4254 connectés
  Linux et OS Alternatifs
  Installation
  Detected file collision(s): /usr/sbin/python-updater
n°1005677
trouble_fe​te
Posté le 27-01-2008 à 05:05:52  profilanswer
Je recompile présentement un stage 3 avec le gcc 4.3 du 16 janvier, et en recompilant "system" j'ai eu une erreur voici le log de portage (je ne prends que celui qui a bien l'air de concerner ce prob en faisant l'impasse sur d'autres trucs genre portage qui me demande de faire un "revdep-rebuild -X --library libexpat.so.0" ou d'autres messages chelou qui n'ont pas fait planter l'emerge system...)
>>> Messages generated by process 4120 on 2008-01-26 09:40:15 for package app-admin/python-updater-0.2:
ERROR: preinst
This package will overwrite one or more files that may belong to other
packages (see list below). Add "collision-protect" to FEATURES in
make.conf if you would like the merge to abort in cases like this. You
can use a command such as `portageq owners / <filename>` to identify
the installed package that owns a file. If portageq reports that only
one package owns a file then do NOT file a bug report. A bug report is
only useful if it identifies at least two or more packages that are
known to install the same file(s). If a collision occurs and you can
not explain where the file came from then you should simply ignore the
collision since there is not enough information to determine if a real
problem exists. Please do NOT file a bug report at
http://bugs.gentoo.org unless you report exactly which two packages
install the same file(s). Once again, please do NOT file a bug report
unless you have completely understood the above message.
>>> Messages generated by process 4120 on 2008-01-26 09:42:29 for package sys-libs/timezone-data-2007j:
LOG: postinst
You do not have TIMEZONE set in /etc/conf.d/clock.
Skipping auto-update of /etc/localtime.
>>> Messages generated by process 4120 on 2008-01-26 10:50:38 for package sys-devel/binutils-2.18-r1:
ERROR: compile
ERROR: sys-devel/binutils-2.18-r1 failed.
Call stack:
                  ebuild.sh, line 1701:  Called dyn_compile
                  ebuild.sh, line 1039:  Called qa_call 'src_compile'
                  ebuild.sh, line   44:  Called src_compile
                  ebuild.sh, line 1383:  Called toolchain-binutils_src_compile
  toolchain-binutils.eclass, line  231:  Called die
The specific snippet of code:
        emake all || die "emake failed"
 The die message:
  emake failed
If you need support, post the topmost build error, and the call stack if relevant.
A complete build log is located at '/var/tmp/portage/sys-devel/binutils-2.18-r1/temp/build.log'.
Après ce message j'ai juste fait "emerge --resume" et cette fois binutils s'est compilé normalement  :o
Qu'est ce qui a bien pu se passer selon vous ?  :jap:
Message édité par trouble_fete le 27-01-2008 à 05:06:28
Tyan Tiger 200T, SDR PC 133, 1*256Mo, Bi-Tualatin 1,4Ghz, disque Maxtor 6Y080L0 IDE 80Go, FX 5200 en format PCI, modem/routeur DSL-524T, le tout sous Gentoo
n°1005937
trouble_fe​te
Posté le 28-01-2008 à 21:26:41  profilanswer
  Installation
[Ma box plante] Inconsistency detected by ld.soEmesene, Client Msn, Gtk+python...
Installation ArtistX - Error 15 File not foundlire un message en file d'attente postfix
[DEBIAN-ETCH] Kernel upgrade -> Waiting for root file systemOpenLDAP et SAMBA | Insufficient access at /usr/sbin/smbldap-passwd li
Vocabulaire: spurious bianry fileScript python mplayer
ubuntu sur le 2ème DD : error 15 file not foundFile system is reporting the free space X clusters not Y clusters
Plus de sujets relatifs à : Detected file collision(s): /usr/sbin/python-updater
