   1  (autoclean)
  14. sr_mod                 16920   0  (autoclean)
  15. floppy                 55132   0
  16. tulip                  44032   1  (autoclean)
  17. supermount             15296   2  (autoclean)
  18. ide-cd                 33856   0
  19. cdrom                  31648   0  [sr_mod ide-cd]
  20. tuner                  11744   1  (autoclean)
  21. tvaudio                15068   0  (autoclean) (unused)
  22. bttv                   78496   0
  23. videodev                7872   2  [bttv]
  24. i2c-algo-bit            9064   1  [bttv]
  25. i2c-core               21192   0  [tuner tvaudio bttv i2c-algo-bit]
  26. soundcore               6276   0  [es1371 bttv]
  27. ide-scsi               11280   0
  28. scsi_mod              103284   4  [sd_mod sg sr_mod ide-scsi]
  29. usbmouse                2936   0  (unused)
  30. keybdev                 2720   0  (unused)
  31. mousedev                5268   1
  32. usbkbd                  4440   0  (unused)
  33. hid                    20900   0  (unused)
  34. input                   5664   0  [usbmouse keybdev mousedev usbkbd hid]
  35. usb-uhci               24652   0  (unused)
  36. usbcore                72992   1  [usbmouse usbkbd hid usb-uhci]
  37. rtc                     8060   0  (autoclean)
  38. ext3                   59916   2
  39. jbd                    38972   2  [ext3]
  40. [root@localhost benjamin]#
ça fait pas mal de modules vrai...
mais quand je regarde les fichiers /etc/modules et /etc/modules.conf
je n'ai que ceci:
Code :
  1. # /etc/modules: kernel modules to load at boot time.
  2. #
  3. # This file should contain the names of kernel modules that are
  4. # to be loaded at boot time, one per line.  Comments begin with
  5. # a `#', and everything on the line after them are ignored.
  6. scsi_hostadapter
  7. bttv
Code :
  1. probeall scsi_hostadapter ide-scsi
  2. probeall usb-interface usb-uhci
  3. alias eth0 tulip
  4. alias sound-slot-0 es1371
où sont tous les autres modules ??? j'aimerais bien virer des trucs comme rtc (je n'ai pas de modem). merci ;)
n°292914
HuGoBioS
Posté le 16-07-2003 à 22:20:36  profilanswer
rtc n'a rien a voir avec le modem c'est Real Time Clock ca sert a plein de trucs
-= In Kik00 101 I trust :o =-
n°292915
Moriaben
Posté le 16-07-2003 à 22:21:55  profilanswer
lol ok merci ;)
sinon tu sais pas où ils sont cachés ces modules (enfin leur fichier de config) ?
n°292918
HuGoBioS
Posté le 16-07-2003 à 22:31:23  profilanswer
je crois que c'st un chargement dynamique des qu'il y a besoin d'eux ... mais suis pas sur !
n°293034
Dark_Schne​ider
Close the World, Open the Net
Posté le 17-07-2003 à 13:03:34  profilanswer
pratiquement tout est en module sous mandrake, donc par example pour la carte son tu auras tout le tralala ( surtout si c'est alsa car support alsa + compatibilté OSS ).
+ port // + imprimante ? module ( partport_pc, lp )
+ souris/clavier USB ? module ( hid, usb-uhci, usbkbd, input, usbmouse )
+ graveur IDE ? module + émulation SCSI (ide-scsi , ide-cd, cdrom,sd_mod,sg )
+ disquette ? module ( floppy )
+ carte TV ? module + support i2c ( bttv ,tvaudio,tuner,videodev,i2c-core )
+ carte son avec puce ensoniq ? module + support AC97 ( soundcore, ac97_codec ,es1371 )
+ carte réseau avec puce générique ? module ( tulip )
+ port joystick ( intégré carte son ou carte mère ) ? module ( gameport )
+ système de fichier ext3 ? support ext3 en module + journal (jbd,  ext3 )
Mandriva : parce que nous le valons bien ! http://linux-wizard.net/index.php
n°293038
Moriaben
Posté le 17-07-2003 à 13:10:33  profilanswer
oui j'ai bien compris ça ;) mais je capte pas où se trouve le fichier de config qui dit de charger ces modules, car dans modules et modules.conf il n'y a pas toute cette liste de modules ;)
n°293044
Dark_Schne​ider
Posté le 17-07-2003 à 13:21:19  profilanswer
pas besoin. le noyau détecte le périphérique et charge le module comme un grand
n°745590
memaster
M.arc a volé mon 62
Posté le 27-10-2005 à 17:15:18  profilanswer
bizarre, j'ai un peu le meme pb sur mon portable (mdk10.0)
en init 3 (mode texte) 30Mo de ram sont utilisées, hors
mon portable n'a pas de lecteur cd, pas de carte tv et j'ai desactivé
volontairement la carte son, mais il me reste une liste hallucinante
de modules dont je ne suis pas sur qu'ils soient utiles.
je mettrais la liste ce soir, mais en gros j'aimerais bien en desactiver
quelques uns.
mon portable possède néanmoins :
port ir (que je ne pense pas utiliser)
modem rtc (que je ne pense pas utiliser non plus)
je mettrais la liste ce soir du lsmod et vous pourrez peut être
me dire ce que je peux virer. vu que j'ai 64Mo de ram seulement, j'aimerais
bien en libérer un peu.
n°745599
Dark_Schne​ider
Posté le 27-10-2005 à 17:56:12  profilanswer
je ne pense pas que tes 30Mo de RAM sont consomé par les modules. tu ferais mieux de faire un top puis SHIFT+M pour voir les process consommant le plus de RAM
n°745604
memaster
M.arc a volé mon 62
Posté le 27-10-2005 à 18:05:47  profilanswer
je regarderais également, mais j'avais rien vu de trop dans le top.
+ d'infos tout à l'heure
n°748117
memaster
M.arc a volé mon 62
Posté le 03-11-2005 à 11:49:42  profilanswer
bon
re
j'ai optimisé un peu l'occupation memoire (en mode console)
en virant 3 consoles mingetty 4, 5 & 6 (je n'utilise guere + de 3) et eteind tous les services inutiles :
atd, random
j'ai gagné 2Mo (c deja ça)
rappel : c'est un portable toshiba3110ct 64Mo bientot 128Mo :sweat:
n°748593
Dark_Schne​ider
Posté le 04-11-2005 à 14:48:39  profilanswer
tant que tu donnes pas le résultat de top trié pâr occupation mémoire, on ne peut rien pour toi.
idem pour le résultat de "ps -auxxx" afin desavoir ce qui tourne et pourrais être désactivé, notamment niveau services.
  Installation
Mandrake sur un SEUL CDMandrake 9.1 -> Lilo disparu impossible de booter
Mandrake Linux 9.1Son uniquement pour le root sous mandrake ... (permission groupe)
[LINUX] Jai mandrake 9.1 Impossible a l'installer !!!kde et mandrake
porbeleme dau demarrage de mandrake 9.1nouvel arrivant das le monde Linux (Mandrake 9.0) cherche de l'aide
Sous Mandrake 9.1, je veux installer GAIM, mais il me demande GTK 2.0.Probleme d'installation avec mandrake....
Plus de sujets relatifs à : Les modules de Mandrake ...
