8197 connectés
  Linux et OS Alternatifs
  Installation
  Dell 2005fpw xorg.conf pour fglrx et ati drivers
n°768869
etan
Posté le 07-01-2006 à 17:22:10  profilanswer
Bonjour, j'utilise un dell 2005 fpw en dual display, et je n'arrive pas a monter au dessus de 1280 x 1024, j'ai vu déjà quelques posts sur les forums d'ubuntu sur le dell 2005 fpw, mais je n'ai pas reussi à augmenter ma resolution.
Mon xorg.conf est issu de fglrxconfig et j'ai apres mis à jour a la main la resolution demandee a 1600x1050 mais il ne monte pas a cette resolution.
Merci d'avance
extrait de mon xorg.conf
Section "Screen"
    Identifier  "Screen1"
    Device      "ATI Graphics Adapter connector 1"
    Monitor     "Monitor1"
    DefaultDepth 24
    #Option "backingstore"
    Subsection "Display"
        Depth       24
        Modes       "1680x1050"
        ViewPort    0 0  # initial origin if mode is smaller than desktop
#        Virtual     1280 1024
    EndSubsection
EndSection
extrait de mon Xorg.log:
(II) fglrx(0): Connected Display1: CRT on primary DAC
(II) fglrx(0): Display1 EDID data ---------------------------
(II) fglrx(0): Manufacturer: DEL  Model: e008  Serial#: 809913164
(II) fglrx(0): Year: 2005  Week: 47
(II) fglrx(0): EDID Version: 1.3
(II) fglrx(0): Analog Display Input,  Input Voltage Level: 0.700/0.700 V
(II) fglrx(0): Sync:  Separate  Composite  SyncOnGreen
(II) fglrx(0): Max H-Image Size [cm]: horiz.: 43  vert.: 27
(II) fglrx(0): Gamma: 2.20
(II) fglrx(0): DPMS capabilities: StandBy Suspend Off; RGB/Color Display
(II) fglrx(0): First detailed timing is preferred mode
(II) fglrx(0): redX: 0.637 redY: 0.340   greenX: 0.297 greenY: 0.610
(II) fglrx(0): blueX: 0.146 blueY: 0.071   whiteX: 0.313 whiteY: 0.329
(II) fglrx(0): Supported VESA Video Modes:
(II) fglrx(0): 720x400@70Hz
(II) fglrx(0): 640x480@60Hz
(II) fglrx(0): 640x480@75Hz
(II) fglrx(0): 800x600@60Hz
(II) fglrx(0): 800x600@75Hz
(II) fglrx(0): 1024x768@60Hz
(II) fglrx(0): 1024x768@75Hz
(II) fglrx(0): 1280x1024@75Hz
(II) fglrx(0): Manufacturer's mask: 0
(II) fglrx(0): Supported Future Video Modes:
(II) fglrx(0): #0: hsize: 1280  vsize 1024  refresh: 60  vid: 32897
(II) fglrx(0): #1: hsize: 1152  vsize 864  refresh: 75  vid: 20337
(II) fglrx(0): Supported additional Video Mode:
(II) fglrx(0): clock: 146.2 MHz   Image Size:  434 x 270 mm
(II) fglrx(0): h_active: 1680  h_sync: 1784  h_sync_end 1960 h_blank_end 2240 h_border: 0
(II) fglrx(0): v_active: 1050  v_sync: 1053  v_sync_end 1059 v_blanking: 1089 v_border: 0
(II) fglrx(0): Serial No: P65375BN0FKL
(II) fglrx(0): Ranges: V min: 56  V max: 75 Hz, H min: 30  H max: 83 kHz, PixClock max 150 MHz
(II) fglrx(0): Monitor name: DELL 2005FPW
(II) fglrx(0): End of Display1 EDID data --------------------
Message édité par etan le 27-02-2006 à 14:16:49
n°768876
mirtouf
Light is right !
Posté le 07-01-2006 à 17:34:30  profilanswer
fais une rcherche sur les modelines.
sinon plains-toi des drivers. :D
n°768881
etan
Posté le 07-01-2006 à 17:51:15  profilanswer
Justement sur internet j'ai trouvé pleins de modeline différents pour cet ecran.
Mais je n'ai pas reussi a les faire fonctionner :/
n°768893
docwario
Alea jacta est
Posté le 07-01-2006 à 18:35:36  profilanswer
étant moi-même un heureux possesseur de ce superbe écran (auto-flattage d'égo :p)
tu n'as pas besoin des modelines.
normallement tu as juste besoin de spécifier les fréquences de rafraichissement dans la section "Monitor". (HorizSync et VertRefresh)
ensuite, quel distro utilises-tu ? Ubuntu 5.10 ? Si oui, sache qu'il y un bug avec les drivers ati disponible depuis synaptic, et là tu es obligé d'utiliser une modeline, mais, si tu fais l'install à la main (en récupérant le driver depuis le site d'ati), il y a un paramètre à donner l'installeur pour corriger ca.
bon après je n'ai jamais essayé en dual-display ...
n°768911
etan
Posté le 07-01-2006 à 19:25:28  profilanswer
Salut, effectivement j'ai une ubuntu 5.10
j'ai installé le driver fglrx et j'ai configuré mon xorg.conf sur la base de fglrxconfig
pourrais-tu m'indiquer les données que tu a mis pour la synchro ?
n°768924
docwario
Alea jacta est
Posté le 07-01-2006 à 19:59:34  profilanswer
Tiré du site de Dell :
Dell 2005FPW :
HorizSync 30-83
VertRefresh 56-75
si tu dois utilisez des modelines, n'ai pas peur, tu ne vas pas "casser" ton écran, il est suffisament solide ;)
Je veux dire qu'il t'enverra chier avec avec un "out of range".
Je te conseille vivement d'ajouter le mode "1280x1024" en plus du 1680x1050, parceque s'il n'arrive pas à afficher il retombera sur le 1280.
Sinon, perso j'ai essayé différentes modelines et certaines donnaient des fréquences bizarres (genre 59Hz).
Message édité par docwario le 07-01-2006 à 20:00:59
n°787165
etan
Posté le 27-02-2006 à 14:22:02  profilanswer
Merci pour les infos avec fglrx c'est niquel seulement voilà désormais j'essaye de brancher l'écran sur une base de portable IBM X31 et sur le x31 je ne peut pas installer les drivers fglrx il me semble : carte trop ancienne.
J'ai bien rajouté le VertRefresh et le Horizsync dans Monitor mais il m'affiche :
(II) RADEON(0): Not using default mode "1680x1050" (width too large for virtual size)
La résolution de base du x31 est de 1024x768.
Auriez vous une idée ?
P.S: sur windows aucun probleme
merci d'avance
  Installation
[Resolu] LFS + Radeon + drivers ATI + XorgInstaller les drivers NVIDIA sur une mandriva LE 2005
[Sécurite] [Signature] Configuration d'apache 2 Fichier httpd.confQuestion post-installation des drivers video NVIDIA
lilo.conf[Urgent] Dell Dimension 5000 et Linux!
NAS Dell et DebianPb installation drivers ATI sous XP 64
problème lors de l'installation des drivers nVidia
Plus de sujets relatifs à : Dell 2005fpw xorg.conf pour fglrx et ati drivers
