3802 connectés
Sujet : L'epox 8K3A+ est fourni avec...?
Squallo Cyberia :D  :D  :D  :D
arrete non ca coute plus chere que la carte elle meme c quoi???
Tangzzz c une barrette de 1Go 2700 crucial registered offerte
Squallo Cyberia oui c quoi cette barette  :ouch: ???
fireman hey y a de la ram livré avec la boite, c koi la marque :D
Squallo Cyberia donc un 100 et un 133 voila merci
Tangzzz http://www.hardwarepub.com/reviews [...] cludes.jpg
Tangzzz allez :
What's Included:
-EPoX motherboard
-User's manual
-Floppy ribbon cable
-ATA-133 Hard drive ribbon cable
-ATA-66/100 Hard drive ribbon cable
-9-pin COM2 cable
-Driver and utility
Squallo Cyberia c sympa de vouloir m'aider mais bon c toujours pas marque  :hello:
Tangzzz Supports Socket A Processors.
AMD Athlon & Duron.
 VIA Apollo KT333 AGPset.
 I/O Controller.
1 Floppy drive controller,
1 Parallel port (EPP, ECP),
2 Serial ports.
 USB.
2x USB 1.1 connectors (2 extra through optional back-panel cable).
This cable is included with the EP-8K3A+ and available optional with the EP-8K3A mainboard.
 Award PnP BIOS. Flash upgradeable.
120MB ATAPI floppy drive and ZIP support!
 Standard ATX form factor.
305mm x 245mm ATX.
 UltraDMA-100+33 EIDE Controllers. (Up to 4 IDE devices).
Backwards compatible with PIO mode 3/4 & UltraDMA-33/66/100
Additional UltraDMA-100+33 RAID controller x2. (Up to 4 devices). Only for the EP-8K3A+
 3x DDR-SDRAM Slots for PC2700.
3GB max. supported.
 PS/2 connectors.
1 PS/2 mouse, 1 PS/2 keyboard.
 6 (32-bit) PCI, 1 AGP.
AGP supports 1x, 2x and 4x  modes.
 Built-in AC97 Digital Audio (by VT8233A/8235) :
Dual full-duplex Direct Sound channels
FM synthesis for legacy compatibility
Supports game and MIDI port
Squallo Cyberia OUI C CELLE LA  :bounce:
combien de cable UDMA133 sont fourni avec?
Tangzzz http://www.epox.nl/images/motherboard/8k3a.gif
Squallo Cyberia heu...a oui interessant  :(
mais bon et je me penche pluôt sur le nombre de nappe
alors???
Tangzzz la 8k3a elle est fournie avec de la vaseline
Squallo Cyberia :lol:  :lol: ouais UP personne la sur ce forum  :heink:
NeoHeaVen [:yoyoz]
Squallo Cyberia Y a personne qui la  :ouch:  ?
Squallo Cyberia J'ai lus dans un test que l'Epox 8K3A+ etait fourni qu'avec une nappe ultra dma 133?
c vrai?
Si vous l'avez dites moi combien il y a de nappe et a quelle norme elle sont.
voila Merci  :hello:
