4806 connectés
Sujet : P6BAT-A+ vous connaissez ?
Noooky :bounce:
Noooky :bounce:
Noooky ui mais je prends lekell  ? il me semble avoir le dernier mais chui po sur comprends rien a leur site tt en jap  :sol:
thx
grim fandago
noooky a écrit a écrit :
:hello: voila je ne sais po mettre mes 2 barrette infineon de 256 chakunes kkun px  m aider  svp ?mon bios date du 17/12/99
 numero de la carte : vt82c692bx
Merci d avance
flash le BIOS alors !!!
ilien83
:D  ben c pour savoir comment mettre ma 2eme barette de 256 paske si je la mets ca beeeeepp et ca boot po !!!!!
compris ? :lol:
 :lol:  :lol:  :lol:  :lol:  :lol:  :lol:  :lol:  :lol:  :lol:
Peu-être parce qu'elle n'accepte que 384 Mo :
The P6BAT-A+ is a full-sized ATX board measuring 305x220mm and using 4-layer printed circuit board. The P6BAT-A+ V2.0/2.2 has a special design feature so that it includes a Slot-1 processor slot and a PPGA (Plastic Pin Grid Array) Celeron Socket-PGA370 processor socket. This feature means that you can install the mainboard with either a Pentium-III cartridge, a Pentium-II cartridge, the SEPP (Single Edge Processor Package) Celeron cartridge, or one of the new generation PPGA Celeron processors. In addition, the mainboard supports a 66 MHz memory bus, or a 100 MHz memory bus, so you can use inexpensive 66MHz memory chips, or higher-performance PC-100 memory chips. The board is installed with an integrated PCI-3D sound system and has a full suite of I/O ports. Seven expansion slots are available for system development and hardware monitoring is supported. This board allows complete flexibility. System integrators can choose the high-performance Slot -1 processor or the inexpensive PPGA Celeron processor according to the system requirements and the price/performance comparison of the two kinds of processor.
PROCESSORS Detail
 SECC2 Pentium III up to 850MHz(100MHz FSB), Pentium II
 FC-PGA Pentium III up to 850MHz(100MHz FSB)
 Celeron PPGA up to 533MHz
 Cyrix III up to 550MHz(100MHz FSB)
CHIPSET
 VIA 82C693A & 82C596B
 CMI8738 PCI 3D Audio Chip on board
MEMORY
 Three 168-pin DIMMs
 Maximum: 384MB
 :cry:  :cry:  :cry:  :cry:  :cry:  :cry:
ienchangel ouiii, mes parents ont la même, avec un celeron 433 et 64 mo de ram, je te file mon adrese et envoie moi la barrette, j'en ai besoin, et je te dirais si ça fonctionne... :D
grim fandago
compris ? :lol:
Bein met la toute seul et si ca beeeeeppp encor c'est que ta carte ne la suporte pas ou qu'elle est griller !!! :hello:
Noooky :D  ben c pour savoir comment mettre ma 2eme barette de 256 paske si je la mets ca beeeeepp et ca boot po !!!!!
compris ? :lol:
grim fandago
Merci d avance
Comprend pas la question ??
Noooky :hello: voila je ne sais po mettre mes 2 barrette infineon de 256 chakunes kkun px  m aider  svp ?mon bios date du 17/12/99
Merci d avance
