bertty Ça ira | sebfun a écrit :
ben faudrait avoir les logs du xorg voir si ya un message d'erreur en rapport avec ton pilote j'avais pas fait gaffe que tu avais deja précisé que tu t'étais mis exprès en rendu software
Désolé du pavé ci-dessous
Code :
- [ 25.992] X.Org X Server 1.20.8 X Protocol Version 11, Revision 0
- [ 25.992] Build Operating System: Linux 4.4.0-184-generic x86_64 Ubuntu
- [ 25.992] Current Operating System: Linux VivoBook-X412DA 5.4.0-42-generic #46-Ubuntu SMP Fri Jul 10 00:24:02 UTC 2020 x86_64
- [ 25.992] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.4.0-42-generic root=UUID=c8d5bd4a-4f2c-4fa2-97e8-cadbe3509649 ro recovery nomodeset
- [ 25.992] Build Date: 24 June 2020 06:00:21AM
- [ 25.992] xorg-server 2:1.20.8-2ubuntu2.2 (For technical support please see http://www.ubuntu.com/support)
- [ 25.992] Current version of pixman: 0.38.4
- [ 25.992] Before reporting problems, check http://wiki.x.org to make sure that you have the latest version.
- [ 25.992] Markers: (--) probed, (**) from config file, (==) default setting, (++) from command line, (!!) notice, (II) informational, (WW) warning, (EE) error, (NI) not implemented, (??) unknown
- [ 26.102] (II) LoadModule: "vesa"
- [ 26.102] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
- [ 26.102] (II) Module vesa: vendor="X.Org Foundation"
- [ 26.102] compiled for 1.20.4, module version = 2.4.0
- [ 26.102] Module class: X.Org Video Driver
- [ 26.102] ABI class: X.Org Video Driver, version 24.0
- [ 26.102] (II) RADEON: Driver for ATI/AMD Radeon chipsets:
- [ 26.104] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
- [ 26.104] (II) FBDEV: driver for framebuffer: fbdev
- [ 26.104] (II) VESA: driver for VESA chipsets: vesa
- [ 26.111] xf86EnableIOPorts: failed to set IOPL for I/O (Operation not permitted)
- [ 26.111] (EE) open /dev/dri/card0: No such file or directory
- [ 26.111] (WW) Falling back to old probe method for modesetting
- [ 26.111] (II) Loading sub module "fbdevhw"
- [ 26.111] (II) LoadModule: "fbdevhw"
- [ 26.111] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
- [ 26.112] (II) Module fbdevhw: vendor="X.Org Foundation"
- [ 26.112] compiled for 1.20.8, module version = 0.0.2
- [ 26.112] ABI class: X.Org Video Driver, version 24.1
- [ 26.112] (**) FBDEV(1): claimed PCI slot 2@0:0:0
- [ 26.112] (II) FBDEV(1): using default device
- [ 26.112] (EE) Screen 0 deleted because of no matching config section.
- [ 26.112] (II) UnloadModule: "modesetting"
- [ 26.112] (II) FBDEV(0): Creating default Display subsection in Screen section "Default Screen Section" for depth/fbbpp 24/32
- [ 26.112] (==) FBDEV(0): Depth 24, (==) framebuffer bpp 32
- [ 26.112] (==) FBDEV(0): RGB weight 888
- [ 26.112] (==) FBDEV(0): Default visual is TrueColor
- [ 26.112] (==) FBDEV(0): Using gamma correction (1.0, 1.0, 1.0)
- [ 26.112] (II) FBDEV(0): hardware: EFI VGA (video memory: 8100kB)
- [ 26.112] (II) FBDEV(0): checking modes against framebuffer device...
- [ 26.112] (II) FBDEV(0): checking modes against monitor...
- [ 26.112] (II) FBDEV(0): Virtual size is 1920x1080 (pitch 1920)
- [ 26.112] (**) FBDEV(0): Built-in mode "current": 207.4 MHz, 85.3 kHz, 77.2 Hz
- [ 26.112] (II) FBDEV(0): Modeline "current"x0.0 207.38 1920 1952 2192 2432 1080 1084 1088 1104 -hsync -vsync -csync (85.3 kHz b)
- [ 26.112] (==) FBDEV(0): DPI set to (96, 96)
- [ 26.112] (II) Loading sub module "fb"
- [ 26.112] (II) LoadModule: "fb"
- [ 26.112] (II) Loading /usr/lib/xorg/modules/libfb.so
- [ 26.114] (II) Module fb: vendor="X.Org Foundation"
- [ 26.114] compiled for 1.20.8, module version = 1.0.0
- [ 26.114] ABI class: X.Org ANSI C Emulation, version 0.4
- [ 26.114] (**) FBDEV(0): using shadow framebuffer
- [ 26.114] (II) Loading sub module "shadow"
- [ 26.114] (II) LoadModule: "shadow"
- [ 26.114] (II) Loading /usr/lib/xorg/modules/libshadow.so
- [ 26.115] (II) Module shadow: vendor="X.Org Foundation"
- [ 26.115] compiled for 1.20.8, module version = 1.1.0
- [ 26.115] ABI class: X.Org ANSI C Emulation, version 0.4
- [ 26.115] (II) UnloadModule: "radeon"
- [ 26.115] (II) Unloading radeon
- [ 26.115] (II) UnloadModule: "vesa"
- [ 26.115] (II) Unloading vesa
- [ 26.115] (II) FBDEV(0): FBIOBLANK: Invalid argument (Screen blanking not supported by kernel - disabling)
- [ 26.118] (==) FBDEV(0): Backing store enabled
- [ 26.119] (==) FBDEV(0): DPMS enabled
- [ 26.119] (II) Initializing extension Generic Event Extension
- [ 26.120] (II) Initializing extension SHAPE
- [ 26.120] (II) Initializing extension MIT-SHM
- [ 26.120] (II) Initializing extension XInputExtension
- [ 26.120] (II) Initializing extension XTEST
- [ 26.121] (II) Initializing extension BIG-REQUESTS
- [ 26.121] (II) Initializing extension SYNC
- [ 26.121] (II) Initializing extension XKEYBOARD
- [ 26.121] (II) Initializing extension XC-MISC
- [ 26.121] (II) Initializing extension SECURITY
- [ 26.121] (II) Initializing extension XFIXES
- [ 26.122] (II) Initializing extension RENDER
- [ 26.122] (II) Initializing extension RANDR
- [ 26.122] (II) Initializing extension COMPOSITE
- [ 26.122] (II) Initializing extension DAMAGE
- [ 26.123] (II) Initializing extension MIT-SCREEN-SAVER
- [ 26.123] (II) Initializing extension DOUBLE-BUFFER
- [ 26.123] (II) Initializing extension RECORD
- [ 26.123] (II) Initializing extension DPMS
- [ 26.123] (II) Initializing extension Present
- [ 26.123] (II) Initializing extension DRI3
- [ 26.123] (II) Initializing extension X-Resource
- [ 26.123] (II) Initializing extension XVideo
- [ 26.124] (II) Initializing extension XVideo-MotionCompensation
- [ 26.124] (II) Initializing extension SELinux
- [ 26.124] (II) SELinux: Disabled on system
- [ 26.124] (II) Initializing extension GLX
- [ 26.124] (II) AIGLX: Screen 0 is not DRI2 capable
- [ 26.340] (II) IGLX: Loaded and initialized swrast
- [ 26.340] (II) GLX: Initialized DRISWRAST GL provider for screen 0
- [ 26.340] (II) Initializing extension XFree86-VidModeExtension
- [ 25.992] Markers: (--) probed, (**) from config file, (==) default setting, (++) from command line, (!!) notice, (II) informational, (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
- [ 25.992] (==) Log file: "/var/log/Xorg.0.log", Time: Wed Aug 12 08:08:51 2020
- [ 25.994] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
- [ 25.995] (==) No Layout section. Using the first Screen section.
- [ 25.995] (==) No screen section available. Using defaults.
- [ 25.995] (**) |-->Screen "Default Screen Section" (0)
- [ 25.995] (**) | |-->Monitor "<default monitor>"
- [ 25.996] (==) No monitor specified for screen "Default Screen Section". Using a default monitor configuration.
- [ 25.996] (==) Automatically adding devices
- [ 25.996] (==) Automatically enabling devices
- [ 25.996] (==) Automatically adding GPU devices
- [ 25.996] (==) Automatically binding GPU devices
- [ 25.996] (==) Max clients allowed: 256, resource mask: 0x1fffff
- [ 25.998] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
- [ 25.999] Entry deleted from font path.
- [ 26.000] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/X11/100dpi/".
- [ 26.000] Entry deleted from font path.
- [ 26.000] (Run 'mkfontdir' on "/usr/share/fonts/X11/100dpi/" ).
- [ 26.002] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/X11/75dpi/".
- [ 26.003] Entry deleted from font path.
- [ 26.003] (Run 'mkfontdir' on "/usr/share/fonts/X11/75dpi/" ).
- [ 26.003] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/X11/100dpi".
- [ 26.003] (Run 'mkfontdir' on "/usr/share/fonts/X11/100dpi" ).
- [ 26.003] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/X11/75dpi".
- [ 26.003] (Run 'mkfontdir' on "/usr/share/fonts/X11/75dpi" ).
- [ 26.003] (==) FontPath set to: /usr/share/fonts/X11/misc, /usr/share/fonts/X11/Type1, built-ins
- [ 26.003] (==) ModulePath set to "/usr/lib/xorg/modules"
- [ 26.003] (II) The server relies on udev to provide the list of input devices. If no devices become available, reconfigure udev or disable AutoAddDevices.
- [ 26.003] (II) Loader magic: 0x564dc3d69020
- [ 26.003] (II) Module ABI versions:
- [ 26.003] X.Org ANSI C Emulation: 0.4
- [ 26.003] X.Org Video Driver: 24.1
- [ 26.003] X.Org XInput driver : 24.1
- [ 26.003] X.Org Server Extension : 10.0
- [ 26.007] (++) using VT number 7
- [ 26.007] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
- [ 26.011] (--) PCI:*(2@0:0:0) 1002:15d8:1043:1831 rev 194, Mem @ 0xe0000000/268435456, 0xf0000000/2097152, 0xfe800000/524288, I/O @ 0x0000f000/256
- [ 26.012] (II) LoadModule: "glx"
- [ 26.013] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
- [ 26.026] (II) Module glx: vendor="X.Org Foundation"
- [ 26.026] compiled for 1.20.8, module version = 1.0.0
- [ 26.026] ABI class: X.Org Server Extension, version 10.0
- [ 26.026] (==) Matched ati as autoconfigured driver 0
- [ 26.026] (==) Matched modesetting as autoconfigured driver 1
- [ 26.026] (==) Matched fbdev as autoconfigured driver 2
- [ 26.026] (==) Matched vesa as autoconfigured driver 3
- [ 26.026] (==) Assigned the driver to the xf86ConfigLayout
- [ 26.026] (II) LoadModule: "ati"
- [ 26.027] (II) Loading /usr/lib/xorg/modules/drivers/ati_drv.so
- [ 26.027] (II) Module ati: vendor="X.Org Foundation"
- [ 26.027] compiled for 1.20.5, module version = 19.1.0
- [ 26.027] Module class: X.Org Video Driver
- [ 26.027] ABI class: X.Org Video Driver, version 24.0
- [ 26.095] (II) LoadModule: "radeon"
- [ 26.095] (II) Loading /usr/lib/xorg/modules/drivers/radeon_drv.so
- [ 26.100] (II) Module radeon: vendor="X.Org Foundation"
- [ 26.100] compiled for 1.20.5, module version = 19.1.0
- [ 26.100] Module class: X.Org Video Driver
- [ 26.100] ABI class: X.Org Video Driver, version 24.0
- [ 26.100] (II) LoadModule: "modesetting"
- [ 26.100] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
- [ 26.101] (II) Module modesetting: vendor="X.Org Foundation"
- [ 26.101] compiled for 1.20.8, module version = 1.20.8
- [ 26.101] Module class: X.Org Video Driver
- [ 26.101] ABI class: X.Org Video Driver, version 24.1
- [ 26.101] (II) LoadModule: "fbdev"
- [ 26.101] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
- [ 26.102] (II) Module fbdev: vendor="X.Org Foundation"
- [ 26.102] compiled for 1.20.1, module version = 0.5.0
- [ 26.340] (II) Initializing extension XFree86-DGA
- [ 26.340] (II) Initializing extension XFree86-DRI
- [ 26.341] (II) Initializing extension DRI2
| sebfun a écrit :
Code :
- Initramfs unpacking failed : Decoding failed
- pci 0000:00:00.2: AMD-Vi: Unable to read/write to IOMMU perf counter.
- tpm_crb MSFT0101:00: can't request region for resource [mem 0xdd4
pour l'erreur initramfs unpacking failed : regarde la https://forums.linuxmint.com/viewtopic.php?t=323152 la seconde ligne tu peux ignorer le problème apparemment
Fait, ça résout au moins ce problème là en effet ! Mais évidemment pas cette histoire d'accélérarion matérielle.
Message édité par bertty le 12-08-2020 à 08:49:22
