5671 connectés
  Linux et OS Alternatifs
  Installation
  prb avec ldconfig.
prb avec ldconfig.
n°599839
Sebastien
Posté le 03-12-2004 à 19:20:40  profilanswer
Tout est la :)
gondor:~# ldconfig
ldconfig: /usr/lib/libopencdk.so.8 is not an ELF file - it has the wrong magic bytes at the start.
ldconfig: /usr/lib/libkdegstplay.so.0.0.0 is not an ELF file - it has the wrong magic bytes at the start.
ldconfig: /usr/lib/libkdegst.so.0.0.0 is not an ELF file - it has the wrong magic bytes at the start.
ldconfig: /usr/lib/libkdegstplay.so.0 is not an ELF file - it has the wrong magic bytes at the start.
ldconfig: /usr/lib/libkdegst.so.0 is not an ELF file - it has the wrong magic bytes at the start.
ldconfig: /usr/lib/libopencdk.so.8.0.1 is not an ELF file - it has the wrong magic bytes at the start.
  Installation
  prb avec ldconfig.
[MDK10.0] installation de wxGTK 2.4 erreur ldconfig .?Erreur Ldconfig à l'install
installation Mandrake 9.1 (ldconfig failed)
Plus de sujets relatifs à : prb avec ldconfig.
