3570 connectés
  Linux et OS Alternatifs
  Installation
  pb sb live+debian+alsa
n°326527
The Dml
pouet.. pouet ...
Posté le 17-09-2003 à 16:49:37  profilanswer
hello: !
j ai un petit pb de son sur ma debian, j ai suivi ce tuto :
http://trustonme.net/didactels/?rub=118
mais ca me semble pas marcher :/ ! par ex qd je lance tuxracer j ai pas de son et j ai un msg du type :
%%% tuxracer warning: Warning: Couldn't set 22050 Hz 16-bit audio
  Reason: No available audio device
pour aller plus vite je met un apercu de mon lsmod
nvidia               1630304  11  (autoclean)
snd-emu10k1            72004   0
snd-hwdep               5120   0  [snd-emu10k1]
snd-pcm                61220   0  [snd-emu10k1]
snd-page-alloc          6388   0  [snd-emu10k1 snd-pcm]
snd-timer              14468   0  [snd-pcm]
snd-rawmidi            13984   0  [snd-emu10k1]
snd-seq-device          4304   0  [snd-emu10k1 snd-rawmidi]
snd-util-mem            1392   0  [snd-emu10k1]
snd-ac97-codec         40632   0  [snd-emu10k1]
snd                    30180   0  [snd-emu10k1 snd-hwdep snd-pcm snd-timer snd-rawmidi snd-seq-device snd-util-mem snd-ac97-codec]
8139too                14728   1  (autoclean)
mii                     2464   0  (autoclean) [8139too]
crc32                   2880   0  (autoclean) [8139too]
usb-uhci               23280   0  (unused)
usbcore                62540   1  [usb-uhci]
et un lspci :
00:00.0 Host bridge: VIA Technologies, Inc. VT8366/A/7 [Apollo KT266/A/333]
00:01.0 PCI bridge: VIA Technologies, Inc. VT8366/A/7 [Apollo KT266/A/333 AGP]
00:08.0 Multimedia audio controller: Creative Labs SB Live! EMU10k1 (rev 04)
00:08.1 Input device controller: Creative Labs SB Live! MIDI/Game Port (rev 01)
00:09.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL-8139/8139C/8139C+ (rev 10)
00:11.0 ISA bridge: VIA Technologies, Inc. VT8233 PCI to ISA Bridge
00:11.1 IDE interface: VIA Technologies, Inc. VT82C586/B/686A/B PIPC Bus Master IDE (rev 06)
00:11.2 USB Controller: VIA Technologies, Inc. USB (rev 1b)
00:11.3 USB Controller: VIA Technologies, Inc. USB (rev 1b)
00:11.4 USB Controller: VIA Technologies, Inc. USB (rev 1b)
01:00.0 VGA compatible controller: nVidia Corporation NV15DDR [GeForce2 Ti] (rev a4)
pour info j ai une carte son integré que j ai désactivé mais qui ne l etait pas lors de l install de debian.et là je cherche a faire marcher ma sblive value.
merci de maider :) !
n°326558
Dark_Schne​ider
Close the World, Open the Net
Posté le 17-09-2003 à 17:24:02  profilanswer
tu peux faire voir ton modules.conf ?
Mandriva : parce que nous le valons bien ! http://linux-wizard.net/index.php
n°326578
The Dml
pouet.. pouet ...
Posté le 17-09-2003 à 17:54:34  profilanswer
alors voila mon modules.conf
### This file is automatically generated by update-modules"
# Please do not edit this file directly. If you want to change or add
# anything please take a look at the files in /etc/modutils and read
# the manpage for update-modules.
### update-modules: start processing /etc/modutils/0keep
# DO NOT MODIFY THIS FILE!
# This file is not marked as conffile to make sure if you upgrade modutils
# it will be restored in case some modifications have been made.
# The keep command is necessary to prevent insmod and friends from ignoring
# the builtin defaults of a path-statement is encountered. Until all other
# packages use the new `add path'-statement this keep-statement is essential
# to keep your system working
keep
### update-modules: end processing /etc/modutils/0keep
### update-modules: start processing /etc/modutils/actions
# Special actions that are needed for some modules
# The BTTV module does not load the tuner module automatically,
# so do that in here
post-install bttv insmod tuner
post-remove bttv rmmod tuner
### update-modules: end processing /etc/modutils/actions
### update-modules: start processing /etc/modutils/aliases
# Aliases to tell insmod/modprobe which modules to use
# Uncomment the network protocols you don't want loaded:
# alias net-pf-1 off  # Unix
# alias net-pf-2 off  # IPv4
# alias net-pf-3 off  # Amateur Radio AX.25
# alias net-pf-4 off  # IPX
# alias net-pf-5 off  # DDP / appletalk
# alias net-pf-6 off  # Amateur Radio NET/ROM
# alias net-pf-9 off  # X.25
# alias net-pf-10 off  # IPv6
# alias net-pf-11 off  # ROSE / Amateur Radio X.25 PLP
# alias net-pf-19 off  # Acorn Econet
alias char-major-10-175 agpgart
alias char-major-10-200 tun
alias char-major-81 bttv
alias char-major-108 ppp_generic
alias /dev/ppp  ppp_generic
alias tty-ldisc-3 ppp_async
alias tty-ldisc-14 ppp_synctty
alias ppp-compress-21 bsd_comp
alias ppp-compress-24 ppp_deflate
alias ppp-compress-26 ppp_deflate
# Crypto modules (see http://www.kerneli.org/)
alias loop-xfer-gen-0 loop_gen
alias loop-xfer-3 loop_fish2
alias loop-xfer-gen-10 loop_gen
alias cipher-2  des
alias cipher-3  fish2
alias cipher-4  blowfish
alias cipher-6  idea
alias cipher-7  serp6f
alias cipher-8  mars6
alias cipher-11  rc62
alias cipher-15  dfc2
alias cipher-16  rijndael
alias cipher-17  rc5
alias char-major-195 nvidia
### update-modules: end processing /etc/modutils/aliases
### update-modules: start processing /etc/modutils/alsa
### DEBCONF MAGIC
# This file was automatically generated by alsa-base's debconf stuff
alias char-major-116 snd
alias snd-card-0 snd-emu10k1
alias char-major-14 soundcore
alias sound-slot-0 snd-card-0
alias sound-service-0-0 snd-mixer-oss
alias sound-service-0-1 snd-seq-oss
alias sound-service-0-3 snd-pcm-oss
alias sound-service-0-8 snd-seq-oss
alias sound-service-0-12 snd-pcm-oss
### update-modules: end processing /etc/modutils/alsa
### update-modules: start processing /etc/modutils/paths
# This file contains a list of paths that modprobe should scan,
# beside the once that are compiled into the modutils tools
# themselves.
### update-modules: end processing /etc/modutils/paths
### update-modules: start processing /etc/modutils/ppp
### update-modules: end processing /etc/modutils/ppp
### update-modules: start processing /etc/modutils/reseau
alias eth0 8139too
### update-modules: end processing /etc/modutils/reseau
### update-modules: start processing /etc/modutils/setserial
# This is what I wanted to do, but logger is in /usr/bin, which isn't loaded
# when the module is first loaded into the kernel at boot time!
#post-install serial /etc/init.d/setserial start | logger -p daemon.info -t "setserial-module reload"
#pre-remove serial /etc/init.d/setserial stop | logger -p daemon.info -t "setserial-module uload"
alias /dev/tts          serial
alias /dev/tts/0        serial
alias /dev/tts/1        serial
alias /dev/tts/2        serial
alias /dev/tts/3        serial
post-install serial /etc/init.d/setserial modload > /dev/null 2> /dev/null
pre-remove serial /etc/init.d/setserial modsave  > /dev/null 2> /dev/null
### update-modules: end processing /etc/modutils/setserial
### update-modules: start processing /etc/modutils/arch/i386
alias parport_lowlevel parport_pc
alias char-major-10-144 nvram
alias binfmt-0064 binfmt_aout
alias char-major-10-135 rtc
### update-modules: end processing /etc/modutils/arch/i386
sinon j ai également ce message au chargement de kde en root :
Error while initializing the sound driver:
device /dev/dsp can't be opened (No such device)
The sound server will continue, using the null output device.
merci de m aider :)
Message édité par The Dml le 17-09-2003 à 17:58:33
n°326653
The Dml
pouet.. pouet ...
Posté le 17-09-2003 à 19:56:31  profilanswer
bon j ai en partit résolu le pb ! cependant j ai pas acces au son en user maisd que en root, pour xmms j ai un msg comme ca :
** WARNING **: alsa_setup_mixer(): Attaching to mixer hw:0 failed: Permission denied
Message: output format: 7
** WARNING **: alsa_setup(): Failed to open pcm device (default): Permission denied
une idée ?
Message édité par The Dml le 17-09-2003 à 19:56:46
n°326663
Dark_Schne​ider
Posté le 17-09-2003 à 20:19:20  profilanswer
> ls -l /dev/dsp
soit tu mets ton user dans le groupe audio, soit tu fais "chmod a+rw /dev/dsp"
n°326664
eL_Shaman_​__
Plop.
Posté le 17-09-2003 à 20:20:45  profilanswer
Pourquoi ne pas utiliser les paquets Debian ??!
C'est vivement recommendé quand même et pratique.
adduser toto audio
n°326666
The Dml
pouet.. pouet ...
Posté le 17-09-2003 à 20:25:06  profilanswer
cool merci bcp !
n°633855
brisssou
8-/
Posté le 09-02-2005 à 21:09:19  profilanswer
j'ai le même problème mais étrangement, je n'arrive pas a changer les droits de /dev/dsp !!?
ils restent comme ça :
lrwxr-xr-x  1 root audio      9 2005-02-09 19:56 /dev/dsp -> /dev/dsp0
j'ai beau faire des :
# chmod g+w /dev/dsp
rien n'y fait.... j'ai même supprimé et recréé le lien... mais que dal
comment ce faisse ?!
n°633870
John Boone
Juste quelques rayons...
Posté le 09-02-2005 à 22:07:22  profilanswer
paske c'est un lien, il faut sans doute aussi rendre accessible le fichier qui est pointé ?? ici /dev/dsp0
Mais adduser tonuser audio est ptet mieux aussi ?
n°634014
brisssou
8-/
Posté le 10-02-2005 à 11:10:10  profilanswer
le user dans audio, c'est fait, et c'est ok
mais /dev/dsp0 est déjà crw-rw----
chui plein de doutes là....
HFR - Mes sujets pour Chrome - Firefox - vérifie les nouveaux posts des topics suivis/favoris
  Installation
[gentoo] mes horloges partent en livenvidia geforce 2 mx & Debian
Debian 3 et php4.3 ?Compilation de Kopete 0.7.2 sous Debian
[Debian] gros newbie : prob de modemConnexion Free degroupe sur Debian Woody avec une Bewan PCI st
Hotplug me plante Alsa[Debian] Apache ki tue mes scripts perl au bout de 140s
[Debian] update via le net... sans accès au net[Debian & Fluxbox 0.9.6pre1] Problème de compilation
Plus de sujets relatifs à : pb sb live+debian+alsa
