5870 connectés
  Linux et OS Alternatifs
  Installation
  Base Pervasive SQL et les librairies sous RedHatEL 3.0
n°618156
kwa29
Kwa29 @ l'ouest
Posté le 10-01-2005 à 17:22:18  profilanswer
Bonjour à tous,
J'espere que ce sujet va passionner les foules car la g vraiment besoin de monde et d'aide.
Aller c parti (je v tenter d'etre clair et limpide) :
Je cherche à installer le client pour une base pervasive.SQL v8 via odbc et pas iodbc (hic!)
Dans mon cas c le Pervasive.SQL-Client-8.50-189.000.i486.rpm (g tenté l'install uniquement en rpm)
Un coup de rpm -ivh  et ca donne ca :
[root@PCDEV>root@PCDEV</a> sofibra]# rpm -ivh
Préparation...              ########################################### [100%]
+++++ Checking current user rights...
Passed...
+++++ Checking for previously installed engine...
Passed...
   1:Pervasive.SQL-Client   ########################################### [100%]
+++++ Setting up group and admgroup...
An existing group pvsw was found.
An existing group pvsw-adm was found.
+++++ Setting up user psql...
An existing user psql was found.
+++++ Setting up the environment...
+++++ Setting up symbolic links for libraries...
+++++ Making user psql owner of all files in /usr/local/psql...
+++++ Setting up the PCOM libraries...
/usr/local/psql/lib/libpctlgrb.so.8 registered successfully
/usr/local/psql/lib/libpceurop.so.1 registered successfully
/usr/local/psql/lib/libpssax.so.1 registered successfully
/usr/local/psql/lib/libpsutilrb.so.1 registered successfully
/usr/local/psql/lib/libclientrb.so.8 registered successfully
/usr/local/psql/lib/libupiapirb.so.8 registered successfully
/usr/local/psql/lib/libcsi100.so.8 registered successfully
/usr/local/psql/lib/libmkc.so.8 registered successfully
/usr/local/psql/lib/libpvmsgrb.so.8 registered successfully
/usr/local/psql/lib/libpsqlcsm.so.8 registered successfully
/usr/local/psql/lib/libpsqlcsp.so.8 registered successfully
/usr/local/psql/lib/libdbcsipxy.so.8 registered successfully
++++ Searching for and restoring configuration from previous install...
odbc.ini.pkgsave
odbc.ini.org
View the README and documentation for this product at:
file:/usr/local/psql/clientdoc/html/index.html
Install has successfully completed.
Juskici tout va bien
Ensuite je teste l'install (je précise que j'attaque la base pervasive en étant sous linux et le base est sous win2000 server)
[root@PCDEV bin]# ./odbctest
OpenLink ODBC Demonstration program
This program shows an interactive SQL processor
Enter ODBC connect string (? shows list): ?
DSN                            | Description
DEMODATA                       | Pervasive ODBC Engine: DEMODATA
Enter ODBC connect string (? shows list): DEMODATA
[iODBC][Driver Manager]Dialog failed, SQLSTATE=IM008
Have a nice day.
La ca merde.
Je regarde du coté des librairies et je trouve des choses étonnantes (ki non peu pas de rapport entre elles d'ailleurs)
Un coup de ldd
[root@PCDEV bin]# ldd -r /lib/security/pam_userdb.so
        libdb-4.1.so => /usr/lib/libdb-4.1.so (0x40015000)
        libc.so.6 => /lib/tls/libc.so.6 (0x400d7000)
        libpthread.so.0 => /lib/tls/libpthread.so.0 (0x4020f000)
        /lib/ld-linux.so.2 => /lib/ld-linux.so.2 (0x80000000)
undefined symbol: pam_get_item  (/lib/security/pam_userdb.so)
undefined symbol: pam_set_item  (/lib/security/pam_userdb.so)
undefined symbol: pam_get_user  (/lib/security/pam_userdb.so)
Pas bon ca il semblerait que cela soit du à pam ou db4
Ensuite ya ca
[root@PCDEV bin]# ldd -r /usr/local/psql/lib/odbcci.so
        libpscore.so.1 => not found
        libm.so.6 => /lib/tls/libm.so.6 (0x4007b000)
        libpthread.so.0 => /lib/tls/libpthread.so.0 (0x4009d000)
        libdl.so.2 => /lib/libdl.so.2 (0x400ad000)
        libgcc_s.so.1 => /lib/libgcc_s.so.1 (0x400b0000)
        libc.so.6 => /lib/tls/libc.so.6 (0x400b9000)
undefined symbol: PSEventSignal (/usr/local/psql/lib/odbcci.so)
undefined symbol: PSLibOpen     (/usr/local/psql/lib/odbcci.so)
undefined symbol: PSLibClose    (/usr/local/psql/lib/odbcci.so)
undefined symbol: PSAnsiToUnicode       (/usr/local/psql/lib/odbcci.so)
undefined symbol: PSEventTimedWait      (/usr/local/psql/lib/odbcci.so)
undefined symbol: PSEventCreate (/usr/local/psql/lib/odbcci.so)
undefined symbol: PSEventWait   (/usr/local/psql/lib/odbcci.so)
undefined symbol: PSThreadCreate        (/usr/local/psql/lib/odbcci.so)
undefined symbol: PSEventDestroy        (/usr/local/psql/lib/odbcci.so)
undefined symbol: PSLibGetSymbol        (/usr/local/psql/lib/odbcci.so)
undefined symbol: PSStrLenA     (/usr/local/psql/lib/odbcci.so)
undefined symbol: PSRegistryGetValue    (/usr/local/psql/lib/odbcci.so)
undefined symbol: PSUnicodeToAnsi       (/usr/local/psql/lib/odbcci.so)
undefined symbol: PSThreadJoin  (/usr/local/psql/lib/odbcci.so)
Pour rire g fais un ldd -r /usr/local/psql/lib/* g rigolé 3s après je pleuré
Bref vous voyez surement le délire (o nivo des librairies sous RHEL3.0 c pas la fete ou alors je suis le roi de la casse)
Visiter mon site http://kwa29.com
n°618160
kwa29
Kwa29 @ l'ouest
Posté le 10-01-2005 à 17:34:15  profilanswer
Pleaze helpzzzzzzzzz
n°618471
kwa29
Kwa29 @ l'ouest
Posté le 11-01-2005 à 10:42:35  profilanswer
Personne ???
n°618628
kwa29
Kwa29 @ l'ouest
Posté le 11-01-2005 à 15:42:33  profilanswer
Pour l'erreur avec ldd c bon g trouvé mais par contre je n'arrive tj pas à me connecter via odbc à Pervasive.SQL
  Installation
[resolu ?] samba : algorithmic RID base pdc/ldapquel firewall basé sur iptables ??
Quel OS pour serv impression à base pII 200Mhz[SQUID] authentification via une base SAM existante c'est possible ?
Création automatique d'utilisateur depuis base de donné?Problème de base de données urpmi (fin du topic)
[Debian] Probleme d'installation de alse-baselogiciel qui permet de modeliser des base de donnes.
base CVS distanteQuelle carte vidéo de base avec prise DVI pour utilisation sous Linux?
Plus de sujets relatifs à : Base Pervasive SQL et les librairies sous RedHatEL 3.0
