6239 connectés
  Hardware - Périphériques
  Divers
  VGA-DVI will not work
n°976941
shihtzu1
Posté le 05-06-2019 à 08:43:48  profilanswer
Hi using a HP pavillion P6-2143ef desktop product no.B4Q82EA#ABF with WIN 7 took cover off VGA-DVI outlet as my monitors have that connection but it will not work is there a way to switch it on having to use 26 in TV to access vie HMDI outlet thank you in advance
n°976949
BloodyCarn​age
Posté le 05-06-2019 à 10:09:08  profilanswer
Get yourself a passive DVI to HDMI adapter for about 5$ and that should do the trick.
Nothing's so bad it can't get worse
  Divers
Ecran 144hz en DVI dual et CG en Display portDVI utilisable pour un 2eme ecran ?
Cable DVI vs HDMI vs DVI/HDMIInformation sur les connectique DVI-D, displayPort
2 ecrans simultanés VGA + DVIFire Tv stick non reconnu (HDMI/DVI)
Écran PC BENQ GL2460 24 POUCES DVI/VGAMini display port ou DVI/HDMI ?
Plus de sujets relatifs à : VGA-DVI will not work
