7855 connectés
Sujet : quel pilote pour une ati radeon VE 64 mb (powered by ati)
Pentier voili voilou : ca permet d'installer les drivers buid by sur une powered by  [:shooter]
Bon alors, voilà la procédure :
En fait, ta carte n'est pas reconnue et c'est normal car c'est pas une build by ATI mais une powered by ATI. En gros tu lances l'install, tu l'arrêtes après la décompression des fichiers et dans le gestionnaire de périphériques, tu fais update driver de ta carte en lui spécifiant où se trouver les fichiers .inf décompressés :
Sinon, procédure complète en anglais:
Common re-installation:
1. Boot up in standard VGA mode.
2. Now, remove all ATI drivers and ATI software:
Go to Control Panel, select Add Remove Programs;
Remove the ATI Display Driver, click ok;
Do not reboot yet.
Remove the ATI Software (Multimedia Center /Teletext and/ or DVD player if
applicable);
Do not reboot yet.
Click on Start
Click on Find, select Files/Folders
Type ati*.*
When Windows has found all ATI files, please delete them all.
Reboot the system.
3. Please ensure that you have checked these BIOS settings.
WARNING! Incorrect changes to CMOS may prevent the system from booting.
Before making changes to CMOS settings, please ensure that you are familiar
with the procedures for restoring default settings. Consult the
documentation for your motherboard and/or your system.
The exact names of CMOS settings may vary from system to system. Not all
systems will offer the options listed below.
These settings (if they appear) will normally be found in the CHIPSET SETUP
or CHIPSET FEATURES portion of CMOS.
AGP Bus Turbo Mode
AGP Turbo DISABLED
Primary Frame Buffer
VGA Frame Buffer DISABLED
AGP 1X/2X/4X Should be set to match the capabilities of the graphics adapter
AGP Aperture Size
AGP Aperture DEFAULT or 64MB
4. After you have checked the BIOS, please boot up in Normal Mode.
5. Please ensure that you have the latest AGP drivers installed for the
chipset on your motherboard.
AGP drivers can be updated from the motherboard manufacturer's website -
http://support.ati.com/info/mother [...] urers.html or chipset's
manufacturer's - http://support.ati.com/info/chipset_manufacturers.html
6. Be sure that you have the latest version of Microsoft DirectX installed
in your system.
You can check your DirectX version using DXDiag (Click on "Start"; "Run";
Type "dxdiag" and click OK).
Please be also sure that you install the additional software related to
DirectX (e.g. the Digital Video Update for DirectX 8):
http://www.microsoft.com/directx/homeuser/downloads/
7. Launch the extraction of the ATI Driver downloaded file, but exit
installation, as soon as it starts.
8. Now you can install the driver manually:
Click on Start, Settings, Control Panel;
Click on the Display icon to open Display Properties;
Click on the Settings tab in Display Properties and click on the Advanced
button
Click on the button Change graphics adapter and Next;
Select "Display a list of all the drivers in a specific location, so you can
select the driver you want."
Select " Show all devices ".
Click on " Have disk ".
Browse your hard drive to find the directory of the driver:
if from the downloaded file:
C / ATI / Support /   Wxx_8500_x_xx_xxxx.exe   / AtiDrive     (for Radeon
8500)
C / ATI / Support / Wxx_RADEON_x_xx_xxxx.exe / AtiDrive     (for other
Radeon products)
C / ATI / Support /   Wxx_R128_x_xx_xxxx.exe   / AtiDrive     (for Rage
128/128 Pro products)
if from the ATI Installation CD:
note: the last 2 letters of the folder name indicate the Operating System
(2k - Windows 2000)
CD / Install / R200XX / AtiDrive    (for Radeon 8500)
CD / Install /  R6XX   / AtiDrive    (for other Radeon products)
CD / Install / R128XX / AtiDrive    (for Rage 128/128 Pro products)
and select any *.inf in this directory.
Follow the screen instructions to complete the driver installation.
Reboot your system.
Do not reboot yet.
applicable);
Do not reboot yet.
Click on Start
Type ati*.*
Reboot the system.
AGP Bus Turbo Mode
AGP Turbo DISABLED
AGP Aperture Size
in your system.
button
8500)
Radeon products)
(2k - Windows 2000)
Reboot your system.
Pentier moi je la connais la méthode  :D
Intéressé...?
attends je la recherche...
flox t as les drivers omega :
http://www.omegacorner.com/ati.htm
sinon y a une methode pour utiliser les drivers ati sur les powered by ati
keodje oui j'ai essayé mais il ne fonctionne pas
flox tas essaye ceux du cd livre avec la carte ?
keodje au  fait ma crte mère est aopen AK77 pro
keodje Salut à tous,
Je me demandais si quelqu'un pouvait m'aider pour les pilotes de ma carte graphique ati radeon ve 64 mb( powered by ati). J'ai bien esssayé de télécharger les pilotes sur le site d'ati mais ceux-là ne fonctionne (en les installant, mon ordi n'arrête pas de se planter.Mon système d'exploitation est windows xp.
merci à tous
