7069 connectés
Sujet : equivalent a DFT pour seagate ?
Zaib3k :(
    _ _ _
   / / (_)
  _\ \ \   DIAGATA.EXE Version 3.02.1011ML
 (_)_/_/
Copyright (c) 2000 by Seagate Technology, Inc. All rights reserved.
Timer Resolution: 0.000122
Long Test Begin: 20-May-2002 16:38:36
Cable Test -  Passed
Buffer Test -  Passed
Identify Data
   Model Number: ST380021A
   Serial Number: 3HV0BCJC
   Firmware Revision: 3.10
   Default CHS: 16383-16-63
   Current CHS: 16383-16-63
   Current Capacity: 16514064 Sectors
   Total Capacity: 156301488 Sectors
   80 Conductor Cable Reported
   ID Method: Unknown
SMART Check: Passed
DST - Errors - Status: 07
Long Test Failed: 20-May-2002 16:40:30
    _ _ _
   / / (_)
 (_)_/_/
Short Test Begin: 20-May-2002 16:42:34
Cable Test -  Passed
Identify Data
   ID Method: Unknown
SMART Check: Passed
Outer Diameter Scan (0 to 2494208) - Passed
   Elapsed Time: 30.00s
   Estimated Internal Transfer Rates
      Min: 67.64Mb/s Max: 477.27Mb/s Avg: 357.63Mb/s
Inner Diameter Scan (155054384 to 156301488) - Passed
   Elapsed Time: 25.51s
      Min: 32.54Mb/s Max: 268.47Mb/s Avg: 206.09Mb/s
Random Seek (1514 Cycles) - Passed
   Estimated Access Times
      Min: 1.465ms Max: 16.356ms Avg: 9.751ms
Random Read (1036 Cycles) - Passed
      Min: 3.906ms Max: 25.144ms Avg: 14.321ms
PIO/DMA Data Compare
   Total Bytes = 24987136
   Estimated PIO Transfer Rates
      Min: 0.93MB/s Max: 2.72MB/s Avg: 2.72MB/s
   Estimated DMA Transfer Rates
      Min: 77.60MB/s Max: 77.60MB/s Avg: 77.60MB/s
SMART Check: Passed
Short Test Passed: 20-May-2002 16:44:14
    _ _ _
   / / (_)
 (_)_/_/
Long Test Begin: 20-May-2002 16:44:31
Cable Test -  Passed
Identify Data
   ID Method: Unknown
SMART Check: Passed
Full Scan (0 to 6582018) - Errors
   |LBA       |Error Register|
   |5719559   |40h           |
   |5953265   |40h           |
   |5955267   |40h           |
   |5999673   |40h           |
   |6001675   |40h           |
   |6005827   |40h           |
   |6082182   |40h           |
   |6086334   |40h           |
   |6195123   |40h           |
   |6199275   |40h           |
   |6242364   |10h           |
   |6246516   |40h           |
   |6342164   |40h           |
   |6346316   |40h           |
   |6379583   |40h           |
   |6395558   |40h           |
   |6405863   |40h           |
   |6566043   |40h           |
   |6568878   |40h           |
   |6582017   |40h           |
Long Test Failed: 20-May-2002 16:46:57
effectivement ce soft fonctionne mais pas mon DD
Zaib3k :(
    _ _ _
   / / (_)
 (_)_/_/
Cable Test -  Passed
Identify Data
   ID Method: Unknown
SMART Check: Passed
    _ _ _
   / / (_)
 (_)_/_/
Cable Test -  Passed
Identify Data
   ID Method: Unknown
SMART Check: Passed
SMART Check: Passed
    _ _ _
   / / (_)
 (_)_/_/
Cable Test -  Passed
Identify Data
   ID Method: Unknown
SMART Check: Passed
   |5719559   |40h           |
   |5953265   |40h           |
   |5955267   |40h           |
   |5999673   |40h           |
   |6001675   |40h           |
   |6005827   |40h           |
   |6082182   |40h           |
   |6086334   |40h           |
   |6195123   |40h           |
   |6199275   |40h           |
   |6242364   |10h           |
   |6246516   |40h           |
   |6342164   |40h           |
   |6346316   |40h           |
   |6379583   |40h           |
   |6395558   |40h           |
   |6405863   |40h           |
   |6566043   |40h           |
   |6568878   |40h           |
   |6582017   |40h           |
Zaib3k merci c sympa
je dl et je test
amososodef si il march en NTFS  DL "disk wizard 2002"
dedan ya seatools
amososodef seatool
tu peu le DL sur seagate.com
Zaib3k [:yoyoz]
Zaib3k ca existe ?
DFT : drive fitness test de IBM ( outils de diagnostic)
je voudrais diagnostic mon Barracuda a fond mais l'outils que g trouvé chez Seagate ne marche pas si le dd est en NTFS (  :ouch:  )
