10324 connectés
  Linux et OS Alternatifs
  Installation
  comment rajouter une ligne pr ma Suse dans grub
n°742563
xadawa
Put1 2 Pc 2 MrDeeuuuhhh !!!
Posté le 19-10-2005 à 21:24:10  profilanswer
Salut, je cherche à rajouter une ligne dans Grub pour lancer ma Suse ... Voici quelques fichiers qui pourront vous servir pr m'aider :
xadawa@debian:/boot/grub$ cat menu.lst
# menu.lst - See: grub(8), info grub, update-grub(8)
#            grub-install(8), grub-floppy(8),
#            grub-md5-crypt, /usr/share/doc/grub
#            and /usr/share/doc/grub-doc/.
## default num
# Set the default entry to the entry number NUM. Numbering starts from 0, and
# the entry number 0 is the default if the command is not used.
# You can specify 'saved' instead of a number. In this case, the default entry
# is the entry saved with the command 'savedefault'.
default         0
## timeout sec
# Set a timeout, in SEC seconds, before automatically booting the default entry
# (normally the first entry defined).
timeout         7
# Pretty colours
color cyan/blue white/blue
## password ['--md5'] passwd
# If used in the first section of a menu file, disable all interactive editing
# control (menu entry editor and command-line)  and entries protected by the
# command 'lock'
# e.g. password topsecret
#      password --md5 $1$gLhU0/$aW78kHK1QfV3P2b2znUoe/
# password topsecret
# examples
# title         Windows 95/98/NT/2000
# root          (hd0,0)
# makeactive
# chainloader   +1
# title         Linux
# root          (hd0,1)
# kernel        /vmlinuz root=/dev/hda2 ro
# Put static boot stanzas before and/or after AUTOMAGIC KERNEL LIST
### BEGIN AUTOMAGIC KERNELS LIST
## lines between the AUTOMAGIC KERNELS LIST markers will be modified
## by the debian update-grub script except for the default options below
## DO NOT UNCOMMENT THEM, Just edit them to your needs
## ## Start Default Options ##
## default kernel options
## default kernel options for automagic boot options
## If you want special options for specifiv kernels use kopt_x_y_z
## where x.y.z is kernel version. Minor versions can be omitted.
## e.g. kopt=root=/dev/hda1 ro
# kopt=root=/dev/hda5 ro
## default grub root device
## e.g. groot=(hd0,0)
# groot=(hd0,4)
## should update-grub create alternative automagic boot options
## e.g. alternative=true
##      alternative=false
# alternative=true
## should update-grub lock alternative automagic boot options
## e.g. lockalternative=true
##      lockalternative=false
## altoption boot targets option
## multiple altoptions lines are allowed
## e.g. altoptions=(extra menu suffix) extra boot options
##      altoptions=(recovery mode) single
## controls how many kernels should be put into the menu.lst
## only counts the first occurence of a kernel, not the
## alternative kernel options
## e.g. howmany=all
##      howmany=7
# howmany=all
## should update-grub create memtest86 boot option
## e.g. memtest86=true
##      memtest86=false
# memtest86=true
## ## End Default Options ##
title Debian GNU/Linux, kernel 2.6.11-1-386
        root (hd0,4)
        kernel /boot/vmlinuz-2.6.11-1-386 root=/dev/hda5 ro
        initrd /boot/initrd.img-2.6.11-1-386
title Debian GNU/Linux, kernel 2.6.11-1-386 (recovery mode)
        root (hd0,4)
        kernel /boot/vmlinuz-2.6.11-1-386 root=/dev/hda5 ro single
title Debian GNU/Linux, kernel 2.6.8-2-386
        root (hd0,4)
        kernel /boot/vmlinuz-2.6.8-2-386 root=/dev/hda5 ro
        initrd /boot/initrd.img-2.6.8-2-386
title Debian GNU/Linux, kernel 2.6.8-2-386 (recovery mode)
        root (hd0,4)
        kernel /boot/vmlinuz-2.6.8-2-386 root=/dev/hda5 ro single
title Windows NT/2000/XP (loader)
        rootnoverify (hd0,0)
        makeactive
        chainloader +1
        makeactive
        chainloader +1
        makeactive
        chainloader +1
title SUSE LINUX 9.3 (/dev/hdb1)
        root (hd1,0)
        kernel /dev/hda2
        initrd /dev/hdb2
title           Other operating systems:
root
# This entry automatically added by the Debian installer for a non-linux OS
# on /dev/hda1
root            (hd0,0)
savedefault
makeactive
chainloader     +1
 :bounce:  :bounce:  :bounce:
xadawa@debian:/boot/grub$ su
Password:
debian:/boot/grub# fdisk -l
Disk /dev/hda: 81.9 GB, 81964302336 bytes
255 heads, 63 sectors/track, 9964 cylinders
Units = cylinders of 16065 * 512 = 8225280 bytes
   Device Boot      Start         End      Blocks   Id  System
/dev/hda1               1        2550    20482843+   c  W95 FAT32 (LBA)    ----> Windows
/dev/hda2            2551        5011    19767982+   c  W95 FAT32 (LBA)
/dev/hda3            5012        7217    17719695    5  Extended
/dev/hda4   *        7218        9964    22065277+   7  HPFS/NTFS
/dev/hda5   *        5012        6273    10136983+  83  Linux    --------------> Debian
/dev/hda6            6514        6653     1124518+  82  Linux swap / Solaris
/dev/hda7            6654        7217     4530298+  83  Linux
Disk /dev/hdb: 203.9 GB, 203928109056 bytes
255 heads, 63 sectors/track, 24792 cylinders
/dev/hdb1               1        2432    19535008+  83  Linux   ----------------> Suse
/dev/hdb2   *        2433       24792   179606700    5  Extended
/dev/hdb5            2433        2554      979933+  82  Linux swap / Solaris
/dev/hdb6            2555        8633    48829536   83  Linux
/dev/hdb7            8634       14712    48829536   83  Linux
/dev/hdb8           14713       24792    80967568+   c  W95 FAT32 (LBA)
Disk /dev/sda: 33.8 GB, 33820286976 bytes
16 heads, 63 sectors/track, 65531 cylinders
Units = cylinders of 1008 * 512 = 516096 bytes
/dev/sda1   *           1       65531    33027592+   7  HPFS/NTFS
G réussi à récuperer ces infos dans ma Suse, par contre les chemins déconnent :
Type de section : image
kernel : (hd2,0)/boot/vmlinuz root=/dev/hdb1 vga=0x31a selinux=0  splash=silent resume=/dev/hda6  showopts
initrd : (hd2,0)/boot/initrd
(null)/ root=0a1000 vga=0x31a selinux=0  splash=silent resume=/dev/hda6  showopts
(null)/
 :bounce:
Voili voulou...
Merci de m'aider plz...
n°744551
xadawa
Posté le 25-10-2005 à 10:07:55  profilanswer
up
n°744618
Dark_Schne​ider
Close the World, Open the Net
Posté le 25-10-2005 à 12:42:25  profilanswer
http://www.linux-wizard.net/howto. [...] ainloading
Mandriva : parce que nous le valons bien ! http://linux-wizard.net/index.php
n°744676
arghbis
salops de dauphins
Posté le 25-10-2005 à 14:18:18  profilanswer
kernel : (hd1,0)/boot/vmlinuz root=/dev/hdb1 vga=0x31a selinux=0  splash=silent resume=/dev/hda6  showopts
initrd : (hd1,0)/boot/initrd
ça c bon pour toi
  Installation
pb grub après install Suse[GRUB][UBUNTU] Problème d'écran noir avec grub après install XP
Suse 10 - Faq How to - Forum[suse 10][résolu] Partitionnement impossible
[Debian Sarge] impossible d'installer GRUB pb dependance localeSauts de ligne
Suse LINUX 10.0Linux SUse 10.0 dispo. : y'en aura pour tout le monde !
Démarrage module sur suse 9.1
Plus de sujets relatifs à : comment rajouter une ligne pr ma Suse dans grub
