8798 connectés
  Linux et OS Alternatifs
  Installation
  Locale sous Debian
Locale sous Debian
n°306541
lelfe
Posté le 13-08-2003 à 21:38:09  profilanswer
Salut
J'ai un problème, j'arrive pas à installer mes locales sous Debian testing.
Si je fais un dpkg-reconfigure locales, ca marche pour root, mais par pour les users, si je reboote, ca marche plus pour personne.
Je comprends pas ? :(
Lelfe
n°306615
apt-get
Posté le 14-08-2003 à 00:32:29  profilanswer
y'a quoi dans ton /etc/locale.gen ?
ta variable LANG est bien initialisée dans /etc/environment ?
n°306622
Goon
Posté le 14-08-2003 à 00:39:49  profilanswer
Ton paquet console-data est bien installé ?
n°306627
911GT3
en roue libre
Posté le 14-08-2003 à 00:51:52  profilanswer
utilises language-env:
Description: simple configuration tool for native language environment
 This tool adds basic settings for natural language environment such as
 LANG variable, font specifications, input methods, and so on into
 user's several dot-files such as .bashrc and .emacs.
 This version of language-env supports Belarusian, Bulgarian, Danish,
 French, German, Japanese, Korean, Macedonian, Polish, Russian, Serbian,
 Spanish, Thai, and Ukrainian.
Task: chinese-t, russian, spanish, french, japanese, german, cyrillic, chinese-s, polish
n°306991
lelfe
Posté le 14-08-2003 à 20:40:10  profilanswer
[lelfe@tanar ~]$ cat /etc/locale.gen
# This file lists locales that you wish to have built. You can find a list
# of valid supported locales at /usr/share/i18n/SUPPORTED. Other
# combinations are possible, but may not be well tested. If you change
# this file, you need to rerun locale-gen.
# XXX GENERATED XXX
# NOTE!!! If you change this file by hand, and want to continue
# maintaining manually, remove the above line. Otherwise, use the command
# "dpkg-reconfigure locales" to manipulate this file. You can manually
# change this file without affecting the use of debconf, however, since it
# does read in your changes.
en_US ISO-8859-1
fr_FR ISO-8859-1
fr_FR.UTF-8 UTF-8
fr_FR.UTF-8@euro UTF-8
fr_FR@euro ISO-8859-15
[lelfe@tanar ~]$ cat /etc/environment
GDK_USE_XFT=1
### BEGIN DEBCONF SECTION FOR localeconf
# Do not edit within this region if you want your changes to be preserved
# by debconf.  Instead, make changes before the "### BEGIN DEBCONF SECTION
# FOR localeconf" line, and/or after the "### END DEBCONF SECTION FOR
# localeconf" line.
### END DEBCONF SECTION FOR localeconf
LANG=fr_FR
[lelfe@tanar ~]$ dpkg -l "console-data"
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Installed/Config-files/Unpacked/Failed-config/Half-installed
|/ Err?=(none)/Hold/Reinst-required/X=both-problems (Status,Err: uppercase=bad)
||/ Name                 Version              Description
ii  console-data         2002.12.04dbs-14     Keymaps, fonts, charset maps, fallback tables for consol
Je pense que tout est normal la dedans ?
Lelfe
  Installation
  Locale sous Debian
Debian + upgrade package[Debian] passage python2.2 -> python2.3
[debian] impossible de monter le cdrom[debian Sarge] pb d'instalation module debian installer
[Debian] Windaube ne veut pas se lancer avec LILO ?!Meilleure Debian pour le modem sagem de free et des packages à jour
[Débian] woody ou Sarge ou Knoppix ? (pour découvrir..)[debian] startkde variable $DISPLAY not set ?
[debian] installer une carte son[debian] usb & ps2 = bug!
Plus de sujets relatifs à : Locale sous Debian
