7900 connectés
Sujet : :::: Kel CARTE MERE choisir pour Athlon XP 1800 ::::
webalex C sympa de m'avoir éclairci les idées, car j'avoue que je connais rien en cartes mères ! :)
Murphy
webalex a écrit a écrit :
Bon alors je pense que je vais prendre la epox
bon choix :)
webalex Bon alors je pense que je vais prendre la epox
Tangzzz Supports Socket A Processors.
AMD Athlon & Duron.
 VIA Apollo KT333 AGPset.
 I/O Controller.
1 Floppy drive controller,
1 Parallel port (EPP, ECP),
2 Serial ports.
 USB.
2x USB 1.1 connectors (2 extra through optional back-panel cable).
This cable is included with the EP-8K3A+ and available optional with the EP-8K3A mainboard.
 Award PnP BIOS. Flash upgradeable.
120MB ATAPI floppy drive and ZIP support!
 Standard ATX form factor.
305mm x 245mm ATX.
 UltraDMA-100+33 EIDE Controllers. (Up to 4 IDE devices).
Backwards compatible with PIO mode 3/4 & UltraDMA-33/66/100
Additional UltraDMA-100+33 RAID controller x2. (Up to 4 devices). Only for the EP-8K3A+
 3x DDR-SDRAM Slots for PC2700.
3GB max. supported.
 PS/2 connectors.
1 PS/2 mouse, 1 PS/2 keyboard.
 6 (32-bit) PCI, 1 AGP.
AGP supports 1x, 2x and 4x  modes.
 Built-in AC97 Digital Audio (by VT8233A/8235) :
Dual full-duplex Direct Sound channels
FM synthesis for legacy compatibility
Supports game and MIDI port
 Extended Functions for Greater Value!
Supports Hardware Monitoring Function by W83697HF
Supports exclusive KBPO (KeyBoard Power On)
Supports CPU Vcore setting via BIOS
Supports Memory Voltage setting via BIOS
Supports CPU Clock setting via BIOS
Supports STR (Suspend To RAM) power saving Function
Supports CPU Multiplier setting via BIOS
Supports Wake-On-LAN Function
Post port onboard design with LED display
Designed with VIA's KT333 chipset, the EP-8K3A+ is a high quality motherboard built by EPoX in the industry standard ATX format. In addition to the AGP interface for high performance graphics, this board offers six industry standard PCI, one 4x compatible AGP expansion buses as well as many other advanced system and BIOS features.
For full feature system designs, the Apollo KT333 is paired with the VIA VT8233A/8235 super south bridge. Highly advanced, the EP-8K3A+ combines integrated AC-97 audio support.
Two bus mastering ATA 33/66/100+33 EIDE ports are provided plus a floppy disk port supporting two drives of any industry standard capacity including 2.88MB as well as 1.44MB and lower capacity types. In addition an IrDa infrared port allows the connection of remote devices.
Murphy
Bonjour à tous,
Voilà, je sais pa kel carte mere prendre pour un athlon XP 1800,
au début j'avais pri une "MSI K7T266 PRO2" chez rue du commerce mais y m'dise ky en a plu !!
Donc si vous pouviez m'en conseiller un otre dans la même gamme de prix, ce serait sympa.
:sarcastic:
MSI K7T266 PRO2 c une vieille carte... maintenant y a le chipset kt333. donc prend plutot une epox 8k3a, asus a7v333 ou msi kt3 ultra
Tangzzz
1000 balles !!!
En effet elle est pas cher, et elle supporte la DDR ????
quelle carte tu choisirais entre celle que tu me dis et la MSI K7T266 pro2, sans compter le prix ?
prends la epox les yeux fermés  ;)
latoucheF7duclavier www.ldlc.com
webalex 1000 balles !!!
Tangzzz
maiatzky a écrit a écrit :
connaissez-vous un site qui vend les asus
risko
ldlc
matos.net
Tangzzz
la 8k3a+, C koa son prix
1000 balles
webalex la 8k3a+, C koa son prix
Tangzzz
En fait j'avai choisi ma carte MSI parce kel avais un bon rapport
qualité/prix, et c une carte offrant ces avantages ke je cherche
prends la 8k3a+ => + de 200 en fsb avec de la ram potable
webalex En fait j'avai choisi ma carte MSI parce kel avais un bon rapport
latoucheF7duclavier
C koa le twinbank ??
en gros quand t'as deux barettes ça profite de la nade passante de ces deux barrettes de ram. :) Un peu comme les PIV.
latoucheF7duclavier j'ai déjà conseillé une msi pour un pote. Son pc esttrès stable, même sous windows 98. :)
Peut être un coup de pot...mais il en est très content. :)
Asus est une marque de qualité et l'asus a7n266c offre un bon rapport qualité+stabilité/prix. :)
Tangzzz
tilateur a écrit a écrit :
t un winner toi!!!!
tu te bases sur quoi pour dire ca? ton experience personnelle? permet moi de te dire que c'est bien peu par rapport au miliers de gens qui utilisent ces cartes et qui en sont satisfaits!!!
MSI est une excellente marque de carte mere, peut etre pas autant que asus (et encore pas de beaucoup, mais cela doit venir du fait que msi sorte ses cartes avant celles d'asus).....
sinon je ne veux pas tomber ds un debat de merde a la amd/pentioume ou ati/nvidia donc je ne repondrai aux insultes que tu vas surement me pondre.....
sur ce A+
t'as des aktions msi ???
ya bcp de pb avec la ram noname / epox ou asus
c tout
tilateur
Tangzzz a écrit a écrit :
msi ca pue
t un winner toi!!!!
sur ce A+
webalex Tu saurait pa son prix ?
Et es-kel est stable, ...
Tangzzz
mais pourtant g un pote qui me la conseillée, T sur ? :??:
vi
tapes la 8k3a+ d'epox  ;)
webalex C koa le twinbank ??
webalex mais pourtant g un pote qui me la conseillée, T sur ? :??:
latoucheF7duclavier j'ai longtemps hésité, et finalment je prends l'asus a7bn-266c.
Pas de via, pas chère et bien stable. :)
En plus il y a le twinbank.  [:tkilla]
Tangzzz msi ca pue
webalex Bonjour à tous,
:sarcastic:
