7465 connectés
  Linux et OS Alternatifs
  Installation
  Autoconf, automake... :/ autobug
n°807631
M300A
Posté le 05-05-2006 à 21:57:52  profilanswer
J'essaye desesperement de compiler seti@home depuis longtemps mais je n'y suis jamais parvenu.
voila ce que j'obtiens lorsque je lance ./_autosetup
gandalf@hellscream:~/build/boinc/setiathome/seti_boinc$ ./_autosetup
Bootstrapping configure script and makefiles:
/usr/share/aclocal/smpeg.m4:13: warning: underquoted definition of AM_PATH_SMPEG
  run info '(automake)Extending aclocal'
  or see http://sources.redhat.com/automake/automake.html#Extending-aclocal
/usr/share/aclocal/oaf.m4:4: warning: underquoted definition of AM_PATH_OAF
/usr/share/aclocal/lirc.m4:15: warning: underquoted definition of AC_PATH_LIRC
/usr/share/aclocal/glib.m4:8: warning: underquoted definition of AM_PATH_GLIB
/usr/share/aclocal/gconf-1.m4:4: warning: underquoted definition of AM_PATH_GCONF
/usr/share/aclocal/gconf-1.m4:71: warning: underquoted definition of AM_GCONF_SOURCE
configure.ac:355: error: `config.h' is already registered with AC_CONFIG_HEADERS.
autoconf/status.m4:424: AC_CONFIG_HEADERS is expanded from...
autoconf/status.m4:437: AC_CONFIG_HEADER is expanded from...
configure.ac:355: the top level
autom4te: /usr/bin/m4 failed with exit status: 1
aclocal: autom4te failed with exit status: 1
Done, now run ./configure
 ./configure -C
Evidemment le script configure n'est pas créé...
ii  autoconf                              2.59a-9                                   automatic configure script builder
ii  automake1.9                           1.9.6-4                                   A tool for generating GNU Standards-complian
ii  autotools-dev                         20060223.1                                Update infrastructure for config.{guess,sub}
ii  m4                                    1.4.4-1                                   a macro processing language
n°807632
black_lord
Truth speaks from peacefulness
Posté le 05-05-2006 à 22:02:19  profilanswer
tu as essayé avec automake 1.4 ?
n°807633
M300A
Posté le 05-05-2006 à 22:03:43  profilanswer
C'est encore bien pire !
n°807634
M300A
Posté le 05-05-2006 à 22:04:39  profilanswer
Voici les sources si quelqu'un prefere tester chez lui :)
http://setiweb.ssl.berkeley.edu/sa [...] -05.tar.gz
n°807636
M300A
Posté le 05-05-2006 à 22:13:07  profilanswer
Hum je me demande si c'est le bon en fait...
topic en stand by.
  Installation
SOS automake[Debian 3.0-r2] Mettre un autoconf plus récent
Besoin d'automake 1.6 sur une Debian stable ...problème de compilation : autoconf sous Gentoo
[autoconf] je ne comprends pas....avidemux & automake 1.6: Please test
Probleme d'installation d'autoconf 2.53kde3 et autoconf 2.53
Plus de sujets relatifs à : Autoconf, automake... :/ autobug
