4816 connectés
  Linux et OS Alternatifs
  Installation
  [pb] controleur pcmcia sous redhat 9
n°275951
gountar
vive les chats et corbier
Posté le 11-06-2003 à 13:11:45  profilanswer
slt !
voila
g un petit prob avec mon controleur pcmcia sous ma redaht 9 il ne marche pas surement du a un prob de modules
en balancant un lsmod g ca lspci
00:00.0 Host bridge: VIA Technologies, Inc. VT8363/8365 [KT133/KM133] (rev 80)
00:01.0 PCI bridge: VIA Technologies, Inc. VT8363/8365 [KT133/KM133 AGP]
00:08.0 CardBus bridge: ENE Technology Inc CB1410 Cardbus Controller
00:11.0 ISA bridge: VIA Technologies, Inc. VT8231 [PCI-to-ISA Bridge] (rev 10)
00:11.1 IDE interface: VIA Technologies, Inc. VT82C586/B/686A/B PIPC Bus Master IDE (rev 06)
00:11.2 USB Controller: VIA Technologies, Inc. USB (rev 1e)
00:11.3 USB Controller: VIA Technologies, Inc. USB (rev 1e)
00:11.4 Bridge: VIA Technologies, Inc. VT8235 ACPI (rev 10)
00:11.5 Multimedia audio controller: VIA Technologies, Inc. VT82C686 AC97 Audio Controller (rev 40)
00:11.6 Communication controller: VIA Technologies, Inc. Intel 537 [AC97 Modem] (rev 20)
00:12.0 Ethernet controller: VIA Technologies, Inc. VT6102 [Rhine-II] (rev 51)
01:00.0 VGA compatible controller: S3 Inc. VT8636A [ProSavage KN133] AGP4X VGA Controller (TwisterK) (rev 01)
je pense ke la ligne
correspond a ma carte pcmcia
et biensur kan je lance le service :
/etc/init.d/pcmcia start
Starting PCMCIA services: /lib/modules/2.4.20-8/kernel/drivers/pcmcia/ds.o: init_module: Operation not permitted
Hint: insmod errors can be caused by incorrect module parameters, including invalid IO or IRQ parameters.
      You may find more information in syslog or the output from dmesg
/lib/modules/2.4.20-8/kernel/drivers/pcmcia/ds.o: insmod /lib/modules/2.4.20-8/kernel/drivers/pcmcia/ds.o failed
/lib/modules/2.4.20-8/kernel/drivers/pcmcia/ds.o: insmod ds failed
c plante
si kelkun vois koi faire pour le faire marcher ca serait cool
merci davance
n°276139
gountar
Posté le 11-06-2003 à 16:59:32  profilanswer
up  :bounce:
n°276536
gountar
Posté le 12-06-2003 à 12:16:37  profilanswer
up
  Installation
[REDHAT AS] kel type de licences ??Problème de modprobe avec RedHat 8.0
[gentoo] lancer le réseau par une carte pcmcia au bootpb RedHat 9 sur presario : firewire
[REDHAT] Bewan ADSL (Unicorn) & RedHat 2.4.20.xxxLinux Redhat 9 cd3
RedHat et dépendances...PCMCIA 2.5.70
problème d'install Soldier of Fortune sous Redhat 8.0On fait comment pour partager des fichiers sous RedHat 6.2
Plus de sujets relatifs à : [pb] controleur pcmcia sous redhat 9
