7465 connectés
  Linux et OS Alternatifs
  Installation
  [sagem fast800] install drivers eagle 1.04
n°378052
Riot
Buy me a riot
Posté le 21-12-2003 à 16:39:18  profilanswer
bjr a tous!
j'essaie d'installer ce f****ing driver (www.eagle-usb.fr.st) 1.04e ou 1.04 pour ma mdk9.0 seulement il y a une erreur dans le make:
/usr/local/src/eagle-1.0.4e> make
scripts/checkSystem && \
make -C driver && \
make -C pppoa && \
make -C scripts
make[1]: Entre dans le r%/1??iso8859-15épertoire `/usr/local/src/eagle-1.0.4e/driver'
make[2]: Entre dans le r%/1??iso8859-15épertoire `/usr/local/src/eagle-1.0.4e/driver'
gcc -DLINUX -D__KERNEL__ -DMODULE -I/usr/src/linux/include '-DADIDRIVERVERSION="1.0.4"' -Wall -Wstrict-prototypes -fomit-frame-pointer -fno-strict-aliasing -pipe  -mpreferred-stack-boundary=2 -O2 -M *.c > .depend
In file included from Adiutil.h:29,
                 from AdiUsbAdslDriver.c:32:
/usr/src/linux/include/linux/config.h:4:28: linux/autoconf.h: No such file or directory
                 from Boot.c:27:
                 from Crc.c:29:
                 from Dsp.c:29:
                 from Me.c:123:
                 from Mpoa.c:27:
                 from Msg.c:31:
                 from Oam.c:20:
                 from Pipes.c:27:
                 from Sar.c:27:
                 from Sm.c:25:
                 from Uni.c:27:
                 from Util.c:27:
                 from Zaps.c:16:
make[2]: *** [dep] Erreur 1
make[2]: Quitte le r%/1??iso8859-15épertoire `/usr/local/src/eagle-1.0.4e/driver'
gcc -DLINUX -D__KERNEL__ -DMODULE -I/usr/src/linux/include '-DADIDRIVERVERSION="1.0.4"' -Wall -Wstrict-prototypes -fomit-frame-pointer -fno-strict-aliasing -pipe  -mpreferred-stack-boundary=2 -O2   -c -o AdiUsbAdslDriver.o AdiUsbAdslDriver.c
In file included from /usr/src/linux/include/linux/prefetch.h:13,
                 from /usr/src/linux/include/linux/list.h:6,
                 from /usr/src/linux/include/linux/wait.h:14,
                 from /usr/src/linux/include/linux/fs.h:12,
                 from /usr/src/linux/include/linux/capability.h:17,
                 from /usr/src/linux/include/linux/binfmts.h:6,
                 from /usr/src/linux/include/linux/sched.h:9,
                 from /usr/src/linux/include/linux/mm.h:4,
                 from /usr/src/linux/include/linux/slab.h:14,
                 from Adiutil.h:39,
/usr/src/linux/include/asm/processor.h:56: `CONFIG_X86_L1_CACHE_SHIFT' undeclared here (not in a function)
/usr/src/linux/include/asm/processor.h:56: requested alignment is not a constant
In file included from /usr/src/linux/include/asm/hardirq.h:6,
                 from /usr/src/linux/include/linux/interrupt.h:45,
                 from /usr/src/linux/include/linux/usb.h:139,
                 from Adiutil.h:41,
/usr/src/linux/include/linux/irq.h:65: `CONFIG_X86_L1_CACHE_SHIFT' undeclared here (not in a function)
/usr/src/linux/include/linux/irq.h:65: requested alignment is not a constant
In file included from /usr/src/linux/include/linux/interrupt.h:45,
                 from Adiutil.h:41,
/usr/src/linux/include/asm/hardirq.h:16: `CONFIG_X86_L1_CACHE_SHIFT' undeclared here (not in a function)
/usr/src/linux/include/asm/hardirq.h:16: requested alignment is not a constant
In file included from /usr/src/linux/include/linux/usb.h:139,
                 from Adiutil.h:41,
/usr/src/linux/include/linux/interrupt.h:128: `CONFIG_X86_L1_CACHE_SHIFT' undeclared here (not in a function)
/usr/src/linux/include/linux/interrupt.h:128: requested alignment is not a constant
In file included from Adiutil.h:45,
/usr/src/linux/include/linux/netdevice.h:165: `CONFIG_X86_L1_CACHE_SHIFT' undeclared here (not in a function)
/usr/src/linux/include/linux/netdevice.h:165: requested alignment is not a constant
/usr/src/linux/include/linux/netdevice.h:497: `CONFIG_X86_L1_CACHE_SHIFT' undeclared here (not in a function)
/usr/src/linux/include/linux/netdevice.h:497: requested alignment is not a constant
make[1]: *** [AdiUsbAdslDriver.o] Erreur 1
make[1]: Quitte le r%/1??iso8859-15épertoire `/usr/local/src/eagle-1.0.4e/driver'
make: *** [build] Erreur 2
...dsl pour la longueur...
j'ai suivi les tutos de ce site, ainsi que celui de lea-linux...
(le lsmod est bon)
"linux/autoconf.h: No such file or directory" pourtant g bien installé le package autoconf
de + les kernel-source sont bien installées...
Une idée???
merci d'avance
Message édité par Riot le 21-12-2003 à 16:41:36
n°378057
Goon
Posté le 21-12-2003 à 16:47:52  profilanswer
tu as bien un lien symbolique /usr/src/linux ?
Ca renvoie bien à un kernel qui a été compilé ? Chez moi ça marchait pas si je me contentais de détarrer les sources, fallait que je le compile.
n°378103
XDMJ
Posté le 21-12-2003 à 18:45:27  profilanswer
sinon sur la cooker (et surement la 9.2) y'a un paquage précompilé (adiusbadsl) qui marche très bien ... la preuve
n°378182
Riot
Buy me a riot
Posté le 21-12-2003 à 21:11:57  profilanswer
merci de vous etre pencher sur le sujet, mais en fait il semblerait que les kernel-sources se soient mal installées...
je les ai don c désinstallées puis réinstallées, et la ça marche!
merci encore
  Installation
[ Mandrake 9.2 ] Y-a du précompilé pour les drivers Nvidia ?[carte rézo] drivers Nforce2 ?
Install Karchiver : libjpeg not foundProblème après l'install de grub
[DEBIAN] Drivers ac97 dans la recompilation du noyau?[MDK 9.2]Probleme install du jdk
[debian] lien pour télécharger l'iso net install "sarge" pour s-ata ?problème install mandrake 9.2, écran bleu !!
[Mandrake 9.2] CD non detecté a l'install sur mon portable dellErreur Install Oracle 8.1.6
Plus de sujets relatifs à : [sagem fast800] install drivers eagle 1.04
