10951 connectés
Sujet : Creative Video Blaster WebCam 5 ss WinXP pro : pb de drivers ?
jerem38 :sweat:
jerem38 :sweat:
jerem38 :hello:
jerem38 [:karochky]
jerem38 :bounce:
jerem38 bon, quand j'ai installé les drivers du cd, ca a planté... Quand j'ai rebooté, les drivers étaient installés, mais bon... C pa génial, koi...
Sinon, le soft plante. donc pour tester la webcam... netmeeting !
c'est pa fluide, alors qu'elle devrait envoyer 30 im/s, et ca plante aussi...
voila ce qu'ils disent sur le site de creative :
Installing Creative Video Blaster WebCam 5 Driver under XP
DECEMBER  2001
  This document provides late-breaking of other information that
  supplements the Creative Video Blaster WebCam 5
  documentation. Please read all the sections before you proceed with
  the installation.
CONTENTS
1.   Driver installation
Insert CD and follow installation steps.
1)  Disconnect Video Blaster WebCam 5 from your computer.
2)  Double-click CtDrvStp.exe located on your Video Blaster WebCam 5 Installation CD.
      Follow the  instructions on the screen to uninstall the existing driver.
3)  Connect Video Blaster WebCam 5 to your computer.
         Windows will detect the camera and install the driver.
         NOTE: In Windows 2000 and Windows XP, the Digital Signature Not Found
         dialog box may appear. Click the YES button to continue with the
         installation.
Copyright (c) November 2001 Creative Technology Ltd. All rights reserved.
  End of Readme File
mais y a pas de drivers a jours...  :cry:
[jfdsdjhfuetppo]--Message édité par jerem38 le 20-05-2002 à 22:19:17--[/jfdsdjhfuetppo]
