4939 connectés
  Linux et OS Alternatifs
  Installation
  Installer KDE sous RedHat [résolu]
n°250353
Giz
Posté le 16-04-2003 à 17:30:10  profilanswer
Après pas mal d'ennuis avec la gestion des dépendances pour installer KDE 3.x sous ma RedHat 8.0 (et donc installer quelques packages relatifs à KDE 3.x), j'ai décidé (comme on me l'a conseillé) d'installer le sublissime "apt" package.
Après avoir modifié mon fichier /etc/apt/sources.list, j'ai effectué
# apt-get update
puis pour installer KDE
# apt-get install kde
voici le résultat :
[root@localhost kroax]# apt-get install kde
Reading Package Lists... Done
Building Dependency Tree... Done
The following extra packages will be installed:
  kdebase mad-libs redhat-logos redhat-menus
The following packages will be upgraded
The following NEW packages will be installed:
  kde kdebase mad-libs
2 packages upgraded, 3 newly installed, 0 removed and 62 not upgraded.
Need to get 0B/20,9MB of archives.
After unpacking 39,3MB of additional disk space will be used.
Do you want to continue? [Y/n] y
Executing RPM (-Uvh)...
warning: /var/cache/apt/archives/redhat-menus_0.38-0.0.8.0_noarch.rpm: V3 DSA signature: NOKEY, key ID ff6382fa
Preparing...                ########################################### [100%]
        file /usr/bin/desktop-create-kmenu from install of kdebase-3.1-9.3.8.0 conflicts with file from package kdelibs-3.1.1-0.8x.3
E: Sub-process /bin/rpm returned an error code (7)
[root@localhost kroax]# rpm -e kdelibs-3.1.1-0.8x.3
error: Failed dependencies:
        libDCOP.so.4 is needed by (installed) kdegames-3.0.3-3
        libkdecore.so.4 is needed by (installed) kdegames-3.0.3-3
        libkdefx.so.4 is needed by (installed) kdegames-3.0.3-3
        libkdeprint.so.4 is needed by (installed) kdegames-3.0.3-3
        libkdesu.so.4 is needed by (installed) kdegames-3.0.3-3
        libkdeui.so.4 is needed by (installed) kdegames-3.0.3-3
        libkio.so.4 is needed by (installed) kdegames-3.0.3-3
        libkparts.so.2 is needed by (installed) kdegames-3.0.3-3
        kdelibs = 6:3.1.1-0.8x.3 is needed by (installed) kdelibs-devel-3.1.1-0.8x.3
Que faire ?  :cry:
Message édité par Giz le 17-04-2003 à 01:28:49
n°250429
Giz
Posté le 16-04-2003 à 20:50:30  profilanswer
Pas d'idées ?  :sweat:
n°250561
Giz
Posté le 17-04-2003 à 01:26:04  profilanswer
ouf ! [:thraell]
un chti :
apt-get --purge remove kdelibs
puis de nouveau
apt-get install kde
et ça roulezzzzzzzzzzzz !  :sol:
apt c'est de la balle !  :bounce:
PS: encore merci à BMOTheKiller pour apt !  [:giz]
Message édité par Giz le 17-04-2003 à 01:27:22
  Installation
Pb d'installation de gtk-2.2.0 [résolu]automatiser le lancement au démarage de fluxbox [ résolu ]
KDE, balancer des fenêtres d'un bureau à l'autreInstaller Nunux sur le mm HD que Windows
[KDE] Kde + Sid = pbNTFS sous RedHat 9 [big n00b]
J'ai un problème pour installer Zsnes ![RESOLU] quel est le nom de ce logiciel ???
cmt installer driver pwc pour webcam philips toucam fun 730K ?[Debian] Apache [Rasuré][RESOLU]
Plus de sujets relatifs à : Installer KDE sous RedHat [résolu]
