3078 connectés
  Boitier
  [Topic unique] Thermaltake Core V71
n°9022130
Psebcool
Posté le 20-01-2014 à 02:59:57  profilanswer
Thermaltake vient d'annoncer son nouveau boitier "ultime". Le Core V71 !
Model Core V71
P/N CA-1B6-00F1WN-00
Case Type Full Tower
Dimension (H x W x D) 583 x 230 x 560 mm
(23 x 9.1 x 22 inch)
Net Weight 13.2 kg
Side Panel Transparent Window
Color Exterior & Interior : Black
Material SPCC
Cooling System Front (intake) : 200 x 200 x 30 mm Blue LED fan (600~800rpm, 13~15dBA) x 2
Rear (exhaust) : 140 x 140 x 25 mm Turbo fan (1000rpm, 16dBA)
Top (exhaust) : 200 x 200 x 30 mm Blue LED fan (600~800rpm, 13~15dBA)
Drive Bays -Accessible : 2 x 5.25’’
- Hidden : 8 x 3.5’’ or 8 x 2.5’’
Expansion Slots 8
Motherboards 9.6” x 9.6” (Micro ATX), 12” x 9.6” (ATX), 12” x 13” (Extend ATX)
I/O Port USB 3.0 x 2,USB 2.0 x 2, HD Audio x 1
PSU Standard PS2 PSU (optional)
LCS Upgradable Supports 1/2”、3/8”、1/4” water tube
Fan Support Front:
- 1 x 120mm or 2 x 120mm or 3 x 120mm
- 1 x 140mm or 2 x 140mm
- 1 x 200mm or 2 x 200mm
Top:
Rear:
- 1 x 120mm or 1 x 140mm
Bottom:
Radiator Support Front:
- 1 x 120mm or 1 x 240mm or 1 x 360mm
- 1 x 140mm or 1 x 280mm or 1 x 420mm
Top:
Rear:
- 1 x 120mm
Bottom:
Other CPU cooler height limitation:
- 185mm
VGA length limitation:
- 310mm (with HDD rack)
- 400mm (without HDD rack)
http://www.thermaltake.com/db/products/case/coreV71/main.jpg http://www.thermaltake.com/db/products/case/coreV71/pic1.jpg
http://www.thermaltake.com/db/products/case/coreV71/pic2.jpg http://www.thermaltake.com/db/products/case/coreV71/pic3.jpg
http://www.thermaltake.com/db/products/case/coreV71/pic4.jpg http://www.thermaltake.com/db/products/case/coreV71/pic5.jpg
http://www.thermaltake.com/db/products/case/coreV71/pic8.jpg http://www.thermaltake.com/db/products/case/coreV71/pic7.jpg
http://www.thermaltake.com/product [...] C_00002231
  Boitier
[Topic Unique] NZXT H440Intel core i5 3570k compatible avec toute les Ram ?
Conseil config pc avec asus z87 pro et intel core i7 4771Chipset Intel core I3 3220 ou Geforce GTX 650
Intel Core i5-3470 (3.2 GHz) ou Intel Core i5-4430 (3.0 GHz)?[Topic Unique] Les boitiers orientés Silence. Warning: Bequiet! arrive
[Topic Unique] Lian Li PC-Q33[Topic unique] Boitiers Streacom
Core 2 duo P8700: Coef. multiplicateur qui chute [RESOLU !]
Plus de sujets relatifs à : [Topic unique] Thermaltake Core V71
