3764 connectés
Sujet : M.A.J d'une KR7A-133 !
remixgame C'est dingue de quoi on peut parler sur un forum dedié au mise à jour de bios
burgergold
cpulloverclock a écrit a écrit :
equivadrais  :lol:
du verbe equiver
 :non:  ----------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------->  :fuck:
cpulloverclock equivadrais  :lol:
du verbe equiver
burgergold p-e un bon dos mais les épaules pas très larges  :D
Prems
burgergold a écrit a écrit :
?!? ta de la misere a comprendre le cher québecois que je suis?  :D
Il a bon dos le québécois sur ce coup-là  ;)
remixgame JE l'ai deja fait sur ma P5-ab de asus avec un vieux proc
Mais je voulait juste savoir au cas ou car je viens de l'acheter il est tous neuf !
LOL
burgergold
Prems a écrit a écrit :
Tu t'es lu quand t'as bu  ? :D
burgergold trouver quelqu'un qui a un programmeur de eeprom, alors ta pas dlair tres confortable avec ca donc touche s'y pas
si c détecté à 1733mhz c bon, tout va bien
remixgame Ok burgergold mais c'etait juste pour savoir merci
Prems
ouais, 2100+ ca signifit pas 2100mhz
c le P-rating de amd, qui selon lui, estime que son XP équivadrais à un tbird 1733, mais en réalité tlm penche vers la théorie que amd compare leur 2100+ à un P4 2.1
remixgame Si je fous le brun dans le bios style je flashe et oups je mets pas le nouveau
si je me trompe
que faut'il faire ?
burgergold ouais, 2100+ ca signifit pas 2100mhz
Prems ....
remixgame Au faite c'est normal que mon Xp 2100+
est cadence à 1733 Mhz ?
remixgame Mais ca n'augmentera pas les performances car sois disant il gere le xp 2100 +
Mais pour l'instant c'a a l'air d'aller
burgergold si ton pc marche sans bleme t pas obliger
un lecteur disquette tu peux ten passé mais c pratique et ca se trouve a 100ff neuf
remixgame Est ce necessaire de mettre à jour
mon bios sachant que j'ai
un athlon xp 2100+
et que la nouvelle verison du bios permet :
Code :
  1. 1. Support AMD AthlonXP 2100+ CPU.
  2. 2. Support new 0.13 micron process AthlonXP CPU, Throughbred.
  3. 3. Fix CPU fan N/A problem for specific low speed CPU fan.
  4. 4. HPT 37x BIOS version 2.0.1024.The RAID function is for KR7A-RAID
  5.    only. This BIOS version is also for non RAID boards and HPT BIOS
  6.    will be automatically disabled while RAID controller chip not
  7.    detected.
  8. 5. BIOS compile date: 4/29/2002.
Mais un autre probleme s'ajoute mon lecteur de disquette est defonce il ne marche plus
donc je me demander si c'etait vraiment necessaire
si vous voulez voir ma conf cliquez sur le petit ordinateur au dessus
MERCI
