5570 connectés
Sujet : Drivers pour Guillemot Race leader Force Feedback
louloup2
salut!
y fait peur presque :pt1cable: A+
louloup2
salut!
die666 il n'y a pas de drivers xp pour ce modem
le seul moyen pour en avoir, c'est de passer le volant en usb, et en faire de ce fait un race leader force feedback wheel.
voici un copy/paste d'un post que j'ai mis ailleurs :
alors, pour tous ceux qui ont un race leader force feedback de chez guillemot en dB9 (port serie):
pour le passer en usb et pouvoir s'en servir sous windows XP il faut souder un cable usb sur la carte mere du volant.
voici un copier coller du post trouvé:
> This has cropped up before - lack of serial version drivers of the
> wheel for XP.  I've had a read through what posts I could find, and
> tried a suggestion of using a USB-Serial adaptor, but the drivers for
> that just created a further COM port.
> One person mentioned a USB hack, to whom I've sent a query, but I can
> find no more mention of it.
> Has anyone managed to get this wheel working in XP?  A driver hack
> perhaps, a physical rewiring?
> Any clues would be most welcome.
> Thanks,
> Amos
One very kind Tony_h (whose post was back in Jan!) answered my USB
hack query - with a successful outcome.  The PCB within the housing
has a vacant USB connection area (J5).  In a nutshell, it's just a
simple job of taking a standard USB extension cable, stripping one end
off, and soldering it in place with the following pin counts :
 1 Red
 2 White
 3 Green
 4 Black
The serial cable was removed (a tidy plug/socket job made that easy)
so that the USB cable exited the unit without any further holes.
Plugged it in, XP detected a new device, installed the most recent
drivers (GI_RLFFBWheel98ME2KXP_2514.exe), and away it went.  Even got
split axis for throttle/brake.
Voilou.. ca marche tres tres bien , je viens de le faire sur le mien, donc guillemot avec leur 15 euros, ils peuvent aller se rendormir..
pour les anglophobes :
il y a sur la carte mere du volant un emplacement jp5 (usb) il faut virer l'etain et y enfiler un cable usb en respectant cet emplacement :
1 rouge
 2 blanc
 3 vert
 4 noir
ensuite, installer les drivers xp du volant de chez guillemot (l'usb) et voilou.. vous avez un volant usb. \o/
new-pseudo
Elite a écrit a écrit :
Où je pourai trouver les drivers de ce volant pour win XP et 2k?
Merci à tout le monde
http://www.multimania.com/tototoz/iench.jpg
Elite Où je pourai trouver les drivers de ce volant pour win XP et 2k?
