2506 connectés
Sujet : Disque Dur pour portable Toshiba 2130CS
chewie ATA-2 <> E-IDE ?
lightman Euh c'est un peu plus compliqué que ça...
chewie :spookie:
chewie d'après un document sur le site de toshiba :
Advanced Technology Attachment (not to be confused with the PC Card ATA drive) is basically the interface between the Hard Drive and the computer.
ATA-4 drives were designed to be backward compatible with the ATA-3 controllers.
Although you should have no problems installing an ATA-4 drive in place of an ATA-3 drive, the computer because of it's ATA-3 interface may not be able to take advantage of the interface enhancements related to the enhancements related to the ATA-4 interface on the hard drive.
Note: Information related to the actual differences between ATA-3 and ATA-4 seem to suggest the changes were related to both the addition of support for ATAPI (Advanced Information Attachment Packet Interface) CD-ROM drives and tape drives as well as to performance.
Hard drive upgrades can be performed on most Toshiba computers.
Toshiba Accessories at 1-800-959-4100 offers hard drives, hard drive upgrade kits and data transfer systems for several notebook models.
Toshiba Authorized Service Providers may be contacted for drive installations and other hard drive upgrade options.
ATA is the "official" name that the ANSI group X3T10 used for what the computer industry cal ls IDE (Integrated Drive Electronics).
ATA-2 or EIDE (Enhanced IDE) was adopted as a standard by ANSI in 1994 and is called Advanced Technology Attachment-2 (it's also referred to as "Fast ATA" ). ATA-2 provides for faster data rates, 32-bit transactions and (in some drives) DMA. Optional support for power saving modes and removable devices is also in the standard.
ATA-3 added further capabilities related mostly to speed.
ATA-4 sometimes called ultra DMA added ATAPI (Advanced Technology Attachment Packet Interface) capability to the ATA interface. A development of the Advanced Technology Attachment specifications which gives nearly twice the maximum transfer speed of the ATA-3 standard (PIO Mode 4).
Ca veut dire que le Toshiba peut accepter les ATA-4 sans pouvoir les exploiter pleinement. Donc les ATA-3, ATA-2 et ATA-1 marchent ?
Si j'ai bien compris, ATA-2 == E-IDE ?
atmonasro [citation][nom]chewie a écrit[/nom]Bonjour,
Ayant un vieux portable DX4/75 de marque toshiba T2130CS/520, j'aurais voulu savoir si tout disque dur (de portable) pouvait y etre monté dessus.
Un disque de 40 Go, par exemple, ne posera pas de problème ?
J'ai le même modèle, avec un dd de 1,4 Go. Aucun prob.
Je crois qu'on peut monter jusqu'à 2 Go. Il te faut juste la bonne épaisseur : c'est 12,5 mm.
Attention la 1ère fois, il te faut rentrer dans le bios et activer l'enhanced IDE, sinon il ne bootera pas.
lightman Non car il bootera même pas au demarrage du BIOS
(J'ai essayé)
[jfdsdjhfuetppo]--Message édité par lightman--[/jfdsdjhfuetppo]
chewie On peut utiliser un DD sous windows 95 de plus de 528 Mo si le bios ne le reconnait pas ?
chewie je suis sur toulouse
cedric_bix
lightman a écrit a écrit :
Si dans les boutiques d'occaz comme CassePC
ou Ordiscount...
C'est 80Frs un DD 2.5" de 540Mo IBM (Neuf emballé)
ta un cassePc prés de chez toi ??
je croyé qu'il n'y en avais qu'un a Maucombre
chewie mais windows 95 doit pouvoir gérer les disques de plus de 528 Mo non ? On s'en fout du bios !
chewie on ne sait jamais ;)
ca court pas les rues un petit disque dur pour portable ...
zulman
chewie a écrit a écrit :
peut-on installer un DD de pc de bureau sur un portable ? est-ce possible ?
et l'inverse ?
c koi cette question ? tu veux essayé de mettre un dur d'un micro dans un portable ?? fais des photos si tu le fais !! je rigolerais un bon coup ;)  :lol:
sérieusement, t'as vu la différence de taille qu'il y a entre les 2 ??
sinon c possible mais via un port externe.. et l'inverse, g jamais essayé mais le voltage ne doit pas être le meme.. du moins je pense :??:
chewie peut-on installer un DD de pc de bureau sur un portable ? est-ce possible ?
et l'inverse ?
[jfdsdjhfuetppo]--Message édité par chewie--[/jfdsdjhfuetppo]
chewie mouais, enfin, toujours est-il que je suis bloqué à 528mb
zulman
merde, ca marche pas pour mon modele ...
ONLY ON MODELS: T2400CS/CT,T3600CT,T4700CS/CT,T4800CT
J'ai le T2130CS ...
arf
j'me disais aussi... un DX4/75 flashable.. il aurait été le premier du genre...
sinon pour des petits durs pas cher, neuf, il y a la société supracom qui vend des portables d'occas, des pièces détachées diverses pour portable et des logiciels (bizarre d'ailleurs les produits microsoft à des prix défiants toute concurrence..)
bref, voila les trucs : tout est en 2.5 IDE
3Go Compaq 75?
6Go Compaq 90?
10Go Hitachi 120?
20Go Hitachi 150?
attention c HT mais c pas cher du tout !!!! il n'ont pas de site web pour l'instant..malheureusement (je pense que c volontaire..;) )
un windows XP home à 95? ... c incroyable... mais attention, microsoft guette ce genre d'entreprise.... [:sfgto]
lightman Je crois que oui tu est limité à 528Mo si tu n'as pas
la possibilité de passer en LBA Mode.
Par contre j'ai déjà reussi à mettre un DD de 830Mo dans
un 486Dx2 Non-LBA mais en rusant
Je n'ai fait qu'une partition de 528Mo dessus (300mo non utilisés)
chewie ouais, mais bon, je me suis rendu compte que mon modele ne passait pas en E-IDE ...
donc je suis vraiment bloqué à 528 Mo ?
zulman
Pour info :
avec un nouveau bios, je peux avoir ceci en plus :
EIDE HARD DRIVE SUPPORT
The BIOS section for hard drive support has been upgraded to support
Enhanced IDE hard drive .  This means that support for hard drives
larger than 528mb is now available.  Check with your local Toshiba Sales
representative for a listing of compatible hard drives.
Est-ce que ca veut dire que tout disque dur de 2"5 en E-IDE peut etre accepté (et donc un disque d'environ 2 Go) ?
tu ne pourras tjrs pas mettre ton 40Go... mais par contre le 2go devrait passer.. en LBA
lightman CASSE PC (Destockage, fin de série, occase)
        - ROUEN
          7, rue de l'Essart - 76680 Maucomble
          Tel : 02 32 80 18 18
        - RENNES
           4, rue de Belle Ile, ZA du Pontay - 35760 St Grégoire
           Tel : 02 23 25 01 95
         - BREST
           1, rue Delobeau - 29100 Brest
           Tel : 02 98 46 97 96
MICROSTOCK  Destokage
GLOGE TROTTER  Destockage portable
        12, Rue Coypel - 75013 PARIS
        Tel : 0 803 31 31
XLSYS  Destockage
        22, rue des Venêts - 92000 NANTERRE
        Tel : 01 56 38 00 00
chewie merde, ca marche pas pour mon modele ...
J'ai le T2130CS ...
arf
chewie Pour info :
lightman Euh ils ont un petit bout de site à 2Frs
qui fait juste plaquette pub.
Sinon Email je sais pas, en revenche le telephone oui!
chewie ils ont un site ou un email ?
lightman CassePC Rennes
chewie je n'ai pas trouvé ce DD.
Tu l'as vu ou exactement ?
lightman Si dans les boutiques d'occaz comme CassePC
ou Ordiscount...
chewie alors il me faut retrouver le meme disque dur ? Arf ... ca va pas etre possible à mon avis ...
lightman Largeur standard 2.5pouces
et 2 hauteurs standards 12.5mm et 9.5mm
cedric_bix c'est des 2"1/2
(pour pc de bureau c'est 3"1/2 et 5"1/4)
autrefois il y avais même des disquettes (et donc des lecteurs) 8"
zulman
Merci,
Thomas
ça m'étonnerais grave !!! ce genre de vieux bios n'est pas flashable en +... je crois que c cho  :sweat:  et que tu l'as  :fuck:
chewie est-ce que il y a des tailles de disque dur ?
comme pour les disque 3"5 et 5"3/4 pour les pcs de bureau ?
merci de vos réponses ;)
cedric_bix c'est pas tous les mêmes diques!
a la base je pense que oui, mais certain le range des boitiers proprietaire. j'ai vue ça dans une broquante de vieux sys en normandie
chewie et un disque de 1 Go ou 2 Go ?
chewie comment le savoir ?
scarladoue je pense pas que ton portable prendra un 40Go > question de bios  :heink:
chewie Bonjour,
Merci,
Thomas
