5245 connectés
Sujet : NV 30: codename "OMEN"/last rumored specs
shaky
busylover a écrit a écrit :
:sleep:  :sleep:
kes ta toi?  :??:  :??:
shaky
:sleep:  :sleep:
busylover :sleep:  :sleep:
busylover >Remarque 1: ceci n'est pas du 100% fromage blanc, encore du buzzware dedans probable, nothing's perfect  :D
>Remarque 2: ceci a pour source l'inénarrable "Mrsinster" qui, il faut bien le dire, ne s'était planté que de très peu dans ses prophéties passées,quelques mois avant la sortie des bolides précédents
>Remarque 3: j'ai précédé d'une recherche sur forum (keywords: nv30 - eclipse - omen, etc...)= rien, donc on y va
You wanted NV30 RUMORED spec`s?
Here they are!!!!
Please rember these are RUMORED spec`s NOT final or 100% factual....
Just RUMORED spec`s!
_Omen_ Card
AGP 4x and 8x
Copper Core Gpu Processor 0.13 m  default clock 450 MHz
73 million transistors
8 pipes
Quad Vertex Shaders
Dual Pixel Shaders
85 bone capable
Lightspeed Memory Architecture III
Quad Cache memory caching subsystem
Dual Z-buffers for greater compression without losses
visibility subsystem
NvAuto advanced pre-charge
Advanced Hardware Anisotropic Filtering:
A new 12nvx mode that delivers improved subpixel coverage ,texture placement and quality.
12nvx mode should deliver 80% better subpixel coverage and placement than previous modes
Hardware bumpmapping
The NV30 can now improves upon it`s textures per pixel in a single clock cycle.
By doubling them!
By applying four not 2 textures per pixel in a single clock cycle,and through a "loop back" it can also apply an additional 4 textures per rendering pass.
That said this greatly improved trick improves performance and image quality by almost completely negating the chips need for multi-pass rendering!
A separate second  copper processor running at 450Mhz and 0.13m as well
Shall handel all T&L now called TT&L (True Time and lighting) .
It will also handel NVAutoShaper a new prechached and precacheable system.
That has precached shapes cirles,squares,triangles,and other shapes.
Programmers can also add shapes to be temporaly stored in it`s precache to speed things up.
This should speed things up and make standard shapes more accurate!
128 MB DDR-SDRAM @ 375 MHz x2 = 750Mhz and 256 bit yes 256 bit!
370Mhz RAMDAC
Direct X 9.X compatible
Latest Open Gl
Backward glide game capable thanks to
NvBlur (Yes a new version of Glide!)
NView Multi-display Technology
Built in reprogramable dvd and tv decoder chip
There maybe A new form of cooling the gpu`s .
Where the Gpu`s have a hole in the middle and through the board.
So, the hottest area of the Gpu`s gets more efficent cooling.
http://www.nvmax.com/cgi-bin/nvmax [...] 1017987953
Hormis les exclamations de rigueur>>  :eek2:  :sarcastic:  :crazy:  :heink:  et les commentaires du style "encore un troll" ou "encore du vaporware",
y a pas de mal à fantasmer et discuter même si l'actu réaliste c'est plutôt l'attente de la Ti 4200
Au fait, l'histoire d'une nouvelle carte 2x plus puissante que la ti4600.... ça serait pas DEUX gpu's à 450mhz core desfois mmmuuuhh?  :sol:
over & out  :sol:
